Question about Philips Magnavox 51MP392H Rear Projection Television
No power TV was working fine then lost picture and sound no power would not turn back on replaced fuse closest to cord now power button lights up but still no picture or sound any idea's ?Thanks
  • 1 more comment
  • Anonymous Jan 01, 2008
    philips magnavox 51mp392h/17 rear. power light up,no sound, no picture........please help
  • m_tenhet Aug 23, 2008
    I just got this tv. When we turn it on, the power light comes on, but there is no sound or picture. could someone please give a little better desription on what I could possibly do to fix the problem? There are 3 red wires that run the lamps, one was plugged in and the other 2 were not.We plugged them and still nothing. Would appreciate any and all help. Thank You. Shane
  • Anonymous Feb 09, 2009
    power light comes on but no picture or sound. model 51mp392h . was working perfectly. appr. any help thanks
Brand, and size please? Most problems come from either the power supply, or deflection circuits.
Posted on May 27, 2007
SOURCE:
Our Proscan TV was working just fine then suddenly just lost power, there is power in the cord but the light won't turn on, is there a reeset button or fuse?
No the TV has failed. most likely the main PCB has failed or is shorted. To repair this will be close to the cost of a new TV at current prices.
Aug 19, 2016 | Proscan Televison & Video
Why did my turntables lose power. not working at all.
There two fuses in the turn table and I've heard of the power button going bad I have one with the same problem that's been collecting dust... Stick with technics...
Jul 19, 2014 | Vestax Pdx2000 Direct Drive Turntable...
Element (FLX-3210) I lost sound when I unpluged my pc plug from my laptop to the TV. Then I went to the tv output which had picture on the screen but no sound. Once the power was turned off the tv it...
The tv turn on now have power and LED power light indicator is on and solid green?Yes,than it is the main Tuner signal board had a short some where and it is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Nov 29, 2010 | Element Electronics FLX3210 32 in. LCD TV
Sound but no picture. menus work.
I had the same problem. In the menu, the image button was grey, and could not be hi-lighted, and the screen stayed blue. I was using the AC power cord. I plugged in the DC power cord instead, and it "woke" the unit up. I switched back to the AC power and it works fine. If you don't hve the DC cord that came with the TV, try andy 12 volt dc output cord with a positive tip.
Jul 12, 2009 | Polaroid 15'' HDTV Monitor FLM-1511
No Picture, No Sound While Watching
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
LCD TV TroubleshootingThe defective LCD TV may have the following common symptoms:
Symptom: No picture on screen but LCD TV still has sound.
Solutions: The problem is cause by defective inverter. Replacing ivnerter will solve hte problem. Symptom: Screen flash on and off between 1/2 to a few seconds, but power indicate light stays on and TV still has sound.
Solutions: The problem is cause by defective inverter. Symptom: Blue Screen but no picture
Solutions: The problem is cause by defective Main Board(AD Board). In some cases, this problem may cause by the defective Screen Controller board. Thsi board is mounting on teh back of LCD TV Scree. Symptom: Power light stays on but no display and sound
Solutions: The problem is cause by defective Main Board(AD Board) or Power supply board. Symptom: No Power or Power indicate light does not lits
Solutions: The problem could cause either by defective Power supply board or defective Main Board(AD Board). Symptom: Screen is half dim and half bright
Solutions: The problem is cause by defective LCD Panel.It needs to be replace.
Hope it may help you;
Regards;
VOTIT
Jan 29, 2009 | RCA L37WD250 37 in. LCD HDTV
Power problem
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Jerry
Nov 07, 2008 | Philips 36PT842H 36" TV
Need Help big screen turns on thens goes off
a tv has two components, firstly a power supply produces high voltage to trigger a line transformer, in turn a transformer produces smaller voltages. firstly check if the ht is constantly been produced from a supply, if this is there than go to a line transformer, and check voltages at the output.
Sep 10, 2008 | Panasonic PT-61HX40 61" Rear Projection...
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Power button Flashes
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Philips Magnavox 51MP392H Rear Projection Television Logo
169 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
