Question about Dryers
Need directions in replacing bearing in dryer
  • Dryers Master
  • 8,220 Answers
I have several American models repair photos at my DRYER blog.
Posted on Nov 07, 2012
Lg dryer not spinning
Sounds like you may have a belt that has either slipped off the pulley or has broken. I suggest checking with the manual that came with your dryer for your particular model instructions for accessing it. If your belt is secure you may need to replace the rollers. Dryers are actually not too complicated, but bear in mind it IS possible it may be time to replace it. Replacement part numbers are in your manual. You may be able to get them from your local appliance store or order from the internet and delivered directly to your door. UNPLUG YOUR DRYER FIRST BEFORE YOU DO ANYTHING!
Jan 29, 2011 | LG Dryers
How do i take it apart to lubricate
There is nothing to lubricate since the bearing are sealed. Grease and oil travels and will getr inside the drum is most cases. If you do decide to repack the bearings with grease a strong saftey pin is needed to pop out the grease seals on the bearings. If the belt tensioners pulley bearing squeaks, replace that pulley along with the belt.
The top and front panels will have to be removed to gain access to the internal parts. The drum will pull directly out when the panels are removed as well
Disconnect the electric before tearing down
Jul 04, 2010 | Hotpoint NVL333GY Gas Dryer
Kenmore 62084 electric dryer belt fell off i need directions on how to get it back on
Good day,
I'll include a link that shows you how, however, there is usually a cause for the belt doing that.
You should make a close inspection of the belt, as well as all the bearings. You can check the rear bearings, by lifting the drum out.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
Thank you for using FixYa
Jan 17, 2010 | Kenmore Dryers
I'M TRYING TO REPLACE THE DRUM BEARING ON AN LG WASHING MACHINE
Try this website, they have parts, and a tab you can click on to see your dryer in parts.
Good Luck,
I hope this helps.
http://www.repairclinic.com/LG-Dryer-Parts
Nov 12, 2009 | LG Dryers
The dryer makes a loud squealing noise when running most of the time. Think it is a belt or bearing but cannot figure how to get inside. Top has 2 screws that cannot be reached with standard straignt screw...
Normally you would remove the front of the dryer, then it makes for easy acess of the drum and rollers..
The noise is probably your rollers, either needs lube or replacement
Sep 25, 2009 | GE Profile Harmony DPGT750EC Electric...
My dryer is making a horrible scraping sound...metal on metal. It appears to be coming from the back area. The belt is still intact...I can make the sound just by turning by hand. I've tried taking the...
rear bearing is bad you will need to take the dryer apart and replace the bearing also you need to check the front drum support while you have the dryer apart
Jul 10, 2009 | GE DBSR453EBWW Electric Dryer
Noisey when runing with a load
your dryer bearings are going bad there is one directly behind the tub and you need to take the front off and take tub unit out and you will see the bearing directly in middle of back of tub
Jun 01, 2009 | Maytag Dryers
Rear Bearing worn out
this will show you how to replace rear bearing and front We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
May 27, 2009 | Dryers
NVLR333ETOWB HOTPOINT DRYER EATING CLOTHES
Very likely the front support bearing is worn through and cracked there are also three drum slides that are positioned on the bearing which very likely worn to nothing and will need to be replaced as well. For model # NVLR333ET0WB replacement part numbers are:
FRONT BEARING: WE3X77
BEARING SLIDES: WE3X87
Good Luck to you.
Jan 07, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
46 people viewed this question
Top Dryers Experts
