Question about D-Link DFL-800 (DFL800) Firewall
Dfl-800 loses connection
DFL-800 looses connection every 20 mins. Have to restart it all the time.
    New Friend:
i have the same problem!!! have you fixed it? How?
Thx
F.
Posted on Apr 15, 2013
lgc999
  • 39 Answers
SOURCE: dfl-1600 sytem restart
Sounds like the firmware is looping for some reason. Try this to reset defaults:
Step 1: Make sure the unit is powered off.
Step 2: Press and hold the reset button located on the back of the firewall. While continuing to hold the reset button, power on the firewall.
Step 3: Continue to hold the reset button for 30 seconds after the unit is powered on.
Step 4: Release the reset button and the firewall will be at factory default settings.
Posted on Oct 23, 2007
  • 193 Answers
SOURCE: DFL-200 WAN won't connect
might be the WAN port failure because of the lightining>so only possiblities is replace it
Posted on Nov 08, 2007
SOURCE: I need configuration aid for the DFL-210
I had the same problem. I googled "DFL-210 Configuration" and find this link http://www.mydigitallife.us/2006/09/dfl210_quick_co.html. I follow those steps, and achieve to connect.
Posted on Aug 09, 2008
  • 62 Answers
SOURCE: DFL-260 Fierwall setting for Static IP
All of these info below are available in the owner manual that you can download here :
D-LINJK DFL-260 Firewall
You can either do it true command line or with the web interface.
Posted on Jun 01, 2009
kamal1984
  • 1383 Answers
SOURCE: DFL-200 UPnP
connect your router to computer with ethenret cable in lan port.
Then access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or 'password"
then go to advanced and enable dhcp then save settings and restart the router to take effect.
Posted on Aug 18, 2009
Unable to reset Dlink DFL 700 network firewall
To perform a factory reset using the reset button do the following:
Step 1: Make sure that the DFL-200/DFL-700 is on.
Step 2: Press and hold the button located on the back of the DFL-200/DFL-700 below the word Reset using a paper clip for 10 seconds.
Step 3: Release the button.
Oct 23, 2009 | D-Link NetDefend DFL-700 Firewall
How to configure
http://www.dlink.com/products/?pid=DFL-800
Oct 07, 2009 | D-Link DFL-800 Firewall
DFL-200 UPnP
http://192.168.1.1
or
http://192.168.0.1
Aug 18, 2009 | D-Link NetDefend DFL-200 Firewall
Wan1 port not working in DFL 800 , can I use wan2
Yes, you will need to duplicate your wan1 configuration for wan2 and then move the cable. If you have any specific problems, please repost and we'll help you further.
Jul 08, 2009 | D-Link DFL-800 (DFL800) Firewall
Apr 09, 2009 | D-Link NetDefend DFL-200 Firewall
Client PC not able to ping WAN networks
Did you set reverse routing rules on the D-Link?
Dec 18, 2008 | D-Link DFL-800 Firewall
Port forwarding?
You can follow the steps on this link, click here. This is the steps on how to setup port forwarding for pc anywhere on a DFL-200. There is big possibility that the DFL-80 might have the setup configuration page as the DFL-200.
I hope this one helps.
Jul 07, 2008 | D-Link DFL 80 (DFL-80) Firewall
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
Mar 06, 2008 | D-Link NetDefend DFL-200 Firewall
NAT Traversal
NAT traversal refers to the common problem in TCP/IP networking of establishing connections between hosts in private TCP/IP networks which use NAT devices Client-based IPsec VPN connections often do not work when passing through a NAT device as the IKE and IPsec protocols were not designed to work through NAT. NAT Traversal is an add-on to the IKE and IPsec protocols that allows them to work when being NATed. NAT traversal is only used if both endpoints support it. D-Link products that currently support NAT traversal include the DFL-200, DFL-700 and DFL-1100. Note: The DFL-80 and DFL-300 do not support NAT traversal.
Feb 16, 2006 | D-Link Express EtherNetwork DI-804HV...
D-Link DFL-800 (DFL800) Firewall Logo
118 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
