Question about Homelite Mighty Lite Lawn Trimmer
I need to know the magneto gap for a 26cc Ryobi engine
Homelite magneto
  • 211 Answers
Hi
0.35 mm
regards savumihai71
Posted on Jan 05, 2009
How do I replace the fuel bulb?
Homelite and Ryobi appear to be made by the same manufacturer. Home Depot now carries a "Fuel System Tune-Up Kit, AC04122," that includes 2 replacement fuel lines and a replacement Primer Bulb for 25cc, 30cc, and 26cc 2-cycle engines. Cost is $7 +.
Aug 27, 2012 | Homelite Mighty Lite Blowervac
Is the Ryobi model CS26 considered a professional weed trimmer?
The Ryobi curved shaft trimmer is a consumer grade trimmer. Both the 26cc & the 30cc engines from Ryobi (Homelite) are pretty light duty. They have 1 piston ring and use an anodized aluminum piston and cylinder. A commercial grade engine would have 2 or 3 piston rings and the cylinder and piston would be chrome plated for longer life. Look for the emissions label on your trimmer. The emissions code of C would indicate a 50 hour emissions longevity (consumer grade). A code of B would indicate 125 hour emissions longevity (estate grade). A code of A would indicate 300 hour emissions longevity (commercial grade).
I hope this helps.
Dec 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite U2T608 edger/trimmer will not start. New plug gaped properly. Dropped carb, dissembled and cleaned out all ports. Fuel is flowing and is new. Motor wont even "cough." Suggestions?
Check the magneto for spark. Remove the plug and reinsert the wire and hold it against the engine as you pull the starter. You should get a nice, blue spark. If you don't see one, the magneto to flywheel air gap may need adjusting or the coil module is bad (rare). You basically need good compression, fresh fuel, good clean air intake, and a strong spark to get it to "pop." I realize you may know these things, but, most people are unaware of the .010"-014" air gap required between the magnets on the flywheel and the legs on the coil module. Disassembly is required to get to it and you take the same steps you would if you wanted to fix the pull rope. A standard business card has about the proper clearance needed between the aformementioned parts. Post back if needed. I am here to help.
Oct 12, 2010 | Homelite Garden
I have a Homelite Gas Trimmer UT21506 26cc Can you tell me the gap for sparkplug RCJ6Y Thanks
This engine uses a Champion RCJ-6Y with .025"
(0,63mm) electrode gap. Use an exact replacement
and replace annually.
Oct 05, 2010 | Homelite Garden
The sparkplug RCJ6Y can you tell what the gap is Thanks
The gap for a similar Homelite is .025". I didn't find your exact model. I think you have the 26cc engine. Here is a user manual from similar models. Spark plug information is on page 16.
http://dl.owneriq.net/e/e795beb6-5dd6-4dbd-a82f-57b8d1a69355.pdf
You will need Adobe Reader installed on your computer to view this manual.
Oct 05, 2010 | Homelite Mighty Lite Lawn Trimmer
What is the air gap for my magneto on my 25cc homelite weeater?
Should be around .013 to .014. turn flywheel until magnets face magneto insert your feeler gauge and loosen magneto screws...let the magneto stick to the feeler gauge and the magnets... re-tighten the screws, remove feeler gauge, and you should be set...hope this helps. ;-D
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite trimmer UT20832
The gap on my 18 year old Homelite ST-185 is 0.025. Since they are still using simple and reliable magnetos, yours should be the same.
Jun 27, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer Magneto Air Gap setting 25cc
Normall setting is 10 thou but if there is no play in the crank bearings you can set at 8 thou
Jun 23, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
267 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
