Question about Harman Kardon HK695 Computer Speakers
Asending sound My old Dell crashed so I bought a new Optiplex 755. I decided to use my old harman/kardon woofer and speakers. I hooked them up and there is a asending sound overiding the other sound. Basicly making them useless. any Ideas? thanks
    Scholar:
  • 143 Answers
Dear sir
it's sound setting given in to sound control panel may be it's set to holl or equalizar is set miss match and chek yr sound pin which connected is proper or not otherwise just put a wizard given in control panel or chek yr sound drviers it;s help u...:)
thanks
please vote
jo_Chinmay
Posted on Jan 05, 2009
What cable connects a Dell PC to a Harmon Kardon HK395 sub woofer?
3.5 m/m. Normally it is color coded green. The pink connects the subwoofer to the speakers. Any color will work. Just mark both ends of wire jacks.
Nov 16, 2014 | Dell Harman/kardon Hk395 Computer Speakers...
Will Harman Kardon HK 206 speakers work with Windows 8
I just purchased a Dell XPS 8500 with Windows 8 and decided to keep using my old Harmon Kardon HK 206 speakers because I'm quite satisfied with these speakers. When I hooked them to my new PC, Windows 8 recognized them right away. The speakers work great on my new PC. Try going to the Control Panel and see if your speakers were recognized. (On my PC they're referred to as "Speakers (Realtek High Definition Audio). That's due to the default drivers in Windows 8. As long as you see speakers in the control panel, you should be OK. In that case you should check your connections. If you don't see speakers in the control panel, go back one screen and select add a device and let Windows 8 scan for any device that it hadn't recognized before.
Jan 23, 2013 | Harman Kardon HK206 Computer Speakers
HARMAN KARDON AVR 130NO SOUND FROM SUB WOOFER
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Harman-Kardon-AVR-130-Receivers-manual/id/386ci155/t/2/
The receiver must KNOW it has a sub and you must decide how bass is managed among all your speakers and set up relative levels.
May 21, 2011 | Harman Kardon AVR 130 Receiver
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
I have two Harman Kardon speakers that came with my computer. I bought a subwoofer and would like to hook it to the speakers and computers. How do I do this?
You will need a sound card which supports more than stereo sound say a 5.1 or 7.1 then you will have the extra jacks to plug in even rear, centre and side speakers if you wish as well as a sub-woofer. Cheers from Scott....pls vote
Jun 24, 2010 | HP Computers & Internet
Question on allowable use
Hi sheawm. You can use your speakers as long they have the mini-plug connector such as ipods, blackberrys, laptops, desktops, etc. so it won´t matter. I hope this helps.
May 08, 2010 | Harman Kardon Harmon Kardon SoundStick II...
How to connect speakers to the sub-woofer and my iMac.
i believe that plug is special because it feeds not only audio signal but also voltage to power the speakers. so unless u know that the speakers will get power from the plug, it will probably not work
May 24, 2008 | Harman Kardon iSub Computer Speakers
Harmon Speaker distortion
Hi, I came across a similar problem with an old Altec and the the solution was to only replace the defective side. Actually, what was replaced was only the speaker itself inside the enclosure which was cheaper rather than replacing the entire assembly. An electronics technician (not necessarily a computer tech) can do the job since some soldering might be involved.
Dec 02, 2006 | Harman Kardon Harmon Kardon SoundStick II...
Harman Kardon HK695 Computer Speakers Logo
94 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
