Question about Electric Air Tools & Compressors
On husky air compressor ,thje valve that controls the outward air on 9415349
I need to replace this part as the plastic knob seems to be stripped.
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
SOURCE: Bostitch 6 gal compressor regulator knob is broken
Call Bostitch At 800-556-6696 and they will send you a free redesign part #27. It was a bad design part and I just did it a minute ago.
Posted on Jul 12, 2010
  • 1388 Answers
SOURCE: I have an older Craftsman Air Compressor and the
It is getting increasingly more difficult to obtain replacement parts for older compressors. If your regulator failed at a fairly high pressure adjustment, say around 100-120 lbs, you could just leave the old regulator in place and add a regulator when needed to one of the quick connects. Purchase a generic pressure regulator from Lowes and add quick fittings to easily connect the regulator or remove when not needed. You could also just remove the old regulator and work-in a new generic regulator in its place. Generic regulators sell for $20 - $40. Good luck with your repair.
Posted on Aug 07, 2010
  • 1388 Answers
SOURCE: How do you replace the regulator valve on a husky
I could not find parts for my husky compressor and had the same problem as you describe. I went to lowes and purchased fittings to draw air out of the safety port. Remove the safety pop valve and install t-fittings to allow you to reinstall safety valve and also a quick connect. If you want to be able to regulate the pressure, install a simple pressure regulator before the quick connect (also avail. at lowes). This remedy is not pretty but sure works great and simple. Problem with husky regulator is stripped thread /knob. Sometimes you can turn the knob if you drain air from tank; this will release the spring tension on the regulator knob.
Posted on Jan 01, 2011
  • 210 Answers
SOURCE: Hi I have a husky 20g 1.8Hp air compressor model#
It very well may be the check valve. A quick way to check would be to loosen the copper or aluminum line that comes from the top of the check at the compressor. Make sure you have pressure in the tank. Remember just loosen the fitting at the compressor. If air blows out the check valve is leaking. Please be very careful. You are working with a pressurized system.
Posted on Aug 02, 2011
How to replace regulator on husky air scout model 41004
On my air scout the regulator cap, which is threaded to receive the bolt attached to the regulator knob was stripped. It's cheapo metal. I removed that and the knob (which is held onto the bolt with a smaller reverse-threaded screw, and replaced the cap using a larger diameter bolt I place of the knob. Works.
Aug 14, 2013 | Air Tools & Compressors
Brand new compressor...air builds in tank but turning the regulator result in no change in the regulated pressure. Tried turning the regulator to make sure it moves freely, and it seems to, but still no...
The regulator has a very strong spring inside causing knob to get harder to turn as you increase the pressure (increase clockwise). If the knob is easy to turn most likely stripped inside. If knob gets tight as you turn then plunger at rear of regulator is stuck. On the back side of the manafold directly opposite the adjustment knob is a small nut housing a plunger. Let out all the air from the tank and remove the nut. Seperate the nut and plunger, lube and re-install. If the regulator knob is stripped you will need to replace the manafold or as a temp fix remove the safety valve (let out air from tank first) and install a tee fitting. On one port of the tee reinstall the safety valve and on second port install quick fitting for full tank pressure (or install aftermarket pressure regulator ).
Oct 28, 2011 | Porter Cable C2002 150 Psi 6 Gal...
Can I adjust the tank pressure on a Husky 1506 compressor. pop off keeps engageing, so I need to adjust so that compressor shut off automatically
Before you change any parts, check that the pop valve is not faulty. Look closely at the pop valve to read set release pressure. If the valve is releasing before marked reading, replace valve instead to one slightly higher. The pressure may or may not be adjustable at the switch (need to replace the switch) depending on switch installed at the factory (parts list does not give enough information). If your switch has a remove-abel cap with adjustment screws/nuts, post again with model number of switch for info on adjustment. Good luck
Oct 06, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Hi I have a husky 20g 1.8Hp air compressor model# 9415349 as soon as it stops running it starts to lose air and has no pressure to the adjustment gauge. do you think it is my check valve from the...
Aug 01, 2011 | Electric Air Tools & Compressors
I have a husky air compressor model WL651004AJ will only build up to 50 psi and compressor keeps running any advise som one could give me to whats wrong.
You can inspect the check valve by removing it and pulling on the small plastic pin sticking out of the middle of the tank side. It should spring back under fairly light tension. Also visually inspect and clean out with a dry q-tip the brass screen on the inlet site. Seal back with ribbon dope.
If this looks ok, remove the 4 bolts holding the head on. Keep all of the sandwiched plates together in order so they go back in easliy. The cylinder sleeve will come off with this stack. Look at the plastic surround on the piston and the inside of the cylinder. In my case, this was eaten up from too many hot summers and cold winters in the garage. The rubber/plastic had hardened and eaten part of itself away. To replace the entire piston assembly on the WL651004AJ, you'll need to get part number WL211000AJ, which in some books is superseded by WL211000SJ.
If the cylinder is scored (meaning that by scraping your fingernail against the lines in it, you catch the nail) then you're probably better off replacing the whole cylinder unit.
Jan 18, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How do you replace the regulator valve on a husky pancake air compressor? Mine just spins and will not allow me to get air to the hose
Dec 31, 2010 | Electric Air Tools & Compressors
Metal pieces in piston chamber
SOUNDS LIKE THE VALVES IN YOUR HEAD ARE NOT CLOSING ALL THE WAY OR HAVE FALLEN APART. THEY ARE MOST LIKELY ARE REED VALVES, THIN STRIPS OF METAL THAT OPEN AND CLOSE WHEN THE PISTON MOVES UP AND DOWN. MAKE SURE THEY ARE ALL THERE AND ARE OPENING AND CLOSING ALL THE WAY. WHEN THE PISTON GOES DOWN IT CLOSES ONE SET AND OPENS THE OTHER AND VISE-VERSA. WHEN YOU REMOVE THE HEAD MAKE SURE YOU MARK IT SO YOU CAN PUT IT BACK LIKE YOU FOUND IT - NOT TURNED AROUND OR FLIPPED OVER. SERIOUSLY MARK IT !
HOPE THIS HELPS. JODY
Apr 11, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Air Tools & Compressors Logo
24 people viewed this question
Top Electric Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Electric Air Tool and Compressor Expert? Answer questions, earn points and help others
