Question about HP CP3525N Color LaserJet Printer
Cp3525 lines on left
I am getting little horizontal dashes done the left hand side of my printing. there are approx 10 on a page about an inch apart
    Sergeant:
  • 241 Answers
This is most likely to be a toner cartridge issue. Either a leaking cartridge or one with damage on the roller of the drum. This is especially likely if it occurred just after changing a toner.
If however the transfer belt of this printer is easily accessible from your printer (I am not massively familiar with this model) it may be worthwhile wiping this down gently with a clean piece of kitchen tissue. This will look like a foot wide sheet of plastic wrapped around two rollers.
Lastly it could be a small roller with residual toner toner powder on it that is repeating down the page. This could be hard to track down, but much like the transfer belt this will get flushed out with continued printing anyway.
Posted on Nov 06, 2012
shortyz1123
  • 9 Answers
SOURCE: scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Posted on Jan 07, 2008
  • 25 Answers
SOURCE: printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Posted on Aug 14, 2008
Joed911
  • 4338 Answers
SOURCE: 2430 printing 1/2 inch marks down left side of page
Did you change the Toner cartridge? If that did not fix it :
Then the Fuser needs replacing. If you take the Fuser out from the rear, and rotate the drum in it, you will see the marks. You can try to clean it but experience shows that you will have to replace it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 13, 2008
  • 10 Answers
SOURCE: Horizontal Lines
try another toner and see if it changes. if it does not then you may need a fuser,
Posted on Oct 16, 2008
jarifa
  • 30 Answers
SOURCE: The print cartridge cradle cannot move.
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
749
Posted on Feb 27, 2009
On left hand side of page horizontal line
You might have touched the main charger cleaner a green part above the waste toner container. just push it inside and try to copy and print
May 11, 2010 | Copystar Office Equipment & Supplies
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Dell Print Quality Problems: Horizontal lines On One Side
Try running a cleaning sheet through the printer. Remove the drum and check you waste toner (if that is built-in to your drum then skip this). If that gets full, then some of the bad toner can spill out creating lines/smuges. I would also use compressed air to blow out the inside of the printer where the toner/drum goes. That will help remove anything that is left behind after a replacement.
Also, check the settings in the print server for anything that will clean the printer/correct horizontal lines.
Mar 16, 2009 | Dell 3010cn Laser Printer
Black horizontal lines across pages
If they are the same distance apart every time then suspect the problem to be caused by the components in this order First the drum that is in the print or xerographic module, the charge and cleaning roller are located in that module also. So I suspect that first.its .Located above and to the right of the toner cartridge. Secondly it could be the roller on the toner cartridge, that would occur probably every 1 1/2 to 2 inches apart, the drum would cause the defect about every 3 inches. It less likely could be coming from the fuser, and if the fuser was causing that you should also have a lot of jams. There is also a transfer roller on the right hand door that could be causing it, but that would be exceptionally rare.
If the lines are random and have no consistant spacing, I would suspect the power supply then the laser.
Oct 28, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Scanning document leaves streak down right hand side
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
Green lines on my Sony projection
Those are called retrace lines and they are the result of the blanking pulse not having the desired effect. This could denote a problem in the Horizontal section of the TV. In this case the green gun is not being turned off as it goes back to the left side of the screen.
Sep 20, 2007 | Sony KP-57WS500 57" Rear Projection...
HP CP3525N Color LaserJet Printer Logo
403 people viewed this question
Seeker5211
Seeker5211
