Question about Spectra Ford F-150 97 96 95 94 93 92 91 90 F-250 F-350 F Super Duty Auto Car Parts 1997
On my 1997 Ford F150, Abs light flash 7 times in diagnostic, Anybody knows the problem? Thanks
    Master:
  • 689 Answers
Defective ABS,Sensor on one of the brake assemblys,
Posted on Nov 06, 2012
1998 ford F150 abs light stays on/master cylinder is full of fluid
Norman, The ABS light is telling you there is a fault in the Anti Lock Braking system, could be faulty wire/plug,sensor, leaking/stuck wheel cylinder/caliper, etc. The computer in your vehicle will have to be scanned to find the fault, diagnosed and estimate repair. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Ford ABS Light Problems Solved on You Fix Cars com
1997 F150 ABS light Ford F150 Forum
How to Troubleshoot the ABS on Ford F150 eHow
Jul 14, 2016 | 1998 Ford F150 Regular Cab
Replaced wheel bearing and speed sensor on RF, 2000 f350 diesel dually. Drove 1 month about 1000 miles, now I get c1145 and c1230 with abs light. Any ideas?
ABS code C1145 - Ford Truck Enthusiasts Forums
www.ford-trucks.com > ... > 1997 - 2003 F150
Aug 20, 2009 - ABS code C1145 1997 - 2003 F150. ... C1220 Yellow ABS WarningIndicator Failure (2) C1222 Wheel Speed ... C1230 Rear ABS Sensor (Electrical/Static) (2) ... ABS light on (Anti Lock Brakes) and I hear pump when in turn ...
Oct 9, 2010
ABS code C1206-2003 F150 SuperCrew
Aug 13, 2007
ABS light C1230
Oct 22, 2006
ABS light on DTC's C1229,C1230
Nov 18, 2002
More results from www.ford-trucks.com
Nov 17, 2015 | Cars & Trucks
I have a 92 ford f150 the ABS light is on and my speedomoter and odomiter does not work
You don't install parts in an attempt to fix,
you use the codes & factory diagnostic manuals
to diagnose & resolve
Nov 09, 2012 | Cars & Trucks
2004 Ford Explorer ABS light on constantly and
I just had the same exact problem. The ABS light was on constanly, and the 4x4 high light flashes about 8 times, turns off for about 2-5 minutes, then flashes again for another 8 times and keeps repeating. In addition, I was also hearing and feeling a grinding and clunking noise going in reverse, and the steering wheel was difficult to turn. I changed a bad hub assembly on the front driver side and everything went away...fixed! I wouldn't let anybody tell me that the ABS system and the 4x4 system are not linked together. In fact, my local Ford service department assured me that I had two separate issues. Well, I only had one issue and it was a bad ABS sensor. I hope my exprience helps you.
Aug 02, 2010 | 2004 Ford Explorer
Speedomter ,check engine,abs light
there is a defective ABS wheel sensor .
you need to scan it by diagnostic tool to know which one of these sensor
Sep 15, 2009 | 1998 Ford Windstar
1997 ford f-150 flashing abs light (flashes 15 times then stops solid and then flashes again 15 times) rear brakes shoes are at 50% no broken parts inside drum area. did notice that somtimes i would come...
Does your speedometer work ok? There is a sensor on top of your rear differential that provides a signal to both the abs and the computer(speedometer uses the signal from the computer) This sensor goes out pretty common.
Jun 08, 2009 | 1999 Ford F150 Regular Cab
The ABS light keeps flashing
unfortunately the abs or anti-lock braking system consist of sometimes many complicated computer controlled components the only way to know for sure (without signs of major braking problems) (or tale tell signs) is to run the computer on a diagnostic scanner which give the error code for the problem ie:sensor x or y out of range pump malfunction etc. Depending on the year you may be able to find a cheap scanner online or at an auto parts store for @$30-@$120 or take it to a GOOD mechanic if you know one and have it diagnosed probably around @$60-$80 US or the dealer will check it and more than likely get it right for around @$80-$100 US
Apr 20, 2009 | 1998 Ford F150 Regular Cab
We changed the brakes, routers and bearings on my 1997 Ford F150. The next time we drove it the brakes didn?t work well at all. At these points a good friend noticed we need to change the calipers, which...
On the Fords, the most likely problem is the rear ABS sensor in the rear end. With out paying the $75 to be sure though it is just an educated guess.
Mar 06, 2009 | 1997 Ford F150 Regular Cab
1997 ford f150 cyliner 7 misfire
sme problem had to have it put on computer and codes reset
Feb 05, 2009 | 1998 Ford F150 Regular Cab
Spectra Ford F-150 97 96 95 94 93 92 91 90 F-250 F-350 F Super Duty Auto Car Parts 1997 Logo
155 people viewed this question
Top Spectra Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ray gallant
Roy McCracken
Are you a Spectra Car Audio and Video Expert? Answer questions, earn points and help others
