Question about Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera
How do i set up blue tooth
It said it is aptional
    Master:
  • 689 Answers
You will need the owners manual for it, Everry manufactur is different in the way you have to set it up. Ihate to tell you.
Posted on Nov 06, 2012
How can I setup blue tooth on the tablet to talk to my cell
Go in to setting look for blue tooth press it, go to your phone settings and look for the same thing on both units press Pair with device. At this time the blue tooth should turn on, blue tooth then should allow both units to hook up with each other FYI pass word should be 0000. if you need it
Mar 14, 2015 | PANDIGITAL SuperNova
I have HP Pavilion DV6 model no WW146AV.How to activate bluetooth in this model
If your particular model of HP has the blue tooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the blue tooth, as well as the wireless LAN. A blue tooth icon should appear in your task bar near the clock when blue tooth is turned on. ELSE
You have to go into start, then all programs, then look for the blue tooth connection setting. Hope this helps.
Go into start, then all programs, then look for accessories, the find blue tooth wizard. You can switch it on via that.
NOTE : BE SURE THAT YOU HAVE A BLUE TOOTH IN YOUR MODEL BECAUSE SOME OF THE MODELS DON'T HAVE IT.
Mar 21, 2011 | HEWLETT-PACKARD Hewlett Packard Hp...
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
Feb 21, 2011 | Plantronics Explorer 230 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
I wanne play my music via bleutooth but i dont find how i need to do dhat
Bluetooth technology makes possible sound transmittion to devices without the wired connections from the device out puting the sound out put gagdget. The bluetooth technology would only perform with devices that have that functionality. For example, once the device acquired on retail has indication of being developed to handle blue tooth technology also known as wireless connectivity, simply use the device settings to enable bluetooth functions. keep in mind that, blue tooth technology workswith only blue tooth gadgets. for example, a blue tooth phone requires a bluetooth ear piecees before functionanlity can be assumed with the settings. Once decided that each devices wanting to perform a blue tooth connectivity are designed for that function, use the settings function either on the menu area to set the wireless connectivity like also known. Remember, wireless cannot access another device that does not provide signals. in other words, once each devices setting are enabled, a signal should appear maybe blue light indicating blue tooth signal has been detected.The functions of thead set requires attempting to listen to any sound during the set up process. The entire process of setting bluetoothh should not be tasking.
checks to perform 1. make sure each device is designed to handle wireless signal recognistion also known as blue tooth technology 2. the devices may need to be set to allow access from the particular devices, a function that was design so that not all signals could be received by your heard piece. In the sitaution of which absence could be noice generation interfering the receiver and possibly preventign setthings
Dec 04, 2010 | Samsung S3650 Corby / S3650 Genio Touch...
I WOULD LIKE TO SET UP A BLUE TOOTH CONNECTION
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 20, 2010 | LG Shine CU720 Cellular Phone
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
Camera phone bluetooth
-First you must "enable" your blue-tooth on your handset.
-Secondly you need to make set your blue-tooth feature to "always visible" (this setting is within your blue-tooth application).
-Third, you need to search for all available blue-tooth devices within your range.
If the kiosk shows as an one of the available devices, try to pair with it. (Note: If your blue-tooth feature prompts you for a pass-code, enter 0000.This also applies if the kiosk prompts for a pass-code.)
If you have followed all these guidelines and you are successfully paired with the kiosk, Congrats! At this point, you will need to send the kiosk all your current pics. Your blue-tooth should give you an option to send and what information your a restricted to send.
Hope this can be of any assistance. Thanks!
Mar 19, 2009 | Cell Phones
Can't set up blue tooth
Strangely enough I went to the website where I purchased the blue tooth. It recommended holding down the button for 8 seconds as opposed to the 3 or 4 listed in the manufacturer's instructions. When I did this it found my phone. The pairing worked fine and now so does the blue tooth.
Jan 15, 2009 | LG Vu CU920 Cellular Phone
Bluetooth problem
I have an lg sprint muziq and I cant get my blue tooth headset connected. The phone can't read or see the blue tooth head set
Jul 01, 2008 | Motorola Mobility HS850 Consumer Headset
Crown Ouku 7 Touch Screen 2 Din Car Stereo Dvd Player Radio Bluetooth Ipod Tvcamera Logo
418 people viewed this question
Top Crown Car Audio & Video Experts
Dennis Key
Dennis Key
Lawrence Oravetz
John
John
Are you a Crown Car Audio and Video Expert? Answer questions, earn points and help others
