Question about Honda Maxus Prosumer MX5223 Pressure Washer
Honda 6.5 hp motor backfires
Back ftre on pull starts
  • Alan Manley Nov 08, 2012
    Further to above pre ignition occurs pulling the starter cord back violently to the re pull position.
2 Suggested Answers
  • 6468 Answers
SOURCE: how to replace piston rings on honda 6 horse motor
you need to remove the pump then the end cover from the engine remove the cylinder head the unbolt the connecting rod push out the piston hone cylinder and then wash the motor out with soap and water i use tide clothes soap and hot water put it back to gether now why does it smoke check the head gasket the over head engines blow head gaskets and **** oil from the crankcase
Posted on Aug 21, 2012
My engine only backfires when I try to start it. Why would this be happening?
The most common reason for this is a faulty fuel system. But here are a few problems that will cause a back fire: incorrect timing, faulty spark plug wires, vacuum hose leaks, computer faults, God-Bless!
May 15, 2015 | 8 HP GX240 Engine OHV Horizontal Shaft
Why does my Motor starts but does not go wen I give it throttle
What sort of motor is it? A two stroke or four stroke?
If it is a four stroke it could be a number of reasons why it doesn't go when you give it throttle. It's difficult to help you if you're not providing lots of details. Is the motor by itself or is it a ride-on lawn mower? Usually something like your problem is the result of lack of sump oil and or the timing is incorrect, therefore it can backfire. If it is a two stroke then the carburettor is probably clogged and cannot provide fuel at high revs but just manages to run at low revs.
Aug 12, 2014 | 5.5 HP GX160 Engine
Lawn motor backfire when starts?
Change the laminator. Part the spark plug wire is connected to. Air gap should be .025.
Jun 05, 2014 | Honda Gxv160 55hp 55 Hp 1" To 78" Lawn...
Engine backfire
1. Carbs not cleaned correctly
2. airbox not sealed to back of carbs or no air cleaner in it
3. intake manifolds broken or open and leaking air
4. any open vacuum lines will make a backfire
5. a lean condition on the engine
6. possibly valve problems or cam timing
Apr 06, 2014 | Honda CB 750 Motorcycles
Honda gx160 qh26 wont start, backfires thorugh exhst, new plug, re&re carb,valves in. .006 ex. .008 , sos please
The Honda GX160 is a single-cylinder multipurpose engine, so it doesn't have a timing belt, fuel filter, or any other wires other than the single spark plug wire and a ground. I'm having the same trouble with my Honda GX160. Spark is good, compression feels a bit lacking though, I haven't measured it. I've heard that the carburetor might be the cause, either needing to be cleaned or replaced as a whole. Dunking it in CLR works wonders, and if that doesn't work, you could probably find a new carburetor pretty cheaply.
Mar 19, 2013 | Cars & Trucks
Hello i have a 1987 honda shadow when i down shift the moter back firers my freinds tell me it has aftermarket exuast pipes on it. so do i have to change jets in the carb. The spark plugs are tan to white...
If there are aftermarket exhaust pipes on your bike, the carburetor should have been rejetted at the same time. It does sound like a lean issue, especially where your spark plugs are tan/white. It's not going to hurt anything to be a little lean, just have an annoying backfire. The only time you should have to worry is if your plugs have no color but white and it backfires while riding, not only downshifting. If you are concerned about the backfiring, I would suggest changing jets, especially the pilot jet. The pilot jet is where you are getting your backfire from. When you let off the throttle and downshift, the main jet circuit is closed and fuel is pulled through the pilot circuit. The pilot circuit cannot provide as much fuel as the main circuit, especially when the motor pulls higher rpms on downshift. This will cause a lean backfire. I know it has been several months since you posted this and you may have this corrected already, but I just stumbled upon your question. Hope this helps, Daniel.
Apr 16, 2011 | 1987 Honda VT 1100 C Shadow
The bike just backfires i change the oil pump gear and now thats all it does is backfire
Honda motorcycle suffers from sticky valve stems. this causes the intake valve to still be closing when combustion occurs - and a second explosion occurs in the manifold - which you hear as a back-fire. 2 oz Mega Power
Gas Treatment #93 in the fuel and 6 oz Mega Power Engine Tune Up in the oil and a couple 500 mile oil filter changes- each with 6 oz Mega Power Engine Tune Up in the new oi. I run both all the time to keep the problem away. Get the products for your cars and your bike. Source: http://www.auto-tune-up-and-repair-options.com/worn-motor-treatment.html
Feb 14, 2011 | Honda CBR 900 RR Fireblade Motorcycles
1994 Honda CR 250 R will not start and backfires
Hi, Kmonroe8269 and the usual suspects are:
1. Severely discharged or a damaged battery should have 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage the battery is faulty and must be replaced, AGM batteries fail in this scenario more so than lead acid batteries.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Faulty main circuit breaker and or connections.
4. Faulty ignition coil and or connections.
5. Faulty spark plug, oil or gas fouled, wrong heat range or service type, wrong gap, loose in the cylinder head, broken electrode or insulator.
6. Faulty spark plug cables, leaking or broken, internal damage check for spark leakage in the dark.
7. Faulty ignition module, switch, CKP, MAP, CMP, sensor and or any connector in the ignition circuit could have corroded, loose, or broken pins/sockets
8. Burnt exhaust valve or air leak in the exhaust system.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
1986 CR500 Won Start just backfires
Bike won start just turns over and backfires Any ideas CBR Forum...
CR250 2002 2003 pdf
http://www.partsfish.com/page/oem-parts-for-honda
Honda CR250R Owner Manual Competition Handbook
Aug 05, 2010 | Honda CR 250 R Motorcycles
Honda Maxus Prosumer MX5223 Pressure Washer Logo
126 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
