Question about Nokia 1600 Cellular Phone
Hello sir, i have Nokia 1600, made in Hungary, Type Rh-64 and IMEI -354529/01/827529/7 im lost my security pass word so please tell me, how to change my pass word.
  • 365 Answers
The security pas if lost it can be changed from the customer centre (nokia care ).try to contact them
Posted on Jan 05, 2009
Nokia 1600 restore factory settings code
You can format your Nokia 1600 device by typing:
* + 3 + call + Power on.
Before the device is reset, you need to provide
the lock code. The default lock code is 12345.
If it is not working try this code
*#7370# in standby mode.
Dec 30, 2012 | Nokia 1600 Cellular Phone
In Nokia 1600 type RH-64 i forgot security code and now cannot reset call timers, would you pls help?
Good Morning:
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Dec 08, 2012 | Nokia 1600 Cellular Phone
Hi alian i have forgotten the security code of my NOKIA Model :- 1600 Type :- RH-64 The serial no.( IMEI CODE ) is 357679/01/8022543/7 Please help me out of this, thanks. Additional Details Hi...
The Problem is with your 1600 Software just Flash it (renew mobile software) it can be done in Nokia Car Please Visit your Nearest Nokia service center they will do it,
Regards,
Harish
// Feel free to vote this answer with 4 thumbs up //
Jun 16, 2011 | Nokia N73 Cellular Phone
I forgot my security code for nokia 1600 type RH-64 with IMEI 359377007718728.Please help me to set my new security code
You may kindly note that the default security code for all Nokia handsets is 12345. In the event the security code is changed and you are unable to recall it, then the phone needs to be reset. You may kindly note that the security code can be reset at any Nokia Care Centre. Kindly be aware that there will be a service provision fee associated with this service, as it is a non-warranty procedure.
You may kindly note, once the phone has been reset, all data in the mobile will be lost. I recommend you take along the proof of purchase/receipt while visiting the Nokia Care.
Good Luck.
Thanks for using FixYa.
Jan 08, 2011 | Nokia 1600 Cellular Phone
I lost my security code for my nokia 1600 rh 64
hello
1_ can you save your formation in other phone .
2_that code format your phone for Nokia only
3_ *#7780# if you know your security numbers use it. if you don’t know it use 12345
4_ other numbers *#7370# and the security n ......
and look if the problem is solve it
because after this . you have like a new mobile
Jan 26, 2009 | Nokia 1600 Cellular Phone
Lost cecurity code
Yesterday after searched around, finally i found a site contains codes for all type Nokia phones, such as: latest firmware, unlock, security code, hidden secret, and more.
If you need, can find them here: http://nokia-tricks-codes.blogspot.com
For all Type Mobile Phone here : http://mobile-secret-codes.blogspot.com
Or check this also
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal strength, better signal reception. It also help if u want to use GPRS and the service is not responding or too slow. Phone battery will drain faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart. Increase battery life by 30% because phone receives less signal from network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user groups) to 00000 and ure phone will sound the message tone when you are near a radar speed trap. Setting it to 500 will cause your phone 2 set off security alarms at shop exits, gr8 for practical jokes! (works with some of the Nokia phones.) Press and hold "0" on the main screen to open wap browser.
Thanks.
Jan 05, 2009 | Nokia 1600 Cellular Phone
Help me,will you?
my phone is 1600 with imei 357953004434766
Oct 07, 2008 | Nokia 1600 Cellular Phone
PLZZZZ BRO HEPL MEE
The most common security code de-fault is 12345
I hope ... it is worth trying this (When u have not changed it)
... I don't think that Phone security code is related to IMEI code :)
If this does not work...try the nearest service centre / dealer for a reset...They do it at a nominal cost
I hope that this solves your problem
Bye
Have a nice day
May 10, 2008 | Nokia 1600 Cellular Phone
NOKIA 1600 IMEI ???????????????
yes sir' JAF can solve that prob.
by using RPL logs...
Jan 09, 2008 | Nokia 1600 Cellular Phone
Nokia 1600 Cellular Phone Logo
79 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
