Question about ViewSonic PJD6251 Projector
How do I get the View Sonic PJD6251 out of standby mode? The blue light is on around the power button but the lamp and fan will not cut on.
2 Suggested Answers
  • 146 Answers
SOURCE: I turn on my Viewsonic
sounds like a bad bulb
projectors get a resistance reading from the bulb and if it doesnt get right value it will give you the double red lights
only other thing it could be is if the fans in projector are not turning on
call viewsonic and tell them issue and make them resolve issue
or
if unit is only 2 weeks old bring it back to store and get replacement or call viewsonic and get them to send you replacement unit - it is too new to mess with it yourself and take chance on voiding warranty
Posted on Mar 24, 2011
Viewsonic projector Pro 8200 will not start / get out of standby mode
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | ViewSonic Office Equipment & Supplies
No image on view sonic pjd6531w projector
1,check the lamp
2,check the lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 27, 2014 | ViewSonic PJD6531W Projector
Sanyo pro xtrax projector
Lamp LED should be lit when the projector is in Standby. However, the problem you are describing sounds like one of two issues. Either the lamp is bad and needs replaced, or there is a power supply fault. If you have tried replacing the lamp already, make sure you reset the lamp counter or the projector may still not function properly.
does the temp warning light come on when the projector shuts off? if so you may also try cleaning the air vent filters and ensure there is proper air flow around the projector. if that checks out then have the projector serviced as the power supply is likely suspect.
Dec 09, 2013 | Sanyo Office Equipment & Supplies
I turn on my Viewsonic PJD6251 but the lamp does not come on, and after a few seconds I get 2 red lights TEMP and LAMP. It is new, only 2 weeks I barely used. Good care.
or
Mar 24, 2011 | ViewSonic PJD6251 Projector
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
My samsung 46 in. hdtv will not power up when plugged in standby light is lit turn on then it flashes lamp led it after theen goes back to standby mode repeats this process three times then all three...
Have you Check the Lamp Fan is it still running while Lamp trys to light?Ballast board is what powers Lamp on ,but if the Lamp Fan is defective Lamp will not light.
Sep 10, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
When I turn the TV on it comes on for 1 min or so then turns off. I get the green blinking light by standby/power button. Then it comes back on....then off again.....then on. It just comes off and on...
Has the Lamp been replaced yet if not replace it pull backoff watch Fan to Lamp if it stops running while Lamp is trying to turn on Lamp will turn OFF FAN maybe defective. For Parts Call Encompass 1-800-638-3328 Clean out all dusty dirty Fans and around Lamp housing.
Oct 04, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony kds-r50xbr1 turns itself off and then green light blinks 52
I too have a Sony KDS-R60XBR1 tv and the issue that you are experiencing is due to one of your fans in the rear of the tv is not working.  The tv automatically shuts off in protective mode.  Make sure the POWER/STANDBY light is blinking and not the lamp light below it.  Is the power/standby blinking 4 times in red? If, yes then its a fan that needs to be replaced.  If its the lamp light blinking then you need to replace the lamp.  The lamp is easy to replace by ordering the lamp either from Sony for $250 or find it cheaper for approx. $150 from other DLP sources and replace youself by following your manual.  I hope this helps you.
Apr 22, 2009 | Sony KDS-R50XBR1 50" HDTV
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
NEC LT240 has Power, Status & Lamp indicators lit & wont turn on!
If your bulb finally reaches it's end before you have the chance to replace it you unit will shut itself down and go into a permanent standby mode. Changing the bulb alone will not remedy the issue. The solution is quite simple but not posted in the manual or anywhere else that I could find for that matter! All that is required is to hold down the HELP button on your remote for 10 seconds while aiming at the infrared sensor on the unit. This will reset the units bulb timer and remove it from the standby mode.
Dec 10, 2008 | NEC LT 240K Multimedia Projector
ViewSonic PJD6251 Projector Logo
111 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
