Question about Epson Stylus 1400 InkJet Photo Printer
Epson 1400. on-screen progress meter not counting.
New 1400. New vista. Progress meter not counting the copies going through printer.
Second problem with another 1400 on vista. If I ask for 3 copies - I get 9. If I ask for four I get 16. etc.
Please help
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    What you have is a problem with the sheet pad. This is a hardware problem. An authorized Epson Repair facilitiy will be able to help you otherwise call Espon for action on repairing your printer.
Epson say they have never heard of a 'Sheet Pad'
The software does not support the number of copies
going through the printer like their previous 1290
printer. The Progress Meter only tells you how many
copies have been spooled.
Michael.
Posted on Jan 05, 2009
Image printing mistake
I would try to uninstall the printer. Do a new installation of the printer.
Dec 31, 2013 | Epson Stylus Office Equipment & Supplies
Canon MG5250 not accepting 525 catridge
Install your cartridge into the Epson printer.Go to "Start > Control Panel" on your computer.Double-click on "Printer.Right-click on the icon of your Epson printer and choose "Printer Preferences" at the bottom of the dialog box.Click on the tab entitled "Speed and Progress" and see the Epson printer monitor box.Check off the box that says "Disable Epson Status Monitor" to turn off the ink monitor.Click "Save" and close the windows. Your cloned ink cartridges should now work.
Epson may also display an error message if you refill the ink cartridges.
Read more: http://www.ehow.com/how_6163069_make-printer-recognize-clone-cartridges.html#ixzz2knfFsjd6
Nov 16, 2013 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
EPSON Photo 1400 paper feed and ink replacement problem
Asit is only a couple of months old seek a replacement under guarantee/warranty.
Jun 29, 2010 | Epson Stylus 1400 InkJet Photo Printer
Previously,when printing,the level of ink was shorty displayed.Not any more.Did I unintentionally swi th off one step of printing ?
Make sure the Progress meter is enabled. Go to Start > Control panel > Printers and Faxes (Printers for vista). Right click on your printer icon and select Printing Preferences. Select the tab called Maintenance / Utility. Now select Speed and Progress. Make sure the Progress Meter is ticked.
Aug 16, 2009 | Epson Stylus Photo R200 InkJet Printer
I'm using an Epson 1400 for dye sublimation and have installed a bag feed system. The 1400 is alerting that the cartrages are not the correct cartrages for this printer and will not let me print. Is there...
Hi I know if you go into Start, Control Panel, printers & Faxes, epson 1400, right click printing preferences, maintenance, speed & progress, and click on Disable Epson Status Monitor - this stops the printer 'thinking' the cartridges are running out... Joy
Jul 01, 2009 | Epson Office Equipment & Supplies
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson r260 status monitor wont show up
Try these steps ::>>
Go to Control Panel / Printer and Fax and then right click on the
R260 printer icon / from the options left click on printing preferences /
on the Printing Preferences window click on Maintenance Tab / on the
lower right click on the Speed and Progress Tab / on the Speed and Progress window there are check boxes look and see if the box for the Disable EPSON Status Monitor 3 has a check on it ( if it has a check., remove it )
Apr 04, 2009 | Epson Stylus Photo R260 InkJet Printer
How to get Epson R300 stylus monitor to work in Vista
I have the same problem with my stylus C88. Epson never did provide Vista drivers so I have never found a way to get the Epson software to work with Vista. The print driver does work so you will be able to print but you'll have to clean the nozzle manually by pushing the button on the printer rather than using the Epson Monitor. Sorry.
Jan 25, 2009 | Epson Stylus Photo R300 InkJet Printer
How to fix my printer progress meter
Go here and download monitoring software so you can see ink levels. Hope it helps.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?sku=C11C655001
Jan 11, 2009 | Epson Stylus 1400 InkJet Photo Printer
I have (4) documents to print, but it won't print. It says: 4 document(s) pending owner
To cancel a print job in Windows you can use one of the following two methods:
CANCELLING A PRINT JOB WITH THE PROGRESS METER:
When you send a print job to the printer, the Status Monitor will appear in the bottom right corner of your screen. Another printer icon for the PROGRESS METER will also appear in the taskbar while printing is taking place. This PROGRESS METER is there so you can manage print priorities or cancel print jobs.
1. Highlight the print job in the PROGRESS METER box.
2. Click on DOCUMENT and CANCEL, or, right click on the job name and left click CANCEL or DELETE.
3. Confirm cancelling the print job.
CANCELLING A PRINT JOB FROM THE PRINTERS WINDOW:
If no PROGRESS METER appears, you can access the document queue in this fashion:
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS (START, CONTROL PANEL, PRINTERS and FAXES in Windows XP).
2. Right click on your Epson printer name, left click PURGE PRINT JOBS (98,ME), or CANCEL ALL DOCUMENTS (2000,XP). (Or, double-click on the printer name to see and modify the status of documents in queue.)
3. Confirm cancelling all documents.
Keep in mind that once information has been sent to the printer it resides in the spooling folders within Windows. It may a while for printing to stop as this data clears the system.
If the printer continues to print (ie multiple copies of a cancelled job, or garbled print) remove the rest of the paper from the printer and allow it to run out. Once an "out of paper" type error appears on your screen, cancel the documents. Once all print job information has deleted, reload the paper and press the paper feed button once to clear the red light and return the printer to a ready state.
Jul 16, 2008 | Epson Printer
Epson Stylus  1400 InkJet Photo Printer Logo
272 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
