Question about Sony VAIO E Series VPCEB36GX/BJ Notebook
Monitor cable not connected - Sony VAIO E Series VPCEB36GX/BJ Notebook
    Sergeant:
  • 416 Answers
Then connect it!
Posted on Nov 15, 2012
What kind of cables are needed for my monitor?
Hello
Use the 15 hole socket by connecting a VGA cable. Thie cable can be boutght from most of the electronics spare part selling shops.
Feb 04, 2012 | Dell 1800FP Monitor
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
My screen is black nothing shows up 3 months old
-check the cables on the monitor and disconnect and reconnect it
-if issue still persist you can check the cable of the monitor for broken pins (vga cable the one with blue connector)
-if there are broken pins then the cable could be the problem
-if not you can try to connect the monitor to another computer or connect the computer to another monitor
-if you connect another monitor to the computer and it works fine then the first monitor you have is broken
-but if you connected the monitor to another computer and it works then it could be the video card of the computer.
Nov 25, 2010 | HP w19 19" LCD Monitor
My monitor color is being dimmed automatically after few minutes of start. it is 6 months new.
-kindly check the vga cable or the monitor cable if its properly connected
-you can disconnect and reconnect the monitor cable to check if it could help
-if not you can try another monitor cable or you can connect the monitor to another system to check if its the monitor or your graphics card
Nov 22, 2010 | LG W1953TPF 19" Monitor
My pc does not give display ? Why
Time Required: Testing a monitor could take from a few minutes to much longer depending on the cause of the problem Here's How:
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
  5. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    • If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
  6. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
  7. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
    Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
  8. Replace the monitor.
    WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it.
Aug 02, 2010 | Dell Dimension 2400 PC Desktop
My monitor is getting red color is there any solution
Hello !
Well, there is a problem with either your monitor, VGA cable or video card.
If you wiggle the VGA cable (the cable connected from your monitor to computer) and the color changes, the VGA cable is faulty.
Either connect your monitor to a different computer or connect a different monitor to your computer to see the results.
If your monitor works on another computer, your video card is faulty. If a different monitor works on your computer, then your monitor is faulty.
Hope this helps.
Oct 04, 2009 | Dell Dimension 2400 PC Desktop
How do i connect my cable tv to this monitor?
It all depends on what your cable box output is.
This monitor appears to support a standard cable cord input. So in essence all you should have to do is connect a cable cord from your box to your monitor.
Oct 03, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
Why won't the HD channels come in on my lg flat screen monitor? We changed the cable box and everything. Any suggestions?
The first thing you need is the HD tuner. Since you stated that you changed the cable box I will assume that means it's HD ready.
So you have HD signal coming in to the cable box box by-way of a coaxial cable. Now you need to get that HD signal to the monitor. For this connection the standard coaxial cable normally used between the TV and cable box will not do the job. How many connection options you have depends entirely on the what is available on the monitor.
Normally there are three choices. Your monitor could have anyone of these, a combination of them or none if it's not HD ready.
They are Component cable, HDMI and DVI.
Component is a combination of three RCA type (red, blue, and green), connectors. Simply connect the "Component Out" from the cable box to the "Component In" on the monitor.
HDMI cable looks similar to a computer monitor cable but bigger. Same goes for this one. Connect the "HDMI Out" from the cable box to the "HDMI In" on the monitor.
An indirect connection can also be made if your monitor has a "DVI In" jack by using a cable that will allow you to come from the "Out" connection of either the HDMI or Component on the cable box to the "DVI In" on the monitor.
If you are unclear about anything or you have any other questions please just ask and I'll try and help out.
Oct 02, 2009 | LG Computers & Internet
Getting audio from a Dell LCD Monitor when connected to a Laptop
connect the audio cable to laptop and LCD monitor...
.35mm male to male jack
connect the cable to your laptops headphone jack and the other end of cable to the monitor
the VGA and DVI cable are for video only
Apr 02, 2009 | Computers & Internet
Cable through a computer monitor
Yes it is possible to connect a laptop to a monitor by way of the VGA port on the back or side of the laptop. but unfortunately no you cannot connect cable to the monitor.
Aug 11, 2008 | Denon AVR-886 Receiver
Sony VAIO E Series VPCEB36GX/BJ Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
