Question about Car Audio & Video
My kdc-x7533u has no display on lcd what will be the solution to get the full normal control? tnks
  • gerald georsua Nov 13, 2012
    to clarify, cd receiver will function also fm radio but the problem is no display on lcd? how to control its function when no display on it? trying to clean ribbon wire but it still d same. pls help me fix this problem. thanks...
Kenwood KDC W6534U - LCD broke (not displaying) head unit works fine otherwise. Now out of warranty. Already had same fault repaired under warranty 2 years ago. How much for replacement facia or...
This is one solution for which the part cost needs to be confirmed from Kenwood. So it is better that you can refer to the service center who had done the work some time ago to give an estimate on the cost. If the fault is a self failure you can ask for some compensation as it has repeated.
Also the LCD pane specific to this model is available only from Kenwood.
Jul 13, 2011 | Kenwood KDC-W6534U CD Player
Need to get the security code for Kenwood KDC-608OR
ok I just found this info online and they say it came from the service manual for that stereo so I hope it helps:
You will need a Kenwood RC-410 remote control. This remote works on KDC-519, KDC-X859, KDC-319, KDC-4019, KDC-MP919, KDC-X759, KDC-419, KDC-X459, KDC-MPV619, KDC-MPV7019, KDC-2022, KDC-2022V, KRC-435, KRC-535 and KDC-X959
To reset the code do the following:
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc.
Above information source = http://techbybucky.blogspot.com/2008/01/how-to-reset-security-code-on-kenwood.html
Jun 19, 2011 | Kenwood Car Audio & Video
How to Fade individual speakers on the Kenwood
Hi.
Use the audio control settings. Here an extract from manual:
Here the full manual:KDC-4020 KDC-3020 KDC-2020 KDC-1020 KDC-1020S.
Regards.
Ginko.
Jun 07, 2010 | Kenwood KDC-2025 CD Player
No pic no sound backlight is on found a site that a guy posted that could solder L2 on circut board now cANT FIND IT AGAIN
HI,,
IF UR FAMILIAR WITH ELECTRONICS,JUST TRY TO OPEN COVER AND REMOVE LCD DISPLAY SOCKET WITH NO.OF WIRES TOGETHER IS ONE MALE SOCKET,THEN KEEP IT AGAIN IN FEMALE DISPLAY SOCKET...IF IT DOESNT WORKS ,,APRROCH LCD TECH..
TNKS
RABBANEES
Nov 11, 2009 | Vizio VW32L 32 in. LCD HDTV
Kenwood kdc-mp532u Auxiliary?
http://inform3.kenwoodusa.com/manuals/KDCX590.pdf - Manual
iPod Adapter Compatible: Using the KCA-iP500 iPod Control Interface, you can connect your Apple iPod digital music player to this receiver. The interface (item # 113IP500) plugs into the receiver's 13-pin CD changer input and controls the iPod through the receiver's controls, as well as displays the iPod's text information right on the receiver's display.
Dec 30, 2008 | Kenwood KDC-MP532U
Want a clock setting on my display window
According to the manual, in STANDBY MODE, push the control knob towards FM or AM and select CLK ADJ. Press the control knob for at least 1 second, the clock display blinks. Adjust the hours by pushing the control knob towards FM or AM, and the minutes by pushing the control knob right or left. Exit CLK ADJ mode by pressing the MENU button. Hope this helped.
Feb 07, 2008 | Kenwood KDC-MP235 CD Player
Faceplate starts flahing and no controls work.
Sounds like you might need to clean the contacts on the back of the faceplate or the ones on the front of the actual unit.
Jan 18, 2008 | Kenwood KDC-MPV619 CD Player
KDC-X591 Demo Mode & Remote Steering Harness
instructions i was trying to figure out the same thing in my brothers car and i came to this site the two answers before mine were both right and wrong, they needed to be combined and modified a tic. but i just got my brothers kdc x591 and this is how hit source button till standby mode is on, press menu then use the control knob the right one thats not the volume, to select demo mode press the 1 button then menu and voila
Dec 31, 2007 | Kenwood KDC-X591 CD Player
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
