Question about Elite Sl 3000 Ul Sliding Gate Operator
Need wiring diagram for q019 elite gate motor
I cant find any wiring schematics for a 1994 elite gate opener using the qo19 circuit board
4 Suggested Answers
  • 188 Answers
SOURCE: I need a new transformer for the QO19 electronic
Google your make and model number. There are several supply houses online.
Posted on Aug 08, 2009
micromatikal
  • 2777 Answers
SOURCE: I am not sure of the model but this Elite gate
Ok, do you want to try and replace these gears yourself? It is a very difficult repair and can get much worse if you have never done one of these repairs before... It is not easy to do..
I can help you find someone that can do this repair, or help you find the parts if you truly want to do it yourself.
Please reply to my answer here and let me know.
Thanks
TIm
Posted on Nov 05, 2010
  • 68 Answers
SOURCE: We have an Elite Sl-300 gate opener that will not
if you take the covor off the unit and look at the motor their is a redbotton. press that back in and tru again
Posted on Jan 13, 2011
Rear wiper stopped
Do you know how to use a volt meter ? Need to check for voltage at the motor ! , need a wiring diagram. Most of the time other people on here will tell you to check the fuse's , that doesn't end up being the cause ! Most of the time it's the motor or a wiring problem ! I have seen the wire in side the rubber boot ,when you open the rear hatch break causing a no power situation to the motor . If you open the rear hatch ,door ,lift gate , what ever you call it . If you look when it is open there is a rubber boot connecting the body to the door , there are wires in side . There have been known to break ! This next part is a FORD pinpoint test. This is how ford says how to check !
PINPOINT TEST B: THE WIPERS ARE INOPERATIVE - REAR WINDOW Test Step Result / Action to Take B1 CHECK CIRCUITS CBP43 (GY) AND SBP19 (BU/RD) FOR VOLTAGE
  • Key in OFF position.
  • Disconnect: Rear Wiper Motor C476.
  • Key in ON position.
  • Measure the voltage between rear wiper motor C476-3, circuit CBP43 (GY), harness side and ground; and between rear wiper motor C476-4, circuit SBP19 (BU/RD), harness side and ground.
  • Are the voltages greater than 10 volts?
Yes
GO to B2 .
No
VERIFY SJB fuse 43 (5A) and fuse 19 (25A) are OK. If OK, REPAIR the circuit(s) in question. TEST the system for normal operation. B2 CHECK CIRCUIT GD150 (BK/WH) FOR OPEN
  • Measure the resistance between rear wiper C476-1, circuit GD150 (BK/WH), harness side and ground.
  • Is the resistance less than 5 ohms?
Yes
GO to B3 .
No
REPAIR the circuit(s) in question. TEST the system for normal operation. B3 CHECK THE MULTI-FUNCTION SWITCH
  • Disconnect: Multi-function Switch C202.
  • Carry out the multi-function switch component test. Refer to Wiring Diagrams Cell 149 for schematic and connector information.
  • Did the multi-function switch pass the component test?
Yes
GO to B4 .
No
INSTALL a new multi-function switch. REFER to Section 211-05 .
Mar 14, 2015 | 2010 Ford Expedition EL
Hi,, i have a SL3000UL slide gate opener that stops half way.
well it seems like you have checcked almost everything. there are two things that come to mind that might be your problem, check the backup battery, messure it while on charge with a multi meter, the reading should be between 13.4v and 14.0v. if this is fine then if you have beams or loops installed try replacing them as they might be faulty.
Dec 04, 2013 | Elite Sl 3000 Ul Sliding Gate Operator
Remove and replace right rear turn signal bulb 94 suburban
OPEN REAR DOORS, REAR LIGHTS HAVE 2 TORX HEAD SCREWS IN VEHICLE DOOR HINGE AREA. REMOVE SCREWS, WIGGLE & PULL OUT ON LIGHT ASSEMBLY. THERE IS A 4 WIRES PLUGGED INTO THE LIGHT BOARD. UNPLUG & REMOVE 2 HEX HEAD SCREWS TO REMOVE BOARD & LIGHTS ASSEMBLY. IF A NEW BULB DOESN'T FIX THE PROBLEM, NEW BOARDS ARE AVAILABLE AT THE PARTS STORE.
Jan 16, 2011 | 1994 Chevrolet Suburban
My sl 3000 ul gate wont open unless I help it out after i press button on board I have to turn motor shaft and push on gate and then it will catch and opne/close. Is it my motor or my worm gear?
if the motor cant rotate the shaft by itself, its likely a burned coil in the motor, but if the motor is running but not moving the gate then its a broken gear
Jan 24, 2010 | Elite Sl 3000 Ul Sliding Gate Operator
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Strike open light flashes and gate opens
it was a loose connection on the circuit board in the romote keypad
Sep 30, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
Schematic for mighty mule 502, lighting hit gate opener and now it does not work have replaced parts of foil runs and blown capaitor
Well this is a BAD situation, because your opener was NOT grounded, you will have to replace the Circuit board, but since this damage was caused by an act of god "nature, being lightning struck" Than GTO, "mighty mule" will probably NOT replace the board leaving you to BUY new ones, which are about $100 to $200
Sep 29, 2009 | Gates Deer Fence: Mighty Mule Driveway...
Wiring diagram
ok, try purchasing a Chilton Manual (NOT a Haynes- it's junk). In it you'll find the complete wiring diagram.
Aug 03, 2008 | 1998 Ford Escort
Elite Sl 3000 Ul Sliding Gate Operator Logo
280 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
