Question about IBM Lenovo ThinkPad T400 Notebook
The circled z appears next to the battery led and machine won't turn on
    Sergeant:
  • 416 Answers
More information needed
Posted on Nov 15, 2012
What does this mean? My machine is very new & won't drain it won't go through a full cycle & won't spin properly now it's bleeping with this flashing up on it!
Turn off machine and check water waste filter to see if blocked should be at front at bottom of machine or at back,not sure this is the cure but hope it helps
Apr 06, 2013 | Washing Machines
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
Whirlpool WFC7500VW1 won't start
My Whirlpool washer model WFC7500VW1 will not start--the green Start button keeps blinking and the red Door Locked button keeps blinking. I do not get any error codes.
Feb 23, 2013 | Whirlpool duet Washing Machines
Stunt copter won't sync
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
My Fisher & Paykel 708 smart drive washing machine won't starts and beeps.
That is Error code 9
9.
(00001001) Phase 1 to 5 - Size Error
Phase 4 to 5
The Display size switch setting does not match that stored in memory.
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size. The cold water temperature LED identifies 5kg. The low water
level LED identifies 6kg. The hold spin speed LED identifies 7kg. If the product has not been
setup before all 3 LEDs will be on. To set the size for 5kg push the wash temp up button then
the power button. To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button. This locks the size
into memory. To check the size is set, start a cycle.
Dec 20, 2012 | Fisher and Paykel Washing Machines
I have an hp dv6700 laptop that won't charge or turn on. Battery is dead and charger works. I replaced the power socket but it still won't turn on, the led does come on ,on the power socket. W
Better feast your eyes on this. The HP Pavilion dv6700 series of Notebook PC's, is also part of the Pavilion dv6000 series,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
1) http://www.mouser.com/Search/Refine.aspx?Keyword=FDS6679
$1.01 USD
2) http://www.mouser.com/ProductDetail/Diodes-Inc/ZXMP3F35N8TA/?qs=%2fha2pyFadujguNNSgppBRqXbOxXLwzGsCXiUkbNNDYUNuErUD%252bBaRQ%3d%3d
Cross reference match for AO4407.
74 Cents USD.
3) And/Or it can also be a ceramic capacitor. Those are the white rectangular smaller objects, that have a dark wide band across the middle of them.
Looking at the second photo that shows the AO4407 Power MOSFET, circled in Yellow, look to the right of the yellow circled AO4407.
See that rectangular object with the wide dark band?
There is one above it, and one above that. Now you can see the others also. There are also smaller versions in that area too.
Regards,
joecoolvette
A) http://en.wikipedia.org/wiki/MOSFET
B) http://en.wikipedia.org/wiki/Power_MOSFET
C) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
D) http://www.youtube.com/watch?v=ihoX7x0RBz8
E) http://www.youtube.com/watch?v=5uiroWBkdFY&feature=related
Oct 03, 2012 | HP Pavilion DV6700T Notebook PC
Where doe's power led,power sw,hdd led on my e-machine
You will need the user's manual for your machine to make sure that you are hooking the wires up correctly. However, most motherboards label these connections directly on the motherboard next to their pins.
Look for an area on the mother motherboard with two rows of six to eight pins. Next to them you should labels such as PWR_SW (power switch), RST_SW (reset switch), HDD_LED, PWR_LED, etc. You won't mess anything up connecting something to the wrong pins, but it isn't that hard to figure out as the wires are usually labeled in the same manner as the pins. So HDD_LED would plug into the HDD_LED pins, PWR_SW to PWR_SW, etc.
Jun 30, 2012 | E-Machines Computers & Internet
IBM Lenovo ThinkPad T400 Notebook Logo
183 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
