Question about Philips HDD1630 MP3 Player
Philips HDD 1630 won't charge
I have a Philips HDD 1630/17. All of a sudden about a month ago it stopped charging. Still has the music and all files, just won't charge. Any ideas?
  • 8,596 Answers
In some cases, it is possible to save the GoGear when it is displaying the symptoms you describe. IMPORTANT: First, back up all music and other files stored on the device. The process I am about to describe will delete all files from the GoGear. Also, this is not a GUARANTEED solution - it works in many cases, but sometimes the player will need to be replaced ( replacements/repair svcs are not necessarily available from the manufacturer).
1) Connect the GoGear to the computer
2) Open Philips Device Manager (Start --> All Programs --> Philips in Windows XP if no shortcut on desktop)
3) Click on the Repair tab - see if there is a msg that says something like "to repair your player, connect GoGear to computer while holding the volume + button"
4)IMPORTANT: Disconnect the GoGear from the USB cable, turn the GoGear OFF, and then press and hold the volume + button; then, connect your GoGear to PC while still holding the volume + button (VERY IMPORTANT: this process will fix your player, but it will also delete all music and images you have stored on the GoGear) - do not let go of the Volume + button until a pop-up comes up saying that your player is being repaired
In some cases, there is a small anomaly that is preventing the charge from getting to the GoGear. This repair process can save GoGears that were seemingly hopeless. However, this solution is not guaranteed to work every time. Also, to prevent this issue from happening in the future:
a) make sure that you are using a computer with Windows XP
b) this player works best with Windows Media Player 10 (so rollback if you have WMP 11 - or get a newer model GoGear)
c)get the latest firmware upgrade for this device from the Philips website - it has been known to fix some scattered issues with the HDD1630
-ThaMp3Doctor
Posted on Feb 04, 2008
I have the same problem I think that the internal battery died... is it possible to change it?
Posted on Feb 01, 2008
MP3 won't charge
My MP3 player won't charge or turn on [Solved] - CCM.net
ccm.net > Forum > Hardware
Jul 12, 2013 - Hello,Was charging my player, and all of a sudden it stopped. Now i cannot charge it and it will not turn on either, it's a Sansa Fuze. Please help ... Hipstreet mp3 won't charge!
Aug 23, 2015
Philips MP3 won't charge via mains USB
Jun 23, 2015
MP3 won't charge after washing
Sep 17, 2014
My laptop does not recognize my mp3 player [Solved]
Jan 18, 2013
More results from ccm.net
why won't my MP3 player charge? ' Yahoo Answers
Jan 03, 2016 | Audio Players & Recorders
Power problem.
just get a small screwdriver and take off the back..look on the right side and you should see how the slider works..after that its easy to fix..i hope this helps.(:
Jul 15, 2010 | Philips GoGear ViBE Digital Media Player
Non-supported fomat detected use the philips media converter otconvert files to the devicr. Flashing when music is playing and some music won,t play and it won,t delete.
The HDD series GoGear is only compatible with older DRM licenses. You will have to load files that are in mp3 format to have any success at all with this series of GoGear.
-Tha Mp3 Doctor
Mar 09, 2009 | Philips GoGear HDD1830 MP3 Player
Phillips go gear HDD 1630/17
esay you get of your lazy but and go to best buy!
Feb 09, 2009 | Philips GoGear HDD6330 MP3 Player
I have a Philips Gogear Mp3 player. suddenly I'm not able to switch on the power supply and i tried charging it for 4-5 hrs.no Use. It's just 4 months old. can u help me?
It's dead. The HDD models are basically obsolete - you may have purchased it 4 months ago, but it was manufactured 3 years ago. Here is the basic troubleshooting to be sure, but it won't work:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Dec 12, 2008 | Philips GoGear HDD1830 MP3 Player
Shows "this device cannot start" when i plug in the device
My advice to you would be to go get a new media player that isn't a phillips product. The headache that the hdd 1630 caused me almost made me go insane. I spent countless hours on the phone with tech support. They even sent me a new 1630 that I had for 2 months when the same problems happened again.
This thing is nothing but a expensive paper weight.
Mar 28, 2008 | Philips HDD1630 MP3 Player
MY Philips HDD1630 MP3 MEMORY APPEARS FULL WHEN THERE ARE NO FILES ON IT
Go to my computer open the Philips icon till you get to the music file delete it. Unplug the player from the usb cable and then reattach it. It will then show a new music file and 5.7 space available. All of your music will be gone.........but it was gone anyway. Ideally you should go to Philips and download the HDD1630/17b software and firmware and print off the instructions and redo your player. I did and it works great!!!!!
Oct 16, 2007 | Philips HDD1630 MP3 Player
BATTERY for 6gb mp3 player
i'm not sure what kind it uses but try Batteries plus. they have zillions of batteries. http://www.batteriesplus.com/
Sep 14, 2007 | Philips Sport Personal CD/MP3 Player
Philips 1630/17 not shown songs on player but from pc seems full
had the same problem just last week on my player. I had to download a newer device manager and then do a repair. also after i did the repair i did a soft reset(hold down the up button for 5 seconds, then push power), now it works fine.
Jul 01, 2007 | Philips HDD1630 MP3 Player
Philips HDD1630 MP3 Player Logo
147 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
