Question about Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black
Saeco Sirius Brew Unit Switch
Hi Guys, I have here a problem with my Saeco Incanto Sirius, in which the brew unit switch which is located on the front panel of the machine after taking the brew unit out, resulting in the machine not detecting the brew unit anymore. I have taking the back panel off to confirm that the switch has broken off, tried to put it back in place but with no luck as there is no room from the back, so my question is: Is it possible to access this from the front and how can I take the front panel, shown in the photo. Your help is much appreciated.
3 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Incanto stuck in the middle of brew process
No you will have to let the machine center itself, on the part that is out, if you look carfully you will noticw a small notch, and in the machine, if you inset a small screwdriver you will hear a click, that is the microswitch, there is one for the the door, that one will have to be pushed then the others at the same time, because if one of them is not engaged the machine will not do anything.
Posted on Nov 29, 2009
EsWorld
  • 1618 Answers
SOURCE: I have a Saeco Incanto S-class sirius machine.
Brew group blocked is normally displayed when there is no water flowing through the brew unit. Remove the brew unit and use a small screwdriver(make sure machine is off and cooled), then gently lift up on cross section fitting on white plastic valve inside the machine, if water flows out it works, now we will plug in machine keep brew unit out and turn it on and press fitting in again, if water flows and pump kicks in and water flows out from valve and not under machine you are good, The coffee grind might be too fine and needs to be adjusted to coarser.
Posted on Jun 28, 2011
How to change brew group rubber orange gasket on saeco Incanto Sirius
google for USA-Incanto Rondo SBS-RS, E74088 Rev. 03.pdf
it has an exploded view of the brew unit. partsguru has the part.
Jan 30, 2013 | Saeco Vienna SuperAutomatica Coffee...
I have a Saeco Incanto S-class sirius machine. Message displayed, "Brew Group Blocked", so I purchased a new Brew Group Unit, when I installed it, got the same message. when turned on, I can...
Jun 28, 2011 | Saeco Incanto Sirius Fully Automatic...
I have the Saeco Incanto Sirius. It makes grinding noises but does not dispense coffee, just hot water.
The grind might be too fine or the grind chamber is blocked, remove brew unit and check the door covering the grind chute to make sure it is clear, or adjust towards coarse about 2 numbers.
Apr 13, 2011 | Saeco Incanto Sirius Espresso Machine
Saeco S-class Incanto Sirius brew unit stuck
Try running the clean cycle again, that sometimes will help the machine to reset.
Sep 15, 2009 | Saeco Incanto Sirius Fully Automatic...
Saeco Incano Sirius brew unit blocked
It is possible that the problem is in the CPU board, check the board, and the capacitor next to the pump.
Jun 04, 2009 | Saeco Incanto Sirius Fully Automatic...
How to find & clean upper filter -Saeco Incanto Sirius brew gp?
If you are holding the brew unit in your hand with the words "Press" facing you, turn the unit right about 90°, and down 90°. Look above the dregs slide, you will see the filter screen under the red gasket.
Apr 02, 2009 | Saeco Incanto Classic Espresso Machine
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
SAECO Incanto Sirius Brew Group
When you remove brew unit look on the back you will notice a small latch near the top, make sure it is in the up position.
Feb 03, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Sirius Incanto loud noise
When you power on the machine, can you hear the machine do the self test?
is there a crack sound when the brewing unit is in work?
Aug 01, 2008 | Starbucks Saeco Italia Digital Barista...
Saeco Incanto Sirius Fully Automatic Coffee Maker Stainless/Black Logo
51 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
