Question about Procom Heating & Cooling
Remote control instrutions for procom model# 3711896
Gas log heater , operating instructions
Therinnaiguy
  • 1420 Answers
SOURCE: Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Posted on Sep 17, 2007
Buffalo12980
  • 625 Answers
SOURCE: ProCom VentFree Natural Gas 30,000BTU Garage Heater
first you gotto see IF a changeover is possible! do your instruction manuals say it can be converted?
Posted on Jan 12, 2008
SOURCE: Procom Model SN400TYLA Thermocoupler bad, can't find part
try 18778865989
Posted on Oct 28, 2008
  • 108 Answers
SOURCE: procom MN300HPA ventless heater conversion
You need to first get a regulator which will go between the propane tank and the burner. You will need to know the burner capacity in BTU/HR and the pressure required. All of this can be found on the furnace specification plate or on the gas valve. It is a no brainer Circut!
Ray
Posted on Nov 07, 2008
SOURCE: Need Instructions to use Fireplace Gas Logs
There should be a set of metal cards attached inside the fireplace.
First you should read everything there.
I know you have to first light the pilot light.
And then there should be a wall switch.
The problem I have currently is that it won't stay lit when the artificial logs are there.
Posted on Nov 23, 2008
How to fix a Control knob stuck on a procom gas heater model number MN180TPA
Spay wd40 on the knob some times these are stiff to operate some you have to push down to turn on/ off
Nov 01, 2016 | Procom Heating & Cooling
How do I resync my ProCom remote with my ProCom Vent Free Fireplace? I have an older model, SSU320RHL-GB.
I ran into this same problem yesterday while I was trying to get my used unit up and functioning.
If you don't switch from pilot to off and wait about a minute before turning it to the "electric" mode, the remote will NOT light the unit.
Oct 24, 2014 | Procom SSU320RHN-GB Heater
Where can i find a downloadable user guide,and a service manual for this model..also im tryig to find the right regulator for this model..does anyone know where i can find it??thanks!!
Here's a link to the Procom Owner's Manual website. However, the Model Number you listed doe not sound like a Procom Model #.
http://www.worldmkting.com/owners_manuals.htm
Also, all vent-free heaters, fireplaces, gas log sets, etc come with the regulator built-in. Are you trying to replace one you think doesn't work? Or are you trying to convert it from one gas type to another?
If it's the latter, there is no conversion approved for vent-free gas appliances. Plus, if you could, it would take more than just the regulator to do it. Totally unsafe to do.. Please don't attempt it.
Feb 25, 2011 | Procom SN400TYL Heater
I want to convert a Procom QN300TYLA natural gas stove/heater to propane. What parts are need to be changed and where can I get them? Also, I would like add a blower and remote control to control the temp...
You can't. You need an LP gas valve which costs almost as much as a new unit. Pressures are different and orifices need to be changed, the the pressure needs to be reset. Just buy a new unit and be safe.
Nov 05, 2009 | Procom QL300TYLA Heater
Looking for: ProCom Model MNO60HBA (about 3 years old) 6000BTU-Natural Gas-Serial#3620775. I want 3 of the plastic like adjuster knobs on top of the heater. Not the igniter button but the one to allow gas...
Control knobs can be purchased from Procom customer service at 877-886-5989. If you can't find them there, call Kozy World's customer service department at 800-776-9425 and tell them you need a control knob for a KWN109 (same size heater, manufactured by Procom, so same control knob).
Mar 07, 2009 | Procom ML060HPA Heater
Procom 30,000 Btu gas stove.fireplace
Its a real problem, given that the US has the worlds lowest average IQ means the problem is here to stay.
Perhaps the delivery drivers could be trained to fit the parts for the 'challenged' customers?
Jan 02, 2009 | Procom QL300TYLA Heater
Heating & Cooling Logo
20 people viewed this question
Top Procom Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
john h
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
