Transfomer Mains for Eagle Amp TPA 40 - Audio Players & Recorders
Cheat codes for minecraft
To teleport directly to them, type /tp and the player's name with a space in between, EX: /tp minecraftdude. Some servers do not allow this, so you might have to tpa request /tpa, and they have to accept it. Some servers allow both, some one, and other neither.
Jul 10, 2014 | Android Apps
Bose 901's
yes u can use a KT88 tube amp , or BTW-2 amp for this da mc34a..this will work good, and you can buy this in e bay that would be cheaper.
You may also want to look at http://www.cattylink.com.
Dec 08, 2007 | Bose 901 VI Main / Stereo Speaker
What is causing a slight hum on my eagle tpa 45 amplifier
Could be a ground hum. You can check the ground on the electrical outlet. Sometimes they are grounded incorrectly. For 3 bucks you can get a 2-prong ground lifter. If that doesn't work, it might be something internal.
Jul 01, 2014 | Audio Players & Recorders
I have hum on my TPA 45 amp. when switched on what cause it please
Don't turn it on and you won't have the hum. It is probably the primary filter capacitor.
Jun 28, 2014 | Audio Players & Recorders
Coffee is not hot.
Possible that the selected time or power was insuffcient. Use a longer time with the same power rating to steam the coffee.
However if the coffee is not heating I am afraid we need to check on the Magnetron, capacitors or transfomer.Can it be also low mains voltage?
Sep 16, 2010 | DeLonghi Microwave Ovens
Dynamic menu error. I cant open my phone menu. What would I do?? It says 'configuration error. please contact your network operator or service centre.
To get the phone working again, you need to download a W200i EUROPE_2 custpack (depends on your phone's package). You have to create folders that go tpa then inside the tpa folder, a folder named preset then inside that folder, a folder named custom. So, it goes tpa/preset/custom with the customize.xml ..., in the custom folder now zip it up so you have tpa.zip, put it in the MISC box and press flash.
Jan 21, 2010 | Sony Ericsson W200i Cellular Phone
My camera on my sony ericsson w580i does not work any help please to fix it myslf
You can add flash menus, change camera driver, change acoustics, add languages with FSX
You can upload stuff to phone either with own_custpack method or via FSX
Rest all remain same. Here is a list a of directories with information. Download the stuff and upload them
ifs/settings/acoustic/ >> Acoustics file
ifs/settings/camera/ >> Camera driver
ifs/settings/display/ >> Display driver
tpa/preset/system/desktop/flash >> flash menus
tpa/system/layout/ >> layout.xml
tpa/system/system/mutlitmedia/mp/skin >> Walkman 2 skins
tpa/system/preset/multimedia/pe >> frames , clipart etc
tpa/system/preset/multimedia/av >> visualizations
tpa/user >> stock pics and themes…
pa/preset/system/settings >> startup and shutdown screens ! all are GIF but with no extension tpa/preset/system/sound >> all sound files
tpa/preset/system/menu >> the famous menu.ml
tpa/preset/system/fonts >> fonts !
/usb/audio >> locked music (can be deleted with FSX only but not with phone)
/tpa/user/audio/ locked music
/tpa/preset/default/audio/ locked music
/USB/IMAGE >> locked images.. can be deleted
/tpa/user/image/ >> locked images
/tpa/prest/default/image/ locked images
;Locked Themes -> /USB/THEME
;Locked Themes -> /TPA/USER/THEME
;Locked Themes -> /TPA/PRESET/DEFAULT/THEMECheck out the FS for more directories and locations icon_wink.gifPlease check out the customization of phone tutorial for more. You can use either own_custpack method or FAR MANAGe
thanks rate it................
Sep 11, 2008 | Ericsson Cell Phones
Marantz amplifier pm-34
the transformer has an internal thermal fuse. If you study the terminations coming out from the internals of the transformer you may notice either a pair of tinned thicker wires or insulated. This may be open circuit. I have often bypassed this internal fuse(they are notoriously common failures) to get a transformer going. You can get a replacement one from a parts supplier if you felt the need. I would just bypass it anyway.:)This may make the amp somewhat "illegal" in the US. We use the MEN (multiple earth neutral) mains power distribution in Australia and the transformer(if melting) would short out to earth and blow the mains primary fuse, the internal thermal is a US requirement.
Jan 12, 2008 | Audio Players & Recorders
67 people viewed this question
 Grubhead
Grubhead
