Question about Panasonic AG-DVX100B DV Digital Camcorder
How to clean Heads of DVX100B
I bought a head cleaning tape and when I put it int he camera it wont accept it and it says Auto Reel Lock.
Does anyone know why that does that? And what is the best way to clean the heads?
  • 126 Answers
Hello there! This kind of tape is abrasive and so when it starts to rotate the S-post is not rotating one and the tension gets higher than it use to be with a normal tape.The best solution for this problem is to rotate upper drum slowly by hand carefully and spray towards it a head cleaning spray.Then wait for 15 min.and blow hot air from a hair dryer inside mechanism for 10 seconds ,and by this action no more droplets will stay on the drum surface.Attention when you put the first tape wait for 15 seconds in pause or stop mode and after push REC or PLAY button.
Posted on Feb 02, 2010
Before I cleaned the head, no pic.. after cleaning the head, no pic.. what do I do?
If you can hear the sound then cleaning the head sometimes works. Unfortunately no amount of cleaning will cure a faulty VCR head
By the way you posted this in the cassette and Reel to Reel tape section not the VCR section so it took me longer to see this.
Dec 07, 2015 | Audio Players & Recorders
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
I constantly get this message-"re-insert
No. The timing cam is misaligned. The carriage is suppose to accept the tape, and when you close the door, it pulls the tape from the carriage towards the head and drive the take-up reel to the supply reel as the head reads or plays back the tape. If the timing cam is misaligned, it will not accept the tape and thus you get the error message.
Nov 12, 2010 | Sony Handycam DCR-TRV280 Digital Camcorder
Jittery video and sound, and now no playback
You may have damaged the heads if your cleaner tape was old and dryed out and had grit on it, buy a new camera head cleaning tape for a start, never rewind it as lots of folk do, if you do that all you do is put the old dirt back on the head.
May 22, 2010 | Sony Handycam DCR-TRV460 Digital Camcorder
My cat peed on the tape, i put it in camera went nuts. took it out, cleaned the tape, cleaned the heads,  now only plays blue on another tape where i know there is picture.  what can i do to use the...
Use video head cleaning cassette to clean camera's video heads. I also suggest you not to use this dirty cassette any more because it will clogge again camera video heads.
May 30, 2008 | Sony Handycam DCR-TRV17E Mini DV Digital...
Tape Deck in Car
Sounds like a poor "connection" between the cassette head and the head in the adaptor.
This could be caused by either head being dirty, or the tape head may be mis-alligned.
You can clean the heads with a proprietary head cleaning fluid.
Check with a standard tape.
Also, if your head unit supports it, switch the auto-reverse control. Some adaptors have dual heads for auto-revers decks, and some only have a single head.
May 07, 2008 | RCA RS2640 CD Shelf System
Incompatible Tape
try a cleaning tape first - best not to rewind the cleaning tape because it will put back the crud previously removed ? into your heads and guides ( last tape to play is prime suspect ) ; - - digital heads wear faster than analog so a new set of heads is next possibility but if the cleaning tape works . . . retire your library soon as possible .
Jul 26, 2007 | Panasonic PV-DV400 Mini DV Digital...
Black or blank screen
your older recordings will only play on a pal monitor / tv ; if the camera video is ok now ? your tape heads may be dirty , wearing out - or both ; try a cleaning tape first but - do not rewind cleaning cassettes , or the old grime will be put back on the cleaned heads and guides ;
Jul 23, 2007 | JVC GR-D73A Digital Camcorder (PAL System)
Elura 60
Hi, When you say you're "using a tape for a while", can you define "while"? The thing about these little cameras is that they don't like to re-use DV tapes. If you are recording over tapes that have previously been recorded on, then your camera could be fussy about that. You can clean the heads, but if the tape is dirty, then it will transfer that dirt back to the heads and youp;ll end up in the same position. The problem is, that the heads will wear out if you clean them to often. In the long run, it's best to use new, clean tapes. And when you are using the tape cleaner, make sure you are following the directions very carefully. NewMediaMan
Jan 14, 2007 | Canon Elura 60 Mini DV Digital Camcorder
Panasonic AG-DVX100B DV Digital Camcorder Logo
784 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
