Question about Air Tools & Compressors
The red knob that controls pressure out of husky 9415349 is stripped
3 Suggested Answers
  • 210 Answers
SOURCE: Hi I have a husky 20g 1.8Hp air compressor model#
It very well may be the check valve. A quick way to check would be to loosen the copper or aluminum line that comes from the top of the check at the compressor. Make sure you have pressure in the tank. Remember just loosen the fitting at the compressor. If air blows out the check valve is leaking. Please be very careful. You are working with a pressurized system.
Posted on Aug 02, 2011
SOURCE: Bostitch 6 gal compressor regulator knob is broken
Call Bostitch At 800-556-6696 and they will send you a free redesign part #27. It was a bad design part and I just did it a minute ago.
Posted on Jul 12, 2010
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
How to replace regulator on husky air scout model 41004
On my air scout the regulator cap, which is threaded to receive the bolt attached to the regulator knob was stripped. It's cheapo metal. I removed that and the knob (which is held onto the bolt with a smaller reverse-threaded screw, and replaced the cap using a larger diameter bolt I place of the knob. Works.
Aug 14, 2013 | Air Tools & Compressors
Husky air compressor repair
Are you meaning that you cannot adjust the regulator to change the pressure output?
Jun 01, 2013 | Husky Factory Reconditioned Electric Air...
My oven wont turn off from the knob it keeps turning
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Mar 03, 2013 | Ovens
Hi I have a husky 20g 1.8Hp air compressor model# 9415349 as soon as it stops running it starts to lose air and has no pressure to the adjustment gauge. do you think it is my check valve from the...
Aug 01, 2011 | Electric Air Tools & Compressors
How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Dec 31, 2010 | Electric Air Tools & Compressors
Just bought a camper. The braking system the guy gave me was for a ford. (Husky Journey HD) I have a Nissan titan (2005). I have been trying to match the wires, but no success. Could you tell me what color...
OK on the truck side, brake controller harness wire colors are:
RED = +12V (Hot at all times, even with truck off)
RED/GREEN = Stop light (Hot when brake pedal is depressed)
BLACK = Ground
BROWN/WHITE = Brake out (variable voltage to trailer brakes, 2v-12v)
RED/BLUE = Dimmer (not used on most controllers)
On the controller side (these are pretty much universal):
BLACK = +12v
RED = Stop light
WHITE = Ground
BLUE = Brake out
Jun 05, 2010 | 2005 Nissan Titan
How do i repair a broken air regulator on a husky portable air
Just to add to the posted advice which would have prevented the repair I'm having to make and the things I'm learning the hard way as I'm fixing the stripped regulator on my H1826F from 2008...
here's the damage:
Other thing that was tricky is getting the cover off the top to get at the guts - most of the holes held screws - easy to get off, but the bottom holes were tricky as the bolts are so far in it's hard to tell what you are dealing with... here's what I found after I broke things (gotta love superglue - it's all better now):
once you get the bolts turning, loosen them till the cover will pull apart and you'll get them both off in one piece, threads intact.
Sep 09, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
157 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
