Question about ASUS P5GC-MX Motherboard
BIOS resets after unpluging PC out of a power grid?
I bought PC with this motherboard few years ago. Now I need it for some purposes, but every time, when I unplug PC from a power grid (ie when I remove PC from one room to another), BIOS resets itself. I replaced battery, and that was somewhat helpful. Now that happens not every time, but sometimes. Anyway, just read on Internet similar problem as mine with this motherboard. Any ideas what to do for this to stop happening?
  • ASUS Master
  • 3,606 Answers
Hello here is the homepage:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX/#download
Try to download a manual by selecting your windows system.
Open the manual folder and hit global for download.
Unzip the file and you need adobe reader to read content.
First of all when removing the cmos battery the bios resets to factory settings.
You need to setup the boot settings and the clock and save it when you leave the bios (read the manual how you do this)
The cmos battery (C2032) must have the volt reading 3,3 volts and the + shiny side facing you:
BIOS resets after unpluging PC out of a power grid - 11_29_2012_1_07_27_pm.jpg
Try removing the battery and clean the contact points with isopropylalcohol and a ball pin.
Take care not to harm the mainboard.
And take antistatic precautions.
Good luck
Posted on Nov 29, 2012
  • carni Jul 11, 2014
    You need a new CMOS battery situated on motherboard small flat silver disc about the 12mm Diameter same as Hans picture above
4 Suggested Answers
arclight1217
  • 208 Answers
SOURCE: pc reboot ramdomly or freeze after a while
HI! THE ONE QUESTION I NEED TO KNOW IS WHAT OS? JUST GENERALLY I WOULD SAY THAT YOU MIGHT TRY TO UPDATE THE OS TO THE LATEST VERSION. AGAIN, NOT KNOWING THE OS, THIS IS A FIX I WOULD TRY. YOU SAID THE PROBLEM HAPPENED AFTER YOU INSTALLED THE OS, BUT WHAT ELSE WAS INSTALLED ALSO? YOU MIGHT NEED TO LOOK AT ALL PROGRAMS TO BE SURE THAT YOU HAVE THE LATEST VERSIONS AND THAT THEY ARE COMPATIBLE WITH YOUR OS. SO, THESE ARE SOME IDEAS FOR NOW. TRY THEM AND IF NO LUCK, REPLY AND LET ME KNOW THE OS YOU ARE USING AND THE PROGRAMS INSTALLED. OK? I'LL BE GLAD TO HELP.
ARCLIGHT1217
Posted on Nov 02, 2008
map9966
  • 2351 Answers
SOURCE: won't boot; now no video
Hi rwbta, from your description it sounds like a bios issue.
The bios only displays: (Press the Delete key for setup) when there is a problem with a device.
(Hard disk drive, video device, over clocking settings, ECT). After resetting the bios (As you have done), display should resume. Since it did not suggest you plug the monitor into the second VGA or DVI port on the graphics card & check for display. Try another monitor, (Just to be sure). If you are running in SLI, disconnect the primary PCI express card (Blue slot) & replace it with the second PCI express card. Boot the system & check for display. No display? Move to the second port on the card & check for display. Still no display? Than it is possible your bios may be corrupt.
You can buy a new updated bios directly from Asus estore online, click this link;
http://estore.asus.com/shop/ There are currently 217 pages to search through in order to find the bios chip for the M2N-E SLI board. (Your board is still under warranty).
You can save time by calling Asus tech at; 1-812-282-2787 & talk with a tech. If you choose to do so please write down the S/N found on the parallel port. The tech will want this & check to see if the board is still in warranty. After a short talk with the tech he or she may include another suggestion or you can just ask for an updated bios chip. In either case be sure to get a case number. The average cost for a bios chip is $5.00 not including shipping. Since this board is still in warranty this item should be free for you. Asus store hours: Monday - Friday 8:00 AM. To 6:00 PM PST, excluding weekends and / or holidays.
Good luck rwbta!
Mike
Posted on Nov 22, 2008
SOURCE: Computer wont boot after memory upgrade
when working on computers you have to be carefull to ground your self before touching the inside of them. when installing memory you dont need to unpluge everythinf just the main power cord on the back of it.the blinking green light means you have something no pluged in right,double check everything you unpluged make sure it back in the right areas.on memory the slots are mark 1,2,3,4
make sure if the memory is diffrent in speeds the lagger ons go first.the first to slots normally have to be the same speed and size ram.if that does not work let me know i can look into it for you.
Posted on Dec 15, 2008
My system is password locked and I cannot remember the bios password
You cannot bypass the password security yourself. If you could there would be no point in having password security on all our devices.
Jan 13, 2016 | Computers & Internet
Reset BIOS? how to
With both PC and LAPTOP Motherboards,Pc Motherboards are easier to Wipe Passwords than laptops because of ease of getting to the Jumper on the motherboard normally by the battery on the motherboard.I would suggest looking online for the motherboard manual which should show you where the bios reset jumper is.Laptops are just the same but a lot harder sometimes to find this jumper. Hope this helps
Aug 26, 2014 | Acer Aspire 7720 Notebook PC
Bl51 motherboard
All laptops have a CMOS, or "Complementary Metal Oxide Semiconductor," battery.
The main purpose for the CMOS battery is to keep the system time, date and BIOS settings even if the computer is turned off or the main battery dies.
Individual Acer Aspire laptop models differ somewhat, but the general steps are the same when replacing a dead CMOS battery.Preparation
Read through the owner's manual for your particular Acer Aspire laptop to determine what kind of CMOS battery you need.
Purchase the battery through Acer or a local or online computer parts dealer.
Turn the laptop off and unplug it.
Also unplug any external hard drives, cameras or other external devices.
Turn the laptop over (bottom facing up), then touch something metal to remove static charge.
Removal
Remove the Phillips screws that secure the motherboard cover (refer to your owner's manual if necessary), then release the cover from the clips on the bottom of the plastic casing.
Lay the cover aside, then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable, then remove the battery.
Installation
Plug the new CMOS battery cable into the motherboard.
Slide the battery partially under the laptop casing to hold it in place, then align the cover with the slots on the bottom of the laptop housing.
Replace the screws, then turn the laptop back over.
Settings
Plug the laptop in and turn it on.
Enter your BIOS (usually by pressing "F1," "F2," F10" or the "Delete" key) before the operating system loads.
Follow the BIOS prompts or refer to your Acer Aspire owner's manual to reset your time, date and desired system settings.
BIOS Reset
Any time the CMOS battery is unplugged for more than a few seconds, your BIOS will be reset to the default manufacturer settings.
If you make any changes to the BIOS that cause problems with your Acer Aspire, unplug the CMOS battery for 3-5 seconds to correct the problem.
http://support.acer.com/us/en/default.aspx
Acer aspire laptop battery replacement
http://www.youtube.com/watch?v=mQTZ1AUR0uw
Jul 24, 2013 | Acer Aspire 5100 Notebook
Reset password
All mother board has a CMOS, complementary metal oxide semiconductor, battery. The main purpose for the CMOS battery is to store the system time, date and bios settings even if the computer is turned off or the main battery dies.
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings.
Apr 20, 2011 | Computers & Internet
How to chang bios settings password intel Dg43nb board i m loss my bios password
Turn off the computer (laptop) unplug it. Remove the Phillips screws that secure the motherboard cover then release the cover from the clips on the bottom of the plastic casing. Lay the cover aside then locate the CMOS battery cable on the right side of the motherboard. Unplug the cable then remove the battery. After a few minutes plug the CMOS battery into the motherboard... Replace the screws then turn the computer (laptop) back over. The CMOS battery is unplugged for more than a few minutes your BIOS will be reset to the default manufacturer settings. (Password removed) now you can set new password for your bios..
Apr 20, 2011 | Office Equipment & Supplies
Can you turn off the password on the motherboard
The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box (Make sure you have your manual handy), LOCATE THE CMOS BATTERY (it is look like a silver Small coin) take out the CMOS battery from the main board ( note: Before taking out the battery make sure that you already touch metal object to remove static electricity) . Then once you take out that the bios password will be reset to blank. Put it back after a few minutes. Same process as what you did when you take it out. Hope this help. Good Luck
Apr 16, 2011 | Dell (E210882) Motherboard
Hoe to you reset the Bios. it shows it needs a password but no one put one in. I have it apart but don't see and way to clear the bios
Usually the Bios password can be reset by taking out the cmos battery out of the computer motherboard for a few seconds.
If unsuccessful or unable to find the cmos battery. The Bios password may have to be reset through the manufacture.
Mar 08, 2011 | Toshiba Satellite L25-S121 Notebook
ThinkPad 600 System Board error
Have you tried using the reset jumper on the motherboard? I had a PC a few months ago that I had to replace the battery in. I eventually had to use the clear CMOS jumper and the reset BIOS jumper to get the computer to load to BIOS normally. Remember, if you don't have to correct the date and time, then the BIOS has not been reset. Sometimes it is a good idea to leave the PC off and unplugged for about 10-15 minutes to let the capacitors drain down. By doing this after reseting the PC, it gives you a clean cold boot (meaning there is nothing stored and nothing has had power before a reboot).
Nov 10, 2009 | IBM (30L2872) for ThinkPad 600E 2645-55x...
Power on password for toshiba satellite m30-107
You can by shorting the CMOS/BIOS battery connector for 30 sec's with a resister pack (2.4 KOhms), but if you don't have any PC repair experience, don't try it!
"You can blow the motherboard if you get it wrong.."
I suggest you take it to a Toshiba repair shop, it will cost about $100 to have them do it for you.
May 08, 2008 | Toshiba Satellite M30 Notebook
ASUS P5GC-MX Motherboard Logo
105 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
