Question about Canon PowerShot G9 Digital Camera
Video playing in fast forward with no sound
Canon powershot g9 is playing video in fast forward with no sound... how do I fix this? thanks!
  • prounce Feb 04, 2009
    Recorded video plays back fast on the camera and when downloaded to the computer.
    This didn't happen initially, started happening and now doesn't happen.
    Older videos that did it still do it however and it would be nice to fix them.
  • 4 Answers
This is a really simple problem and easy to solve.  Unfortunately the videos you've recorded cannot be changed back because they have been recorded in Time Lapse mode.
With the camera switched on in Video Mode turn the control dial on the back (this is the dial to the right of the LCD screen).  This will change the settings from TIME LAPSE to STANDARD.  There are actually 6 different modes but the best one for normal videos is STANDARD.  There is a HIGH RESOLUTION setting,  however these record fewer frames per second (fps) so whilst the quality is better per frame,  there are half the amount of fps so the the movie will look at bit jerky.
It's really easy to accidentally twist the dial when holding the camera,  so always check the icon in the top right of the LCD before recording to make sure its just a yellow camera in a yellow square.
This should be problem solved for all future recording.
Posted on Feb 04, 2009
  • Colleen Jul 13, 2012
    Great advise. I had the same problem and this was the instant fix to my problem. Thanks for taking the time to answer.
My canon g9 is recording in fast forward. How do i get to the standard mode? step by step help please.
While in video mode, turn the wheel on the right of the screen and you will see that you accidentaly had the camera's video setting on time laps instead of standard.
Jan 31, 2011 | Canon PowerShot G9 Digital Camera
My g9 was playing video clips very fast. i changed the setting back to "standard" and can record/play new videos correctly; however, the video clip that i previously recorded before i changed the setting...
I believe the setting you changed set the RECORD method, not playback. The video is recorded that way. There are some Video software out there that can rerecord a video at a slower pace, but do you want to spend the money? Try Ulead.com for a low cost program.
Apr 17, 2010 | Canon PowerShot G9 Digital Camera
Movie plays too fast
if you can upload your movie to utube and then post a link, it can be easier to diagnose.
Digital cameras were designed for still motion, not full motion,. its a feature they put on and doesn't perform very well. If you want higher video, i recommend using a video camera.
Jan 20, 2010 | Canon PowerShot G9 Digital Camera
Video records at high speed
You need to change your video settings. You have it set for time lapse. Turn your camera to the video mode on the top of the camera and then turn the dial on the back of the camera to the size of video you desire.
Aug 07, 2009 | Canon PowerShot G9 Digital Camera
Video Playback in fast mode (canon ixus 80)
Oh my, sounds like you accidentally recorded in "Time Lapse" mode (one of the specialized video features of your camera). Unfortunately, there's no way to convert the already taken video back to "Standard" video with sound, I'm sorry. However, you'll obviously need to set your camera back to standard mode for future videos. Press the "Function" button while in video mode. Then press left/right to select "Standard" video.
Jul 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
VIDEO STARTED PLAYING BACK ONLY IN HIGH SPEED W/O VOLUME,,,,,,,CHANGED SPEED OUT OF NOWHERE.....PLZ HELP! I'M USING CANON G9
I EASILY FIX'D THIS PROBLEM & FOUND OUT I CAN DO SOOOOO MUCH WITH SHOOTING VIDEO'S! I DID A GOOGLE SEARCH & CAME ACROSS THIS ADVICE.......TURN THE TOP DIAL ONTO VIDEO ON TOP OF CAMERA. THEN TURN DIAL ON RIGHT SIDE & YOU WILL SEE DIFFERENT SCREENS SUCH AS BLK & WHITE, VIVID COLORS, FAST OR SLOW SPEED; I TURNED MINE TO AUTO & PRESSED FUNC BUTTON IN CENTER OF WHEEL & I WAS BACK TO SHOOTING IN NO TIME........HOPE THIS HELPS!!
Jun 20, 2009 | Canon PowerShot G9 Digital Camera
Every time I try to play back a video, it goes super fast and I don't know how to slow it down!
Are you sure you have not recorded the video in time-lapse mode? Could be worth checking. Once in the Video setting, you can use the thumb ring to change video mode - one of these modes is normal and one is time lapse (there are five or six others).
Apr 13, 2009 | Canon PowerShot G9 Digital Camera
Video too fast during playback on my Camera
I have a Powershot SD1000 and it should be similar.
When the video plays very fast it was probably filmed in Timelapse mode( which fast- forwards the video) When you are in video mode press the SET Button and set the camera to Standard mode
Sep 19, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Problem w/ canon g9 camera
Make sure that you're not on timelapse, it should be standard to do a regular playback.
Aug 04, 2008 | Canon PowerShot G9 Digital Camera
I have a canon SD 580. When I playback the video clip it's always in fast forward mode and I can't play it normal speed. Any help?
Make sure you are shooting your movies in "Standard" mode. If you have the mode set to something else, especially "Time Lapse", the playback may not match 'natural' motion.
In any case, you can control the speed of the playback. When you first enter the movie playback mode, there should be a movie control bar along the bottom of the LCD. Instead of the "Play" button, select the "Slow Motion Playback" button (single arrow with single bar next to the normal Play button), and control the speed with the left or right arrows on the multi-controller.
May 02, 2008 | Cameras
Canon PowerShot G9 Digital Camera Logo
1,427 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
