Question about Magic Chef MCO160UQ Microwave Oven
Microwave wont turn on and turns on by itself
My magic chef microwave locked itself. it wont unlock when i hold down the cancel key. what do i try next?
PDF]microwave oven and keep it for future reference. - Home ...
www.homedepot.com/.../ef8a2fd1-648b-424f-81d1-37...The Home Depot... of insurance loss. Once again, thank you for purchasing a Magic Chef product. .....To Lock/Unlock Control: The microwave oven must be in for 3 seconds until
Oct 07, 2015 | Magic Chef Microwave Ovens
Vent fan wont turn off
Steve,
The vent fan is thermostat controlled to protect the control panel. Once the panel temp drops, this will turn off by itself. This is normal for this to occur when your steaming and cooking for a long time. Good Luck
Apr 22, 2014 | Maytag Over-the-Range Microwave
Kenmore microwave hood combination, The fan wont
With the full model number, chances are we could have helped you more.
If the cooktop lights recently failed, it may need circuit board repair.
Or it may be a failed hood TCO.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Oct 15, 2013 | Microwave Ovens
Ge microwave turned on by itself and wont turn off
some kind of issue with the microprocessor for the unit that controls this function and others, not likely to be a do it yourself repair.
Dec 23, 2012 | GE Profile Spacemaker 1.8 Cu. Ft....
Microwave turntable wont turn
Hi - Possibilities of the turntable not spinning are either it is turned off, damaged or the support itself is damaged as well. Confirm that the power supply is not faulty or defective. Contact a professional to move forward accurately.
Oct 30, 2012 | Frigidaire FMV157GM Microwave Oven
I have a samsung microwave it wont turn off its aroundn 7 years old is it dead
It might be the on/off switch itself. Have you tried anything?
Feb 17, 2011 | Microwave Ovens
Microwave wont kick on unless I push the door up
Hi, this is a faulty door latch assembly. the switch is malfunctioning. the entire door latch assembly will need to be replaced.
Jun 21, 2009 | Amana ACO1520A Microwave Oven
Turntable wont stop turning, even when not in use
The turntable is a seperate intenty from the microwave itself, I would presume that the switch that turns off the turntable when the door is opened needs replacement.
Feb 28, 2009 | Panasonic NN-H965 Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Magic Chef MCO160UQ Microwave Oven Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
