Question about Maytag MER6772 Gemini Electric Kitchen Range
Maytag MER6772BAQ oven temperature varies 24 degrees in the upper and 53 degrees in the lower in the
What is the acceptable temperature range for the ovens in this electric range.
  • 1462 Answers
SOURCE: Maytag MER5775Q Electric Kitchen Range
heating elements are usually good or failed with nothing between so unlikely to be the element. problem probably lies with the thermostat. to check, bypass the thermostat and check the oven gets really hot.
Posted on May 18, 2007
fridgetech
  • 473 Answers
SOURCE: MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Posted on Nov 18, 2007
huuum
  • 750 Answers
SOURCE: oven lights will not turn off, Maytag gas double oven range Prec. touch 750
Hello bohlke75,
Welcome
You said, After cooking in the upper oven today, my wife noticed that both oven lights were on. I tried to turn them off but the oven light button just beeps when activated. I individually tried the plunger switches on both doors but that did not work either. You also unplugged the stove with the hope it would cancel the lights but they came right back on when i plugged it back in. You assume it is something in the touch pad since both lower and upper lights are affected.
Did you leave the plug out for 5 minutes or just do it quickly?
if it only happens on one door then the plunger switch is bad!
if it's both doors then you have a button or control problem. Service can give you a true diagnoses with out the cost of swapping parts randomly!
If it was the plunger you may have been able to get away with a do it your self repair!
Let me know how you do
Thank You,
Huuum
Please remember to leave a rating!
Posted on Oct 16, 2008
SOURCE: Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Posted on Dec 04, 2008
SOURCE: electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Posted on Jan 18, 2009
Maytag gemini electric double oven, f1-f2 codes both ovens, tested both temperature sensor probes, both at 1100 ohms, called Maytag, said might be control board. Anything else to test before spending $$$...
make this test and fix it. God bless you
F1:-1 Runaway Cook Upper oven Test the temperature oven sensor replace if necessary F1:-2 Runaway Cook Lower oven Check the temperature oven sensor replace if necessary
Nov 04, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini range and the bottom oven is off by 25 degrees. When I set it for 350 it only gets up to 325 actual temp even though the digital display says 350. Is there an adjustment or do I have...
Sorry to read about your problem, I hope this helps you out.
OVEN TEMPERATURE ADJUSTMENT
If you think the oven is operating too cold or hot, you can adjust it. Bake several test items and then adjust the temperature set- ting not more than 10° F at a time.
To Adjust: 1. PresstheBAKEpad(upperorlower
oven) and enter 550° F.
2. PressandholdtheBAKEpad(upperor lower oven) for several seconds until TEMP ADJ is displayed.
3. PresstheAUTOSETpad-eachpress changesthetemperatureby5°F. The control will accept changes from -35° to +35° F.
4. Iftheovenwaspreviouslyadjusted,the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F.
5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Maytag MER6772 Gemini Electric Kitchen...
The actual temperature (as measured by repairman's device) is 20 to 30 degrees lower than indicated on the control panel. Should the control panel be replaced in a 7 year old range or should the range be...
You can adjust the bake average temp +/- 35 degrees this is called calibration.
Here's How:
To Adjust: 1. Press the BAKE pad (upper or lower oven) and enter 550° F. 2. Press and hold the BAKE pad (upper or lower oven) for several seconds until TEMP ADJ is displayed. 3. Press the AUTO SET pad - each press changes the temperature by 5° F. The control will accept changes from -35° to +35° F. 4. If the oven was previously adjusted, the change will be displayed. For example, if the oven temperature was reduced by 15° F, the display will show -15° F. 5. When you have made the adjustment, press the CANCEL pad and the time of day will reappear in the display. The oven will now bake at the adjusted temperature.
Do this first and you will be back to normal. If your using a oven temp. checker make sure you let the oven cycle for awhile. Preheat should take about around 10min. Remember 350deg is an average temp.
Have a great day!
Dec 07, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Amana oven will not hold temperature
First check the temperature probe if that checks out good the problem is the bake element is failing. Here is a couple links on checking and replacing these parts
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenelementvideo.html
Jun 28, 2010 | Amana AER5712AAS Electric Kitchen Range
Recalibrate maytag over MEW5627
Press BAKE pad.
Enter 550 on the digit-pad.
Immediately press and hold BAKE
pad for 3 seconds.
Oven can be adjusted from -35 to +35
degrees in 5-degree increments by
pressing AUTOSET pad. To avoid
over adjusting the oven, move
temperature 5 degrees each time.
Wait 4 seconds for the data entry
timer to expire to accept the change.
Temperature adjustment will be
retained even through a power failure.
May 14, 2010 | Maytag MGS5770 Gas Kitchen Range
Heat in lower oven will not exceed 185 degrees
Several possibilities:
1. Bake/broil elements are bad - can you see them glow red?
2. Temperature sensor is out of wack - does the temperature displayed agree with the actual oven temperature? The sensor can be tested by measuring its resistance.
3. If the elements and sensors check out and the oven "thinks" it is hot when it's not, then it is probably your control board. In this case we may be able to help you, we repair these at www.fixyourboard.com.
Sep 30, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have to adjust my oven temperature with an oven thermometer. I have to set the oven higher to get to the temperature I want. It's sometimes as much as 100 degrees lower than the setting. To get it to 350...
Oven temp sensor failure, possible control board problem. Unit thinks its a different temp. sensor connects directly to control....suggest you to call maytag cust service....sometimes they will assist with parts
Jun 09, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6772 Gemini Electric Kitchen Range Logo
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
