Question about Admiral 24 in. DDB1501AWW Free-Standing Dishwasher
There was a puddle infront (not under) my dishwasher last night. I think my drain is clogged. It is a base model Admiral Ultima. There are no screws holding the basket. Does it just pry out? I tried a baking soda/vinegar solution to try to clear the clog. A pot of boiling water afterwards does not drain at all. Should it be draining when the dishwasher is off? Any other ideas on what my problem/solution is?
SOURCE: admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Posted on Mar 03, 2008
SOURCE: don't spin or drain
Hi, just wanted to let you know we have a simliar prob. found out today that it was the water pump. I removed it and was checking it out . when i turned it over i found out that the bearing sleeve seperated and the loose bearings stopped the pump from working. and wouldn't allow the washer to spin. most places i checked so far the replacement assembly will run approx. 80.00 +/- plus tax.
Posted on May 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: I have water (condensation?) leaking from under the freezer
I appoligize for not seeing your post sooner here are some links to pages that may be helpful, Let me know if you need more help as Fixya has a problem notifing me of anyones response to a solution , Thanks, Sea Breeze
appliancepartsse@yahoo.com
864-812-1887
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://appliancejunk.com/forums/index.php?topic=22.0
PART NUMBER AND MODEL SEARCH FEATURE
Please feel free to contact me the charge is free, Sea Breeze
Posted on Jul 16, 2009
  • 784 Answers
SOURCE: Admiral machine will agitate, but will not drain or spin
Agitating and Spinning are from one motor. Pumping is not controlled by the same motor. If the pump is bad, it won't pump. Pump can be checked by measure the resistance of its terminal, and its measurement should not be open. If pump is good then the problem is from the pump controller. If pump is bad, then you know what to do.
Posted on Sep 01, 2009
  • 512 Answers
SOURCE: My admiral washing machine will not drain.
While you have it all apart, look into the pump. Does it appear to be clogged with anything? Does it appear to be intact? No broken blades or worn down parts? If it does not appear broken, put it back together. Leave the panel off and cycle the machine through all it's functions and see if the motor is running at all, you may have to fill it (use small load function) to get it to work unless you know how to bypass the water level switch (I will not tell you how as it would take too long). I'm not 100% sure on this but believe the pump works when motor goes one direction and the gear box works when motor runs the other (varies from machine to machine and I am not an appliance tech) and if your motor is not able to run both ways it will not pump out or spin either. You didn't mention spin so suspect it didn't get that far.
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
WHY DOES THE MOTOR ON MY SAMSUNG DISHWASHER RUN ALL THE TIME AND THE LIGHT ABOVE HEAVY BLINK?
Yes, you've got a leakage error, which means water has leaked down into the base of the dishwasher. The drain pump runs all the time, trying to get all the water out, but the drain pump can't get to the water down in the base. (Those North Korean engineers/designers aren't too bright.) You'll have to pull the dishwasher out, pull off the side panels, and dry up all the water before that drain pump will stop running. But you still have the problem of figuring out where the leak came from and fixing the problem before you can use the dishwasher. The most common source of leakage in a Samsung DW is the drain pump and/or drain hose.
Feb 24, 2015 | Samsung Dishwashers
What do i do to fix error code OE on my LG dishwasher
Based on what it mentioned on the LG website it is an error indicating a drainage error. The solution might be to clean the drain filters at the base, check drain hose under kitchen sink and behind dishwasher for kinks or blockages. On make sure the kitchen sink drain is not blocked. Worst scenario is a clogged drain pump. you will have to provide the model number for any further analysis.
Sep 19, 2014 | LG Dishwashers
665-110733490 Was working fine ,last night shut it off w/water in the bottom.also pushed cancel/drain did not drain.today I ran A wash cycle but after wash still had same amount water in...
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose-filter assembly or the drain pump not working. First try to clean the drain hose and drain pump filter located inside the front bottom panel for any clogs, then check drain pump operation. Take off the bottom access panel to clean the drain pump filter and hose. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jun 09, 2011 | Kenmore Dishwashers
No lights go on, will not run
Float valve is jammed.
Look inside the machine on the floor will be a small float valve. Looks like a small upside down cup. Lift it and clear anything from underneath.
The valve is a safety feature to stop the machine from over filling. If anything gets under the valve it will jam open and stop the machine.
Not working?
Check for a clog internal or external.
Scoop as much water our as you can. Open the cover on the floor of the machine. Usually just turns and lifts out or snaps out some are screwed in. Take your time and try not to force anything. Look for a clog there.
Check for clog in the drain. The dishwasher will connect to the drain under your sink and run either directly to the drain or into your disposal unit. Remove open the connections and look for a clog. Clear if necessary.
Not the clog?
Water is pumped out by the machine via an internal pump located under the base. If it fails the water will collect until it trips the float valve. First scoop out all the water from the machine and run it again. If water comes in and it runs to the point it fills again and trips the float then either the pump or timer is faulty.
Pump check.
Remove the machine. It will be held in place by screws directly into the counter top. You may have to lower it to get it out. The front feet turn with a wrench to lower.
Turn off the water supply. Run the unit again until you get to the drain cycle.
Connect a test light or voltage tester to the terminals at the pump. Check for voltage at the pump. If you have voltage replace the pump. If no voltage the timer is faulty.
Timer problem?
Some can be replaced as a unit others are integral to the control panel. Turn style can be replaced. Touch control can not.
For more help go to my more detailed tip "Dishwasher will not run. DW101 how to fix". Or click on my profile and you will find the link there.
Hope this helped you. Please take the time to rate this tip.
Thanks,
Adrian
Mar 21, 2010 | Kenmore 13723 Stainless Steel Built-in...
Dishwasher full of water
Check all areas stated below to address this issue.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Jun 18, 2009 | Electrolux Dishwashers
GE Triton dishwasher will not drain and after cycle.
Look at the timer to see if the contacts have finally worn off. The circuit board may have failed too.
Nov 09, 2017 | GE 24 in. GSD4320Z Built-in Dishwasher
Small puddle of water under fridge
if you have a thin sheet of ice in the bootom of the freezer your drain is clogged,use a hair dryer to lossen the ice sheet and get it out of the way,heat up the drain hole and pull the frig. out from the wall,use a hanger or something you can usr to clear the drain tube,last get a hot half cup water with alittle beach and pour it down the drain,your done,let me know how you do-ike
Nov 28, 2008 | Maytag MSD2756GES Side by Side...
My dishwasher won't drain
It is possible that it ran thru the entire cycle but was unable to drain teh waste water ( usually the result of a clogged filter screen in the bottom of your dishwasher).. I suggest you either hand bail the water out and look for the drain filter screen or check where the drain hose is hooked up under your sink and possibly into the side of a garbage disposal..That could be clogged up too... Hope that helps...
Aug 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Admiral 24 in. DDB1501AWW Free-Standing Dishwasher Logo
71 people viewed this question
Top Admiral Dishwashers Experts
Paul Bade
Oloyede Monsuru
Melissa Martin
Melissa Martin
Are you an Admiral Dishwasher Expert? Answer questions, earn points and help others
