Question about Toshiba Satellite L675d-s7016 Laptop Amd Turion Ii Dual-core Mobile Process
Problem with Toshiba Satellite L675D-S7016 17.
  • joecoolvette
    joecoolvette Nov 07, 2012
    Okay................wait a minute.................I'm sitting down............Now, ...............what is the problem? Post in a Comment.http://www.irisvista.com/tech/laptops/To...
  • 416 Answers
Big problem or not?
Posted on Nov 15, 2012
SOURCE: function key on my toshiba Satellite l675D-S7040
hi.
do these works and your problem will be solved:
1- click on "windows start button" and click on "Control Panel" then go to "Network and Sharing Center".
2- when the "Network Connection" opens, Right-click on your wireless connection icon.
3- choose enable option.
Posted on Jan 27, 2011
  • 241 Answers
SOURCE: toshiba satellite L675D-S7016 is asking
Forgot Windows log on password? A Windows password reset bootable disk could do all the job for you, it can reset your lost or forgotten Windows password safely and quickly without login, you can create a Windows password reset bootable disk with the tool Windows Password Breaker, then use it to reset your password.
Posted on Feb 14, 2011
prashant2012
  • 1127 Answers
SOURCE: i want to buy a
Hi
Please click the mention below link to download the CD application Creator
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2760012&rpn=PSK3JU&modelFilter=L675D-S7052&selCategory=2756709&selFamily=1073768663
Posted on May 11, 2011
  • 1542 Answers
SOURCE: toshiba satellite l675d-s7049 wifi problem?
Hi
If you look down to the bottom right hand side of your screen you should see something that looks like a tv screen or something that says network internet access
take your mouse over to it and click on it to open the box
If your wirless switch is enabled it should show you that you are or are not connected to any particular network or router
If your wireless switch is not enabled please look through your user manual to find which keys to use to enable it
then in that network box please look for the name of your router or network then click on it then go down to connect
If it does not connect automaticly it will ask you for a password
so then you will have to enter the password that you have given it or look at the base of the router as the password may be the one that is written on it
if it still will not connect please go back up to the network that shows the name of your router/network and go to the left side and click on manage wireless networks delete the network that has your name or routers name theen close that box
then wait a few seconds and windows should pop up a box telling you that wireless network are available please click here
so go back to the network box go up to the name of your network/router that windows have found again
click on it and go down again to click connect and once again if it does not connect within a few mins you may have to enter the password that either you gave it or the no
written on the base of the router
if this does not work then you may have to reset your router
to do this you must use a ethernet cable plugged into the router and your laptop
then hopefully you will have a router user book to tell you what ip you need to type into your browser to enter the router to reset it
some router ip address are 192.168.2.1 or 192.168.1.1
if you cannot find the ip address of the router can you ask a friend to look it up on their internet
hope this has helped you
many thanks for using fixya
and we hope fixya has fixed it for yeh
Posted on Jul 19, 2011
  • 72 Answers
SOURCE: i could not find my
Hi!
You here is a link for the drivers and softwares for your Toshiba Satellite L675D-S7052. Please click this link Toshiba Satellite L675D-S7052.
Posted on Jul 20, 2011
Toshiba Satellite L675d-s7040 touchpad scroll not working
The problem is the sensor pad, cracked ribbon wire, or the ribbon cable is not properly attached to the plug on the motherboard.
Apr 11, 2012 | Toshiba Satellite L675D-S7040...
How can I safely overclock my Toshiba Satellite L675D-S7106
Without changing the CPU and updating the motherboard firmware I don't even know if you can do that as it depends which chip is fitted and how old the firmware is.
Feb 25, 2012 | Toshiba Satellite L675D-S7050 Notebook PC
Satellite L655D-S5093 keyboard removal
This is the User's Manual for the L655-S5098 laptop:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2759985&rpn=PSK2CU&modelFilter=L655-S5098&selCategory=2756709&selFamily=1073768663
Predictably, its useless when performing maintenance such as keyboard replacement, but page 82 indicates that this laptop supports "most USB-compatible [external] keyboards", so, while the chicklet keyboard is down, you can boot and use the system with a workaround USB keyboard.
I could not find an L655-S5093 laptop model on the Toshiba support web site, which is found at http://www.pcsupport.toshiba.com
The closest I could locate for you are these two How-to Guides:
Here's a teardown of the Toshiba L645/L645D laptops:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L645D-L640D/remove-laptop-motherboard-1.htm
Here's a teardown of the Toshiba L675D laptop:
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-L675D-L670D/dismantle-laptop-1.htm
Nov 27, 2011 | Toshiba Computers & Internet
I could not find my computers video card driver.My computers mark Toshiba Satellite L675D-S7052.Can you help me?please
Hi!
Jul 20, 2011 | Toshiba Satellite L675D-S7052 Laptop
Whats the difference between a toshiba L675D-S7100 and a S7107? which is a better laptop
http://us.toshiba.com/computers/laptops/satellite/L670/L675D-S7107/ is the link for the s7107 and http://us.toshiba.com/computers/laptops/satellite/L670/L675D-S7100/ for the s7100
the s7107 is better out of the two because of the better processor and it has a blu ray drive BUT if you dont need the blu ray drive save the 120 dollar difference and get the s7100 as for the price difference you wont notice much if any difference in speed with the processor also on the right of the page look at the ones near the bottom that have the intel i3m processor for around the same price its much better
May 14, 2011 | Toshiba Computers & Internet
What is the difference between a toshiba L675D-S7100 and a L675D-S7107 and which is a better laptop
Hi
Here is the webpages for both models, you can check and choose the best for you
  1. Toshiba L675D-S7100
  2. Toshiba L675D-S7107
Please tell us your impression
Good Luck
May 14, 2011 | Toshiba Satellite L675D-S7100 Notebook PC
I want to buy a recovery dics for toshiba laptop satellite l675d - s7052. But i don't know where it's bought.
I do not believe Toshiba sells recovery discs, instead they have a utility called Toshiba recovery disc creator. Which should already be on your laptop if not download from Toshiba website.
May 11, 2011 | Toshiba Satellite L675D-S7052 Laptop
How can I disable the pinch zoom on my Toshiba Satellite L675D-S7107? When I'm scrolling up or down, sometimes the pointer turns into a black cross with arrows at each end and the text becomes resized. ...
Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
Mar 12, 2011 | Toshiba Satellite L675D-S7107 17.3" Laptop...
Toshiba Satellite L675d-s7016 Laptop Amd Turion Ii Dual-core Mobile Process Logo
76 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
