Question about Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator
Amana model ARB2557CSR, defrost timer replacement instruction and video
Is there a video showing how to replace the defrost timer in an Amana model ARB2557CSR?
    Top Expert:
  • Amana Master
  • 9,472 Answers
See other post.
Posted on Nov 07, 2012
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Amana Refrigerator SCD22JL
Good trouble shooting TD, the evap fan runs through the defrost T-stat. Change it out and you should be set. Catriver.
Posted on Aug 15, 2007
james3751
  • 614 Answers
SOURCE: I've a Amana ARB1917 and I want to know where is
The defrost timer for the unit is located under the fridge in front or back. Depends on model. A few put them inside the fridge. Russ
Posted on Jul 18, 2009
  • 401 Answers
SOURCE: Defrost timer went bad. How do I manually bypass the timer?
IF ITS A DEFROST TIMER AND NOT A BORD THE WIRES ARE HEATER POWER COMPRESSOR THEN NEUTRAL IS ALONE.
I I I I
HPC N
GOOD LUCK!
ERIC
Posted on Jan 17, 2010
Testimonial: "I connected a jumper from the compressor to the power and I'm back in business. I'll have to find a new timer in the morning. Thank you!"
  • 949 Answers
SOURCE: amana bottom refrigerator bx20rw, how do i replace
This link will show an exploded view of the area. Part number 6 is the defrost thermostat. Cut and paste into your browser.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=273&diagram_id=810195#d810195
Basically you need to empty the freezer, remove the drawer and back panel, unclip the thermostat and replace, there are two wires and should be the same on the new one, use caution not to damage the evaporator coils.
Posted on Apr 18, 2010
Replying to Richaed Roth - Amana ARB2557CSR Defrost timer. diagram from online source shows timer on the inside of the frig box near the lights. I've not done anything yet to verify te location a
OK, you can open the cover. Here is the part if you need it.
Here is a diagram if you should also need it. It is number 12 on the diagram. Let me know if you need anything further. I forgot what the original question was.
Nov 07, 2012 | Amana Refrigerators
Amana ssd21sw stop cooling freezer side frost in rear wall any sugestions
Defrost cycling problem which will affect cooling the fridge compartment by struck the freezer fan's function.To solve defrost problem:
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on,replace the defrost timer and defrost thermostat. If the heater itself is bad,replace it. Thanks and hope helpful.
Feb 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Our Amana has a reocurring defrost problem where the back of the freezer clogs with ice every three weeks. Is there anything we can do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
My Amana refrigerator defrost timer is supposed to cycle every eight hours. Instead it takes about 14 hours to cycle around back to the defrost mode. The defrost mode does last for the proper 20 minutes....
Relax, some people exagerate was all I was saying.
Anyhow, go to a good parts store and ask for a Supco EDT (Electronic Defrost Timer) replacement as they are more reliable and not much difference in price.
May 15, 2010 | Amana ABB1921DE Bottom Freezer...
Amana br18v1w bottom freezer iced up will not defrost
rotate defrost timer till compressor off
does it defrost if no then
jump out defrost t-stat (round disc)
if starts to defrost Replace defrost t-stat
if yes replace defrost timer if not turning
Oct 24, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
My in-laws Amana ATB1832AR Top Freezer has stopped cooling. It was purchased 7/1/2005. Is there an inline fuse for the compressor that may have gone out?
you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, ie defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
Aug 13, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Fan is not working and fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Light is on, fan runs, compressor will not come on, compressor has never made a noise. Amana Distinctions model ARS2665A S/N 0010242568..side by side refrigerator freezer with ice maker.
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Mar 19, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana model B136car# seems not to be defrosting
There are only two elements in that defrost system; the heating coils themselves and a timer; I have lost both of these (not simultaneously) on occasion.
The timer is not costly and not that difficult to replace.
The heater coils are another matter; some DISassembly is required.
Since it is unlikely that coils in both the freezer and refrigerator are not likely to fail at once, it looks like the timer is at fault.
Jul 19, 2008 | Amana Refrigerators
Amana ARB2557CSR / ARB2557CSL Bottom Freezer Refrigerator Logo
179 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
