Question about John Deere Garden
John deere 332d oil pressure waring light will not come on when keys on the bulb is good
Oil pressure light will not come on the bulb is good
ButtFuzz
  • 463 Answers
SOURCE: IJohn Deere whinning noise
Is the device that lowers or raises the loader a hydraulic piston type device, or more of a hydrostatic type device? Whining noises are not uncommon with hydrostatic devices...
Posted on Mar 26, 2009
jimmy nutron
  • 132 Answers
SOURCE: I have a 1968?? 2020 john deere. The hydraulic
make shure none of your hydrolic cylenders are extended and fill it up till you can stick you finger in there and it barley touches if you do this when cylenders are extended you will over fill it.
Posted on Jun 04, 2009
  • 302 Answers
SOURCE: change oil in riding lawn mower
look at the side of the engine down low. There should be a pipe plug screwed in that has a square head. Put a drain pan under the area and remove this plug and the oil will drain out. It's best if the engine is warm. You should get 1 1/2 quarts of oil out of it. Let it drain for about 5 minutes and then re-install the pipe plug. Add 1 1/2 quarts of 30W oil and then cut the grass !
Posted on Aug 27, 2009
Testimonial: "Thanks. It worked!"
  • 8404 Answers
SOURCE: John Deere 4410 three point hitch will not raise.
Im sorry, I thought you said you changed the oil. My thought was that perhaps the hitch might have bled down during the oil change. That happens occasionally with the tractor I service at work.
I hope you find your trouble. If you could let me know the answer, id appreciate that.
a
Posted on Sep 25, 2009
rwvanlue
  • 486 Answers
SOURCE: John Deere Gx75, kawasaki 9hp motor- oil in carb!
A very common problem with the GX series with Kawasaki engines. The carburetor 'inlet needle' sticks open and fills the crankcase with fuel. When checking the oil, it can be difficult to see the gasoline and the level appears to be OK. Remove the dipstick and smell the oil, you may detect a gasoline smell. Also, drain the oil, and you may find much more fluid than you expect.
The solution on newer mowers was to install an 'in-line' shut-off valve to keep the fuel from syphoning into the carburetor. The inlet needle and seat in the carburetor is NOT replaceable, so a new carburetor is the ultimate solution, but VERY expensive. Installing and using an in-line shut-off valve is more affordable.
Also, this situation is common when machine is transported on a trailer, as the bouncing causes the needle/seat to leak. When transporting, always turn off the fuel supply to the carburetor.
Posted on Nov 08, 2009
Def pressure extremely low on a 848L john Deere Skidder
check for problem pressure relief valve or valves passing oil back to reservoir
Jun 02, 2016 | John Deere Garden
Where do i locate oil pressure sender on a john deere 445
Not sure but if you follow the sure from the oil gauge it should lead to it also match the color coding..good luck..
Feb 28, 2015 | John Deere Garden
Crankcase pressure
if under warranty take back to authorized dealer, check threads or attaching method used for filler cap to be in good condition, if good check crankcase vent tube for kink or obstruction.
Sep 01, 2014 | John Deere Garden
332d john deere skid steer why is it blowing white smoke
i do not know what a skid steer is. If the motor on anything is blowing white smoke there is water getting into the combustion chamber which is bad bad news means head gasket,intake,cracked cylinder those patch jobs in the bottle are exactly what they are patch jobs it will hurt you pocket book a lot but if you want to keep it it is past the point of patching.
May 17, 2014 | John Deere 420,1020,2010,2020,2510,2520...
John deere js40
when you changed the oil was the mower turned on the side? if so oil gets on the sparkplug. remove and clean then your good to go.
Jun 03, 2013 | Garden
We fixed an engine of john deere 3020 diesel model 1966. All things it's ok. We took a watch which pressure the oil engine instead of the short lamp. When the engine is working and is cold, the pressure is...
I have been working on the my John Deere 3020 and can not get it to start. I had the starter rebuilt and have gone through everything I can think of! Any help would be great
Feb 18, 2011 | John Deere 3020 Gas & Diesel Tractor...
Need to locate the oil pressure sending unit on a John Deere 1010 Gasoline tractor
looking at engine on oil filter side--the sender is on the left side of oil filter and to the right of dipstick in between both
Mar 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
132 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
