Question about Dryers
Aeq6700fso dryer dryness button won't change the
  • Dryers Master
  • 8,220 Answers
E68 is a stuck button on th control panel
Posted on Nov 07, 2012
  • amandajroy
    amandajroy Nov 07, 2012
    But it's NOT stuck. I have taken the WHOLE thing apart. A few times. It works, it's cleaned. It's really not stuck, so what is making it act like its stuck?
3 Suggested Answers
  • 5 Answers
SOURCE: Error Code E68 stuck button?
control boards for this model are as low as $146.00 on ebay, although the code 68 "button stuck " issues 's I've found have been the start button switch ,found one at the local electronic store[close to what's on the board , but not exact !] for $3.99 fixed one for a customer of mine [just to see if that was indeed the problem]. Been running for the last year so far
Posted on May 24, 2010
SOURCE: GE Dryer model DSXH47 keeps shutting off after about 30-40 sec.
I am also having the same problem. So as a work around, I put the dryer into test mode (set cycle selector to 12 o'clock, press Select and Pause for 6 sec, then press Start and Pause for 4 sec). Then turn the selector switch one notch clockwise which turns the dryer on with heat. My clothes get dry, but I don't have PermPress, etc. To turn off dryer and exit test mode I pull the plug.
Posted on Jun 18, 2010
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Kenmore dryer won't start
If thermal fuse is bad, most dryers will not run. If it is bad, dryer has overheated for some reason. Check venting to be sure it is clear and be sure heating element has not grounded out.
Aug 29, 2017 | Kenmore Dryers
Auto dry not cutting off when clothes are dry
Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem. Your problem should either be dirty or bad connections with the contact continuity plates, the chrome things under the lint bucket or the control circuit.
Oct 05, 2010 | Fisher and Paykel DEGX1 Electric Dryer
I have a Whirlpool Gas Dryer LGR6646BI-12 the clothes feel warm but not hot and they are still damp
The Dryness Level allows adjustment of how damp or dry the clothes are at the end of the cycle.
  1. Make sure the correct Cycle has been selected for the type of fabric being dried.
  2. If the correct cycle is selected and the clothes are still coming out too damp, use the Auto Dry Level button (Kenmore) or Dryness Level button to increase the Dryness level.
  1. If the highest Dryness Level setting was selected and the clothes are still damp, the Customer Focused Drying Mode settings that are built into the machine can be adjusted.
Dryers come from the factory set to Drying Mode 1 (default). Drying Modes 2 and 3, include additional drying time.
Note: This change will affect ALL Auto Dry cycles.
  1. Machine MUST be in Standby mode before beginning. (Standby mode = Plugged in, Power off)
  1. To select drying modes, momentarily press the Auto Dry Level button (Kenmore) or Dryness Level button (Whirlpool) again. The dryer will beep, and the display will flash and show the next drying mode number.
  1. With the door open and the display flashing the desired drying mode number, press the Start button to save the drying mode and exit diagnostics.
  1. Press the Pause/Cancel key at any time to cancel changes and exit from this mode.
Hope this works............
May 01, 2010 | Dryers
Can't change dry options...
no try to unplug it got a few minutes if that dosen't work replace the touch pad
Dec 09, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I cannot change the different settings in the panel. It just takes me to options and the only way to get out of there is to press back. I can't change the time try, dryness level, or anything. Is there a...
Take the metal panel off the back of the top control area and find the service papers there. The papers will tell you which combination of buttons to push to troubleshoot different problems. Of course, unplug machine first and leave off awhile before opening the unit to prevent electric shock. Hope this helps.
Whirlpool duet dryer
Activate the diagnostic test mode.
1. Within 5 seconds, press more time-less time-more time-less time.
2. All indicators should now be on and "88" displayed.
3. Press dryness level button. All LEDs in group should turn off.
4. Press control on button. Control locked should turn off.
5. Open door. Press cancel.
Oct 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
117 people viewed this question
Top Dryers Experts
