Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Dead tv We were watching TV with no problems whatsoever. There was a "pop" then the TV went completely dead, no power, nothing. We tried replacing the lamp, but still nothing...any idea what happened? It's a Panasonic PT-50LC14 that's only 2-3 years old. Thanks!
  • 2 more comments
  • Anonymous Dec 22, 2007
    Had the same problem with our PT-50LC14, last night, 12/20/07. Heard a pop sound and the TV went dead. Tried to turn it on and the power light comes on blinking green instead of steady then you two light grilling noise which stops and repeats continually. Called Panasonic Tech but they could not give a clue and only gave us numbers to call Service....which has appointment in next year....any quick help will be appreciated..
  • balmoral Jan 02, 2008
    Same thing happened to me New Years day 2008. Tried following fix instructions in manual ( turn power on several times) but does not work. Red lamp indicator flashes red every 5 seconds and never received a "lamp needs to be replaced" message. So I assume it is not a lamp replacement problem.
  • Anonymous Feb 11, 2008
    power supply faulty circuit diagram needed
  • pvanl Jul 22, 2008
    I had a pop and the tv went blank. I was told to replace the lamp but I can't find the manual. I took off the back and I am not sure where the lamp is. I googled the manual but can't find a diagram of the back of the TV. Now I'm not sure what is wrong.
Change the hid lamp!
Posted on Jul 01, 2008
    Scholar:
  • 125 Answers
Sounds like a power supply problem. I am sure that the pop is the fuse blown. If the fuse is blown, this means that there is a short somewhere. Rear projection TV are like LCD projectors. And all of them use Switch mode power supply. If you are lucky, there is a chance that a protection device (like a varistor) is sorted. This means that removing this, even without replacing will bring your TV to life, however... Most probably the power supply is defective.
Posted on May 22, 2007
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
ViewSonic N3252W LCD TV went pop and completely died. No power whatsoever. Not even the red light indicator that is always on as long as its plugged in.
The main power regulator board [SMPS board] has damaged. It should be replaced. Normally there is no repair to these boards. Only card base replacement is done. Check this to know more.
Jan 07, 2013 | ViewSonic N3251w 32 in. LCD HDTV
My haier htr20 tv wont power up..tv is completely dead.
Check the main power regulator section circuit.
May 20, 2012 | Haier HTR20 20" TV
Im getting no power whatsoever heard a pop last time i turned it on now nothing
The tv power supply board it is dead.That the board,where the power a/c cord plug into it.U have all the tools and understanding basic electronic also can do basic soldering work?Yes,take ur tv aparts.Check the whole power supply board carefully,by replacing all those blown capacitors that are busted open and all those capacitors are dying going to dead like bulging up or puffing up on to it tops.Replacing all those dead capacitors to a those new capcitors,do some modification of the capacitors parts like by replacing it in the same Micro fered,but the voltages should be 5 or 10 higher than those old busted or dying bulging up tops capacitors.By replacing all these dead capacitors and dying capacitors with a higher voltages capacitors.These capacitor to have a better chances to take more heat resistance,while tv be watching for hours of using.The tv should have power and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Apr 08, 2011 | Sharp LC-42D64U 42 in. LCD HDTV
I have a hitachi 42hdf52 and i was watching it when i heard a loud pop and my screen went black my green power light remained on untill i tried turning the unit on and off then it was tottally dead. Any...
Ur tv power supply board is dead.Replaced the power supply board,ur tv power will return,and the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 21, 2010 | Televison & Video
My Mitsubishi projection TV just shut off
Heat problem. Cleaned the dust off the boards and did a full reset.
Sep 07, 2009 | Mitsubishi VS-50605 50" Rear Projection...
Tv popped............then nothing
Maybe the flyback transformer going out.
May 30, 2008 | Televison & Video
No power
I also have this television and the power just went out. But, before there was a smell. I did not hear the pops. The television is 3 years old.
What do you suggest. What could be the problem. It appears that others have had this problem.
May 10, 2008 | Apex Digital GB4308 43" Rear Projection...
No Power
Your set is going into high voltage shut down. Might have been the high voltage transformer that has gone bad.
Mar 09, 2007 | Hitachi 60UX58B 60" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
204 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
