Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Push start button on control panel - machine does not start
Cabrio washer Mod.#wtw600sw0 power to washer -- press start button machine does not start no lights on control panel.
  • 2 more comments
  • Anonymous Jan 26, 2009
    Start button keeps flashing.
  • Anonymous Mar 16, 2014
    My whirpool cabrio model #WTW7340XWO will not turn on when power button is pushed. However, there is power going to the control panel
    No power to my machine
    My cabrio washer model # wtw7340xwo will not turn on when power button is pushed. Power is running to the control panel
  • 318 Answers
Only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Posted on Jan 06, 2009
Technician just left my house with same problem. Panel buttons (start, pause, load size etc) worked intermittently. Took 20 minutes to start machine. Was told the interface user board was bad. It was covered under warrantee. Hope this helps.
Posted on Jan 22, 2009
My washer ( Whirlpool Cabrio M: WTW6500WW) will not start, cancel, rinse nothing! I can't even properly diagnose it because every button I press gives me an error chirp?
it sounds like you have a bad touch pad,try unplugging the machine for a few minutes to see if it resets the board,i would call the factory on this,they've been having problems with this and they might give you the part for free but you'll have to pay for the labor.
http://www.repairclinic.com/PartDetail/Touchpad-and-Control-Panel/W10070060/1202650
this could be the problem
Mar 29, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My front loading washing machine started and then displayed f1, now it will not start at all and when I pushed the start button it beeps three times and does nothing.
The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
Thank you !!
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a cabrio washer wtw6200 when i push in the start button will not do anything. it like the senser been push inside.
First check to see that you have power in you outlet. If so then you can check under the control hood and see if the 120V line comming into the motor control unit is pluged in and seated correctly.** UNPLUG FROM OUTLET BEFORE YOU CONTINUE** To get to this there are about 6 screws on the back behind the control hood, leave the bottom 2 screws on the pivoting clips.Move that galvinized panel back a little, then grab the whole top and slide it forward and lift the front edges. Once lifted there are 2 clips under the cover to release the control hood, Lift it off and you can check the 120v and all other plugs for correct position. Re assemble and try it. Good Luck
Jun 20, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I hit power button then start start light flashes and wont start
If your start button is flashing even when you hit your start button . Your electronic touch control board (ETC) is not working correctly . Either the intergrated curcuit board is not responding or the actuator on touch panel is broken . Push start button in and see if the button makes a clicking noise. If it does replace curcuit board , if it does't replace the part where you touch.
Oct 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer want start.
leave the door open and try it again if it does the same thing as before the door lock has gone
Jun 27, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Touch panel buttons do not work
This sounds like a bad touch screen. You can get a replacement online at repairclinic.com. They will have instructions on how to remove the old and put on the new
May 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
F1 error on Cabrio washer
Pressure Signal Out-of-Range
F then 1 flashes when the control detects an
out of range pressure signal.
➔ Check pressure hose connection from tub
to machine/motor control. Is hose pinched
or kinked?
➔ If F then 1 repeats numerous times after
POWER is pressed and the pressure hose
connection is not pinched or kinked,
replace the machine/motor control.
my check with part supplier is W10189966
Mar 08, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,774 people viewed this question
Dan Webster
Dan Webster
Sal De
