Question about Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series shutting down. overheat?
My dryer is shutting down after about 15-20 mins into drying. I've checked the connections, and cleaned out all lint traps, the exhaust vent, and popped open the bottom panel cleaning out any/all lint.
I'm suspecting its overheating, due to it restarting on its own after about 20-30 mins. Is there anything I can check to confirm this, and if it that is the problem any suggestions on how to fix it?
Thanks
Jackie
  • Crathsor Jan 09, 2009
    Well it turns out the motor is actually going out on the Dryer. I ran the Dryer with no heat, and it shut down on me roughly 10 mins into the cycle. So I'm guessing either Dryers aren't made like they used to be, or I need to be alot more pro-active in the cleaning maintenance. Which goes back to they're not made like they used to be.
    Having an older Maytag Dryer for 14 years with no issues to a Kenmore dying on me in 3 years. Guess its back to Maytag.
  • 135 Answers
Your motor is very likely overheating and needs replacement. A simple test is the motor will be so hot you cannot even touch it. Hope this helps!
Posted on Jan 05, 2009
Started drying load, dryer shut off. won't turn on. checked door, changed thermal fuse, checked breaker. still doesn't work. light also not on.
If this is an electric dryer, you may have lost half of the power supply to it. Unplug and remove the little cover plate above where the power cord enters the dryer. Look at the 3 screws holding on the power cord for burned/black looking or loose connections. If nothing wrong there, shut off house breaker and remove cover on house plug where you plug the dryer into and look for same type of issues.
Mar 17, 2015 | Kenmore series 70 80 90 Dryer Motor...
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
I have a Kenmore 90 series dryer.The only number
the door should have a sticker where it closes against with model and serial numbers as for the second part ck terminal connection to elements to make sure they are tight next shoot continuity of the elements limit switches thermal fuse elements will be between 9 and 13 ohms others should read 0
Jan 28, 2010 | Kenmore Dryers
Kenmore series 90 electric dryer will start, heat up and then shut itself off after about 5 minutes
take the bottom of the dryer off and check for obstruction in heat tube. if it is loaded with lint it will overheat and shut down. Use vacuum cleaner and clean it out. Also take exhaust tube off back of dryer and check that the tube leading to the outside is clean with no obstructions. Check baffles on outside make sure there is noone living in your vent tube to the outside.
Jul 13, 2009 | Dryers
Overheating/burnt rubber smell
classical sign of a bad motor. the motor has a thermal switch on it telling the unit to shut off when it gets hot. after it cools down, the switch will tell the motor to turn back on again. good luck, i'm pretty sure that's your problem. contact me for further help if needed. thanks :)
Jul 06, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series gas dryer
The trouble is actually with the start bearings in the drive motor,I bet you have a small hummmm or GRRRRR right at the start, as if the unit wants to hesitate.
Anytime you have a dryer that starts then shutsoff and must "cool" down, it is the motor.
Feb 18, 2009 | Kenmore Dryers
Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Jan 15, 2009 | Zanussi TC7102W Electric Dryer
Kenmore 90 Series Gas Dryer that drys for 10 mins & shuts off...
Check the vent pipe going to the outside of the house, including the vent louver, to make sure the pipe is not partially or fully clogged with lint.
Your symptoms are a classic description of reduced or no airflow from the dryer.
Jan 09, 2009 | Kenmore 62802 Electric Dryer
Kenmore 90 Series Dryer will not DRY
first check the vent outside to see if it is blowing air out strong, then check for heat.
Dec 24, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
297 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
