Question about Canon Color ImageRunner LBP5970 Laser Printer
E5 PREP FIX UNIT
MXM450
  • 62 Answers
SOURCE: imagerunner 2016, waste toner full error message
hey, wel if the copier is showing a message saying that the waste toner is full it means the waste toner deposit is attached to the drum unit.
so, open up the frotn cover, pull down the (drum)-lock lever, it should release the left cover, then pull towards you the drum unit, and there you go.
the black case with a small trasparent cap is the waste toner deposit.
you have two ways to go.
1 you may remove that rounded transparent plastic cap and be able to vaccum the waste toner (dont even try reusing that toner, it wont work ok) or
2 you can go the other way wich allows you to easily vaccum it: remove the drum (the roller itself) then the charger roller, then the cleaning blade and there yo go again, but now you got more space to vaccum and believe me it is easier this way.
an additional choice would be to buy a new drum unit gpr18 i think (check please) and forget all about vaccum-ing.
Posted on Jan 26, 2009
color_50
  • 22 Answers
SOURCE: Canon Color ImageRunner - Tab Instructions
To be able to print using tab paper from the driver
Since the tab paper can only be fed from Stack Bypass, single reverse tab paper cannot be
used. The tab paper must be single forward.
1. Go to the printer and put some tab paper in Stack Bypass
2. Press Letter on C3200 LCD panel and press Next
3. Select Tab paper and press Done
4. Go to Windows Start menu and choose Settings
5. Open Printers folder
6. Select Canon iR C3200 PS3’s Properties
7. Click on Device Settings tab
8. Click on Form to Tray Assignment button
9. Making sure that Stack Bypass is highlighted and Paper Size is Letter, select
Tab Paper by scrolling down the Paper Type list
Page 2
Hint:
In order to print to Tab paper, it is necessary to select Tab Paper in the Form to Tray
Assignment dialog box before using this option. Otherwise, the option of printing to Tab paper
is not available from the print driver.
10. Click OK to close Form to Tray Assignment
11. Click OK to close Properties window
12. Open Word document called “tabs.doc”
13. Go to File menu and select “Print…”, and change the current printer to Canon
iR C3200 PS3.
14. Click on Properties
15. Click on Paper Source tab.
16. Select Paper Type option
17. Choose Tab Paper from Paper Type list. As soon as you select “Tab Paper”,
Conflict Information dialog will appear. Click on OK.
Page 3
Hint:
In order to change the tab position, click on Tab Position button. Clicking this button opens a
dialog box for specifying the width for shifting the image data to be printed on the tab part of
the paper.
Hint:
The conflict information displayed pertains to the finishing of the document. Tab paper must
be grouped, not collated. Since the default value for finishing is Collate, the driver
automatically adjusted the finishing option to resolve the conflict.
18. Click on OK to close the Properties window.
19. Click on OK to print the tab paper.
20. Go retrieve your output.
Note:
Please note that this procedure for printing on tab paper is not the same for all drivers. CCD
drivers would be similar to this procedure, but depending on the OS Platform, exact buttons
and steps would vary. However, from such drivers as imagePASS-C1 PS and Macintosh drivers
would work completely different from this procedure. Although we will not cover each
procedure step by step, we encourage you to take time to make yourself familiar with the
procedures.
Posted on Mar 15, 2009
SOURCE: Canon MP210 getting E5 message with PG-50
Sadly Canon cripple many of their printers so that they will not accept the high yield cartridges such as the 50 & 51. As a result your printer the MP210 will only accept the 37 or 38 cartridges which are only half filled, or the 40 and 41 which are fairly full, but don't contain as much as the 50 & 51. All I can suggest is that you could try to sell the 50 on eBay, and send a strongly worded email to Canon.
Posted on Aug 26, 2009
  • 89 Answers
SOURCE: how to load staples in canon imagerunner 3300 copier
Does your copier have the finisher or saddle to have staples? There should be instructions in the user manuals for replacing staples. If you don't have the user manuals, I'd ask Canon to purchase replacement copies or look on the web.
Posted on Nov 25, 2009
SOURCE: my canon pixma MP145 showed E5 and wont print anymore
I have been using black and color ink refills for sometime now, but am unable to use my printer since last week. It shows E5 and on the dialogue box is stated that it cannot recognize the COLOR.
Posted on Jan 20, 2010
How to clean the magenta toner out of the drum unit
Change the magenta image unit,your image unit life end,
Feb 28, 2013 | Canon Color ImageRunner LBP5970 Laser...
E003-0001 error messege
This error related to fixing unit, low temperature error in fixing temperature control or DC controller PCB faulty.
Solution replace new fixing film assembly
Feb 04, 2013 | Canon Color ImageRunner LBP5970 Laser...
HOW WE CAN RESOLVE Error message E1 CHG.WST.CTN
This tells you that the waste container is full and needs to be replaced. This LINK tells you the step by step process in resolving this issue.
I hope this works for you. Kindly reply for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Feb 19, 2011 | Canon Color ImageRunner LBP5970 Laser...
LBP 5970 --16 PREP.Y TNR
Hi!
Y toner is your yellow toner that needs to be replaced!!C is cyan,M is magenta and BK is black!!
Enjoy!!
Jan 29, 2011 | Canon Color ImageRunner LBP5970 Laser...
Printing colour quality problem on canon irc2620n laser printer
Are you service technician?
You can try to clean the laser unit, try to clear dc-con like on clc3200, but first try gradation adjustment.
If you not an technician do not try to clean laser by your self
Feb 01, 2010 | Canon imageRUNNER C2620 Color Copier
Info
Canon ir3300 is a black and white 33 ppm (A4) copier , printer (network), fax and scanner ( b/w).
For more info please visit canon website.
Sep 26, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Canon Color ImageRunner LBP5970 Laser Printer Logo
110 people viewed this question
old marine
old marine
