Question about Car Audio & Video
Having trouble with BOSS BA-2900 car amp, anyone knowing anything about...
  • 2 more comments
  • mirkow Jan 06, 2009
    Hi jhall1793!
    I cant give much technical details as I dont have really much knowledge in car amps. But I'll try anywhere. Apart of what I have already said about, before the problem occurred, the amp was overheating on regular basis (known issue with this amp), but it was enough to switched it off for few minutes and on, and have it play for some time. At one stage, it died completely. I have checked the amp, all wiring is there nothing disconnected/changed, pulled out the radion, nothing suspicious either. Noticed today, there is now power not getting there, which wasnt the case in initial symptoms.
    Also tried to get owner manual, as there are some knobs and swithes (eg. LPF, HPF and Gain) witch I'm not sure are in right position and have anything to do with it.
  • mirkow Jan 07, 2009
    Hi 69althatime,
    I know Boss amp is ****, you can find that info all over the net. I did not buy it, it came with the car I have purchased.
  • Jimmy Hall
    Jimmy Hall May 11, 2010
    mirkow: knowing that you don't have voltage @ the amp is a start. you need to find the fuse/s that supply the amp to see if it/they is/are open. with the overheating issue the amp may have failed & blown the fuse/s. if you find that it is open, try replacing it to see if the amp functions. if the fuse opens again when power is supplied, then the amp is probably fried, unless there is another device like an equalizer that is utilizing the same power source & is shorted. let me know.
  • Jimmy Hall
    i need more info. what exactly is happening or not happening?
There's your problem. Boss is garbage, you get what you pay for when it comes to car audio.
Posted on Jan 06, 2009
What's the watts for a boss audio systems BA-1200
Here is the manual with all the specs for the BASS1200 10" Low Profile Amplified Subwoofer
Sep 16, 2015 | Boss Car Audio & Video
Climate control (fan not working)
How would anyone other than the mechanic that tested
that system know the answer?
It is all about having reference material, trouble flow charts,
& proper test equipment & having the vehicle to test
Could that person have misdiagnosed it & your question is
valid,sure,but no one would know what else it could be on a
Jan 26, 2013 | 2007 Renault Megane 2.0
This is actually not so difficult from a logics perspective.
(Also it is true about their lack of schematics)
There are usually many more than one capacitor in these units. Good thing is all the capacitors are usually from the same manufacturer. Therefore is you match the size you can usually be pretty sure of the value of the blown one as they are usually a range of sizes for each value.
Hope this helps.
Jul 13, 2017 | Boss R1400D Car Audio Amplifier
Is there a fuse for transmission in a 1995 Pontiac Grand Am???
If you just had trans work done, don't use the car,
take it back & hopefully they will resolve the issue
Parts Store people are not all mechanics or shouldn't even
give out advice.
You should have a warrantee, use it
Nov 17, 2012 | 1995 Pontiac Grand Am
Im having heating issues with my boss ba-4400 plz anyone tell me why?btw its burning hot cant even touch it.
You thermal fuse/thermostat/thermistor is faulty...replace it because this is causing your heating problem and could cause a fire.
Most are located on the air duct in the back on the dryer they will look like the picture below.
You can check the fuse with an ohm meter...if it is working it will have continuity, if it is faulty it will not have continuity.
Sep 25, 2012 | Dryers
Would not play anything
If this is happening to all the discs you insert then you are having a problem with the laser lens. If the lens is faulty then you wont have any success. Replace the unit or if you want to really invest in the repair then go ahead and do so but im personally not to crazy about boss car audio equipment, quality is poor and chances are that it will happen again. Good luck boss.... : )
Mar 10, 2010 | Boss AUDIO SYSTEMS BV7300 Car DVD Player
Hi looking for a manual for a boss ba-1000 car amp
You can contact boss electronics or the amp retail store.. Most boss amps are sold at flea markets so they may not have direct access to the Manufacture. look at your amp and see if there is an 800 on it if not contact the place you bouht it for a phone #
Nov 02, 2009 | Car Audio & Video
Boss BA-2900 car amp doesnt produce any sound
i have come across a similar problem before. if you are using the ceramic (glass, clear) fuses the solder in the end caps sometimes melts. you will not see the fuse blown, but the fuse may still be bad. try a new fuse to see if that works. also make sure no single stray strands of wire from a positive or negative wire are touching on the terminals on the amp. i hope this helps. ill keep thinking of other things in the meantime
Jan 05, 2009 | Boss Car Audio & Video
Car Audio & Video Logo
536 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
