Question about Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac
Leaf blower will not start
Just brought it yesterday and mix up the 50: 1 with a gallon of gas and the unit will not start
  • 63 Answers
SOURCE: someone ran gas instead of 2-cycle in leaf-blower; now locked up
It's probably dead. If the rope won't pull buy another and keep it for parts, the repair bill will be more than it costs. Spray some wd- 40 in the spark plug hole and let it sit for a couple days, IF it frees up you got lucky but don't expect it.
Posted on Mar 16, 2009
  • 272 Answers
SOURCE: Ryobi RY08576 25.4cc was started without mixed fuel
If the engine is sticky ie harder to pull it might have to be pulled apart new piston and honing of cylinder. not difficult just a pain. If it doesn't seem any harder to pull, Drain all of the unmixed fuel. Put a few drops of 2cylinder oil in the spark plug hole and pull the starter a few times with the plug out of it. Put a few more drops in repeat. Replace the plug (new plug) Put in mixed fuel prime the system cross your fingers and it should start up for you.
Posted on May 12, 2009
rwvanlue
  • 486 Answers
SOURCE: ryobi gas leaf blower starts but will not stay
carburetor & fuel system needs to be cleaned and carburetor diaphragms and gaskets need to be replaced, inspection of fuel lines and filter
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: ryobi backpack leaf blower about three years hard to start
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
  • 100 Answers
SOURCE: Do you need special oil to mix with gas for the
40 parts fuel to 1 part 2/stroke oil
Posted on Aug 14, 2010
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is gas ratio 50 t0 1 for homelite leaf blower
50:1 is the gas ratio... thats about 2.6 ounces of 2 cycle mix to one gallon of gas
Sep 14, 2014 | Homelite Garden
What is the oil mix for 2 gallons of gas for a 2 cycle gas leaf blower
Only use 50 to 1 as that is what is specified.
To get 50 to one ratio with the 6.4 oz bottle of 2 stroke oil just add 2 1/2 U.S.. gallons and that will be 50 to 1 ratio so you will have the correct ratio .
Aug 11, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
I need to know the correct ratio of fuel mix for homelite blower/vac
It is 50:1. That is 2.6 Ounces 2 stroke oil/ US Gallon or 1.3 ounces of oil / 1/2 US Gallon. I recommend synthetic and adding Stabil brand gas stabilizer to the mix. It helps greatly.
Dec 03, 2010 | Homelite Mighty Lite Blowervac
What ratio of gas mixture 2 cycle oil to a gallon gas
You mix that 50 - 1 or 2.8 ounces per gallon of gas...
heatman101
Sep 30, 2010 | Homelite Blower Frame Up04405 Up04405a...
Need to know gas mixture
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
Is it a gas oil mix?
Yes, most likely. I am not sure what model you have, but if you don't put oil in the crankcase, then it is. I would mix 50:1 ratio. Use optimix. one tube for a gallon of gas. It burns clean and they warranty any motor you use it in. When you use this, it doesn't matter the ratio, so you can use it in all of your 2 stroke units. Also, it won't hurt a four stroke unit either.
Jul 05, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas mixture for ryobi 25cc blower
buy a sythetic oil for two-cycle and the mix will not mater,it will cover 16-1 to 50 -1(note if it says mix one bottle or tube to 1 gallon,mix it 1 to 8 tenths of a gallon,always runs a little better and extends the life of your machine
Jul 04, 2009 | Ryobi Backpack Blower 25.4cc
Proper gasoline and oil mix ratio.
My echo uses 50-1 ration. Home Depot sells the small containers for Echo Leaf Blowers that you mix with one gallon of gas.
May 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Ryobi Ry09050 26cc 200mph Gas Handheld Leaf Blower/vac Logo
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
