Question about Toshiba Computers & Internet
Toshiba satellite l750-16l "a disk read error occurred"will a new hard drive fix
  • Toshiba Master
  • 2,878 Answers
You hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and reseat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Posted on Nov 07, 2012
Report
  • 50 Answers
SOURCE: SMART Failure Predicted on Hard Disk 4: Hitachi-(S1)-ToshibLaptop
that will be expensive. i just went to microcenter and asked them, they said many hundreds of dollars just to look at it, then like 1600 for the cheapest recovery...
I would
1. stop using it immediately. (after an error like that, you may have only minutes of life left on it)
2. get a 25 dollar external enclosure to put the drive into. If it's IDE make sure you get an IDE enclosure, if SATA, get SATA compat. external enclosure.
3. get another computer, o rgo to a friends house, etc, and try to read your data on their computer after plugging in your hard drive inside the external enclosure.
4. if you can see it, rush like mad to copy the data thats important to your friends computer before the drive is 100% dead.
microcenter and similar stores have external hard drives at $129 dollars for a terabyte. BUY ONE! :-)
Good luck
PS: rumors go around that if you freeze the hard drive in your freezer for an hour, it helps get the data off, dont know if this is in fact true. Once the drive is dead, it's dead. You cant do much about it unless youre willing to part with a lot of money.
Posted on Feb 02, 2009
jilpeshpatel
  • 259 Answers
SOURCE: disk read error occured
If not give it a go and do a repair if needed again!
1- You may have a corrupt MBR (master boot record)!! You will need to reformat and do Fdisk /mbr to delete the master boot record!! Save all data first as this will not allow you to access any of your data as all file location addresses are located in the MBR!!
2 - Your harddrive may have a bad sector get a zerofill tool(low level formatting tool)!! This will rewrite you HD's sectors putting them back to factory spec's!! Maxtors is called Maxblast you can get it from thier site!!
3- or it could be a defective drive, but most read errors are due ot corrupt MBR or a bad sector!!
Posted on Mar 26, 2009
  • 122 Answers
SOURCE: toshiba satellite 1805 s204 "media test failure, check cable"....
Did you install the windows system etc? If not boot from the system restore cd and it should work. If it will not boot from the cd-rom then more damage was done then was apparent and the unit would require factory qualified repair. Be sure of the cost before committing to repair since on laptops sometimes it is cheaper to replace the repair. Good Luck
Posted on Jul 21, 2009
dnewcombe1
  • 1564 Answers
SOURCE: Toshiba Qosmio laptop with Phoenix securecore
You've probably got to have your computer configured to boot from a rescue CD before it can recognize and install the new harddrive. Also make sure that there is an operating system installed on the hard drive . If not it will not do anything until you install one. This will be automatic if you install a new XP or Vista DVD into the computer's DVD drive the reboot.
Posted on Sep 07, 2009
Testimonial: "I'll go out to Toshiba and get a rescue disk. FYI:I booted up with an XP disk to try to load the OS, but keep getting the blue screen"
  • 1752 Answers
SOURCE: how to fix a disk read error occured?
Sorry, it's time for a new hard drive.
Posted on Nov 19, 2009
How to fix hard drive error message ata device
I think you are talking about Toshiba MK6476GSX, if yes then this might help you
http://forums.toshiba.com/t5/Satellite-Laptops-all-other/Win7-Dectecting-Hard-Disk-Problem-with-TOSHIBA-MK505GSX-ATA/td-p/189018
Jul 20, 2014 | Toshiba Computers & Internet
My toshiba L505-S5963 will boot but it stops and says "a disk read error has occured plz press ctl+alt+del to restart" even after I do that, it comes back to the same thing EVERY time! how do I...
your hard drive might be causing that, but to be sure of that, take out the hard drive and try booting from your cd rom.
and pls let us know after trying.
Aug 27, 2012 | Computers & Internet
Disk read error occurred
This indicates the hard drive has errors or bad sectors, you can go into my computer, right click on C Drive, select properties, select tools, click check now, a small pop window will appear, check off both boxes on left, when computer restarts again it will test and repair files and attempt to fix bad sectors, this test will take some time, but worth the effort
Jun 07, 2012 | Toshiba Satellite L655-S5072...
Getting error code F3 F100 0003 on a Toshiba Satellite L650 running on a Windows 7 Ultimate 32 bit operating system. This code appeared before hard disk drive was replaced and continues to appear after a...
Hi Lea,
If you're getting the F3 F100 0003 error on boot-up, the problem might lie on three things. It's either the a bad HDD, Memory, or the video adapter (which is soldered on the motherboard). Since you already replaced the HDD, the problem might lie on the other two. If you can burn a disc to run diagnostics on your computer, you can use UltimateBootCD or Hiren's Boot CD (more info on the tools here).
I've also seen some errors when you are trying to re-image the HDD using the Recovery Discs and it may have some connection to the error message that you're getting. Here's a list below:
-An error has occurred: ERROR : 10-FC10-1710" -- may be caused by a faulty hard drive.--An error has occurred. ERROR : 10-FC12-0241" -- may be caused by a faulty hard drive or defective memory.
-An error has occurred. ERROR :10-FC12-045D" -- may be caused by a faulty hard drive.
-An error has occurred. ERROR :10-FC06-0002" -- may be caused by damaged recovery media or faulty hard drive.
-An error has occurred. ERROR :10-FC12-0970" -- may be caused by defective memory.
Hope this helps. Good luck.
Sep 06, 2011 | Toshiba Satellite L455D-S5976 Notebook
Hi. Every time I turn my Toshiba Satellite Laptop on (A305-S6905) it turns on normal then it goes to this black screen and says "A disk read error occurred press ctrl+alt+del to restart." I...
The disk read error message appears when the motherboard can't read what is in the hard disk and use it to launch the Windows boot process.
It means that the hard disk is dead and everything on it is lost, including the recovery partition that new laptops use instead of the recovery disks. You will have to replace the hard disk (a quite complicated job that only an experienced person should do) then order a recovery disk from here
https://www.csd.toshiba.com/cgi-bin/tais/support/jsp/serviceUnitVerification.jsp
and use it to reinstall Windows.
Jul 15, 2011 | Toshiba Satellite A135-S2386 Notebook
I'm tryna to turn on toshiba satellite p105-s6024 and it keeps saying a disk read error occurred... What do I do?
Well that usally means the bios has looked for a hard drive during preboot check and it wasnt present. Or it wasnt responding therefore you most likely need a new hard drive.
Aug 13, 2010 | Toshiba Satellite P105-S6104 Notebook
I have a Toshiba Satellite M35X-S114 that when I power up it reads "A disk read error occurred". When I ctrl-alt-del I can get to a PhoenixBIOS screen, but don't know what to do there. Has my hard drive...
You can try to either repair windows or the best option is to reinstall everything back on the System.
And if does not help. Please get ur Hard drive checked.
Jul 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Satellite A210
Your hard drive is failing/failed. A reputable repair person should be able to remove the drive and slave it to another computer. Then if it will come on as a slave, he/she can get the data off. If it's dead as a slave then a professional recovery is the only way to recover data. In any case you're going to need a new hard drive.
Good Luck
Mar 21, 2009 | Toshiba Satellite Pro A210-EZ2202X...
TOSHIBA A135-S2386- I HAVE AN ERROR WHEN TURNING ON MY LAPTOP
You most likely have a faulty hard drive, especially if it is making a clicking sound.
You wil need to purchase a new hard drive and install Windows again with the Toshiba Recovery CD.
Jan 21, 2009 | Toshiba Satellite A135-S2386 Notebook
Toshiba Satellite laptop boots up but shuts down on its own very shortly
Hi JOJO0803,
Based from the error message you're getting it sounds to me that your problem there is not software related but is more hardware in nature.Since you're getting a message "disk read error occurred IDE#0" this pertains to a problem with the hard drive itself. It's possible that your hard drive developed bad sectors or errors on the disc itself.
So to be sure I would recommend that you run the hardware diagnostics for your laptop computer especially the one for the hard drive since you're getting this message. If the hard drive fails the test or any other part fails in the test, contact your techsupport and ask for replacement parts if your PC is still under warranty. Otherwise you may have to buy parts for your laptop.
If the hard drive tests passed and all the other hardware tests also passed then you may proceed to troubeshoot the software using the Windows XP Home CD. Boot from the WinXP Home CD, and you get to the setup screen, choose "R" for recovery console and then on the prompt type "CHKDSK /R" let it run, it may take a while. afterwards it will bring you back to the prompt then type EXIT and it will reboot the system, see if that fixes the problem. Worst case scenario you may have to format then reinstall Windows XP again to fix this problem.
Hope this helps!
Peace! :)
Oct 23, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
326 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
