Question about Dryers
Gas valve replacment procedure - Dryers
  • Dryers Master
  • 8,220 Answers
Why? These never fail unless it is a LG
Posted on Nov 07, 2012
Service engine light stays changed gas cap done smoke test replaced oxygen sensor
Code 449 is for a defective vent valve solenoid. The engine computer can not open or close the valve or can not tell if the valve is operating.
The valve/solenoid would need to be tested and you will probably need a shop manual to get the testing procedure.
Mar 06, 2014 | Cadillac DeVille Cars & Trucks
Gas valve replacement procedures
Tank-type gas water heater control thermostat?
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Tankless gas water heater.
Each brand and model might have different instructions.
Some tankless companies post manuals, most do not, and want work done by professional.
Nov 06, 2012 | Water Heaters
We have a reliance sta kleen 805 lp water heater that we installed used and it will not let us go through the start up procedure. i assume its in some kind of lock out mode, it does not respond to hot...
Used, Reliance 805 is power vent gas
10 year old water heater that is newly installed.
Unknown gas control valve.
I'm not a fan of installing old power vent water heaters.
Usually these things are so expensive that old one is only replaced when it fails.
120Volt Outlet must have correct polarity and unit must be grounded between ground prong on cord to manifold tube connected to bottom of gas control valve. Test for continuity with multimeter.
Is this an early FV model with air intake located on bottom?
If air intake is clogged with dust, then combustion chamber overheated and tripped FV system. The older heaters need replacement parts and new gas control valve, or entire heater must be replaced.
Replace gas control valve.
Copy following link for gas control troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Post question on Tank forum with more information about type of air intake and gas control valve and history of water heater
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Oct 25, 2012 | RELIANCE ELECTRIC WATER HEATER
Auto part store says there is no egr valve on 08 dodge ram 1500 4.7. True?
25 - Emissions Control/Exhaust Gas Recirculation, Gas/VALVE, Exhaust Gas Recirculation (EGR), 4.7L/Removal REMOVAL collapse.gif Labor Operations: Click to display a list of Labor Operations associated with this procedure
2431021.jpg The electronic EGR valve and solenoid assembly is attached to the rear of the left cylinder head. An exhaust gas routing tube connects the EGR valve to the intake manifold.
1. Use a diagnostic scan tool to record any Diagnostic Trouble Codes (DTC). 2. Remove the throttle body resonator. 3. Perform the fuel system pressure release procedure (Refer to 14 - Fuel System/Fuel Delivery - Standard Procedure) 4. Disconnect and isolate the negative battery cable.
2430847.jpg 5. Disconnect the power brake booster vacuum hose (1) and the vapor canister purge hose (2) at the intake manifold.
2430720.jpg 6. Disconnect the EGR valve solenoid electrical connector (1).
2430801.jpg 7. Remove the EGR valve assembly retaining bolts (1). 8. Remove the EGR valve and the EGR routing tube from the engine as an assembly. 9. Remove and discard the metal gasket located between the cylinder head and the EGR valve assembly.
2433378.jpg 10. Remove the EGR valve routing tube retaining bolts (1) at the EGR valve assembly 11. Remove the EGR valve routing tube and discard the gasket.
Feb 14, 2012 | 2008 Dodge Ram 1500 2WD
Wont heat
do you hear 3 clicks when you start it up,these clicks are the gas valves opening to supply the unit with gas for operation,if no clicks are heard it can be the thermal fuse is open,if only 1 or 2 clicks check continuity of the main and secondary gas valve coils as they can open up or get weak from heat during operation,usually just replace both coils on the gas valve as they are inexpensive one has 3 connections and the other has only 2 connections,but first bypass the thermal fuse with a jumper wire (for testing only) then replace the gas valve coils next,unplug both coil connections then remove 2 screws holding the valves to the valve and replace and reverse dis-assembly procedure
Feb 07, 2012 | Kenmore Dryers
I have an older Kenmore gas dryer model # 97260100 it heats up for 15 minutes then goes cold, drum continues to run can u give me any insight as to what needs to be replaced
The problem is either of the cycling thermostat, high-limit thermostat or the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify any of these condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Note: This is an image of an electric dryer but the thermostat and the thermal cut-off (cut-out) locations are the same.
Disconnect each of the thermostat wires then connect and insulate them properly. Once done, reconnect power and start the dryer. The gas valve solenoid coils are indeed faulty and both need to be replaced if the problem still persists. Click here for the procedure in replacing the solenoid coils.
Gas Valve Solenoid Coils Replacement Procedure
Either or both of the cycling thermostat and the high-limit thermostat are malfunctioning if the dryer continues to heat up with the thermostats bypassed. Disconnect power then reconnect the cycling thermostat wires but keeping the high-limit thermostat bypassed. Reconnect power then start the dryer. The high-limit thermostat is the culprit if the dryer continues to heat up. If not, then the cycling thermostat is the culprit.
Also do the other way; that is reconnecting the high-limit thermostat wires but keeping the cycling thermostat bypassed. The cycling thermostat is the culprit if the dryer continues to heat up. If not, then the high-limit thermostat is the culprit.
Replace the faulty thermostat and it should solve the problem.
Nov 08, 2010 | Kenmore 72872 Gas Dryer
Have a kenmore model # 110.72822101, where's the thermostat located, my dryer gets hot then cold
The cycling thermostat or the high-limit thermostat may not be the problem but rather the gas valve solenoid coils sitting on top of the gas valve assembly. Disconnect power then verify this condition by bypassing the thermostats. Refer to the image below and locate the thermostats.
Nov 08, 2010 | Kenmore 72822Gas Dryer
Gas will not stay lit the lighter wil ignite for about 4 seconds then diminish
Your propane supply may be nearly exhausted, or your gas valve is having trouble staying open.
To check the gas valve, you will need a helper. Turn the fridge off. Open the lower outside vent. Put a finger on the gas valve. Ask helper to turn it on, you should feel the solenoid snap. If you don't feel it release and flame dies out, then gas valve may be defective. Measure the voltage with a multimeter instead of using finger. If voltage remains when flame dies, then defective gas valve.
If the gas valve snaps shut and then flame dies, you are looking at a corroded / damaged / misaliged flame sense. You will need a service manual, or the procedure to clean may be listed in the owner's manual. Either way, clean the electrode assembly, and reassemble. If still same problem, follow high tension wire back to circuit board, and make sure it is on good and tight with clean connections. If still not working, the replace the electrode assembly. If it remains inoperable, then circuit board may be defective. Most RV shops now have the ability to test circuit boards before purchasing a replacement.
Jun 28, 2010 | Thetford Norcold RV Cooler/Freezer
How do I locate and replace EGR valve?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} EXHAUST GAS RECIRCULATION (EGR) VALVE REPLACEMENT
REMOVAL PROCEDURE
1. Turn OFF the ignition. 2. Disconnect the EGR valve electrical connector 3. Remove the bolt retaining the pipe assembly from the EGR valve and carefully pull the pipe assembly back. 4. Remove the EGR valve retaining bolts. 5. Remove EGR valve assembly. 6. Remove the gasket. INSTALLATION PROCEDURE
1.
Install the EGR Valve with a new gasket to the intake manifold. NOTE: Refer to Fastener Notice in Service Precautions.
2. Install the bolts through the EGR valve. Tighten Tighten the bolts to 30 N.m (22 lb ft) 3. Connect the pipe assembly to the EGR valve. 4. Install the bolt. Tighten Tighten the bolts to 30 N.m (22 lb ft) . Connect the EGR valve electrical connector.
Jan 30, 2010 | 2001 Buick Regal
1317150009709 frigidaire dryer0how do i get at the pilot light or
There are 2 house fuses in the dryer circuit. If
1 of the 2 fuses is blown, the drum may turn
but the heater will not operate.
Gas supply valve is not open (gas models).
Dryer does not have anough air supply to
support the burner flame (gas models).
LP gas supply tank is empty or there has been
a utility interruption of natural gas (gas
models).Replace fuse.
Check to make sure supply valve is open. See INSTALLATION
INSTRUCTIONS for procedure.
See INSTALLATION INSTRUCTIONS.
Refill or replace tank.
Dryer should heat when utility service is restored
Feb 16, 2009 | Frigidaire FGQ332ES Gas Dryer
Dryers Logo
27 people viewed this question
Top Dryers Experts
