Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Dishwasher stopped working during rinsing cycle.
I have a Kitchenaid Superba Dishwasher that just stopped working. Completely dead. Water sitting on the bottom never drained. There's power going to the dishwasher.  I read your other solutions and you have me thinking it's the fuse. Can you give me steps on how to try this possible solution before I give up. Thanks.
  • rsheets462 Feb 08, 2009
    I have same model and same situation - what did you do to solve the problem? where is the fuse located?
  • 375 Answers
1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse with wiring harness supplied with it.
Good luck
Vlad
First Choice Appliance
Posted on Sep 11, 2010
Dishwasher took 3 hours to complete cycle
If you have set the unit to heated water or your hot water is not hot will delay the wash cycle. The heater in the dishwasher is very slow!
The following is from the user manual.
15
TROUBLESHOOTING
First try the solutions suggested here and possibly avoid
the cost of a service call...
Dishwasher is not operating properly
Dishwasher does not run or stops during a cycle
Is the door closed tightly and latched?
Is the right cycle selected? Refer to the "Cycle Selection
Charts."
Is there power to the dishwasher? Has a household fuse
blown or circuit breaker tripped?
Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
Is the water shut-off valve (if installed) turned on?
Dishwasher will not fill
Is the overfill protection float able to move up and down
freely? Press down to release.
Dishwasher seems to run too long
Is the water supplied to the dishwasher hot enough? The
dishwasher runs longer while heating water. Refer to the
"Dishwasher Efficiency Tips" section.
A delay automatically occurs in some wash and rinse cycles
until the water reaches the proper temperatur
Hope this helps?
http://www.repairclinic.com/UserManual/f75a81f2957b4b86b396c8c3629d9078/8531130/Use-Care-Guides-Owners-Manual/Use-and-Care-Guide-8531130
Oct 16, 2016 | KitchenAid Dishwashers
Hard water in dishwasher
If you have hard water you can check on water softeners that hook into your water system.
Oct 29, 2012 | KitchenAid Superba Series 49 dBA per Iec...
I have the KitchenAid Superba dishwasher in stainless steel. I've noticed that my tupperware (especially) are never dry after a cleaning cycle. Even if I wait a couple of hours after to empty the...
You might try using Jet Dry in your rinse aid dispenser, but plastic things tend to hold water and there isn't much you can do except try using Jet Dry.
Apr 09, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Our ten year old kitchenaid dishwasher doesn't get the dishes clean. there is food particles left on dishes if we don't completely rinse our dishes. is there a cleanout filter that needs to be emptied?
Locate your dishwasher's filter. It is typically on the floor of the dishwasher. Pull out the bottom rack and look along the bottom of the dishwasher until you find it.
Use a paper towel or sponge to remove any residue or debris that has accumulated on the outside of the filter once you locate it. On some dishwashers, the filter area does not detach or open, so your hand cleaning will stop here. On other models, you can unscrew the filter housing to access the inside and clean any debris from the filter area. Simply wash out the filter using soap and water, then reassemble once cleaning is complete.
Further clean the filter area by pouring a quart of white vinegar into the bottom of the empty dishwasher. Turn to a wash cycle and allow the dishwasher to run with the vinegar cleaning the mechanisms, including the filter.
To deep-clean your dishwasher and the filter periodically, mix the following ingredients together in a bowl, then pour into the bottom of the dishwasher: 1/2 cup salt, 1/2 cup baking soda and 1 cup bleach. Let the mixture sit in the bottom of the empty dishwasher overnight. The next morning run a wash cycle, letting the bleach mixture clean and disinfect the dishwasher thoroughly.
Aug 29, 2010 | KitchenAid Dishwashers
Detergent packs are not dissolving
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
Apr 21, 2009 | KitchenAid 24 in. KUDS02SRSS Stainless...
My dishwasher leaves crumbs and food particles stuck to everything in the top rack
Usually this problem is due to the fact that the dirty particle filled water isn't fully draining and the unit is trying to rinse the dishes with fouled water thus baking any leftover food particles during the dry cycle.
Make sure that all of the water is draining from the dishwasher after all drain cycles.
Usually poor draining is due to a blockage or partial blockage in the drain line,also the blockage can be at the drain pump itself or where the drain connects to the under sink drain
Dec 20, 2008 | KitchenAid Superba Architect KBCA06XPBS...
Kitchen aid dishwasher
Either:
Good luck,
Vlad
Sep 01, 2008 | KitchenAid KUDMO1FK - Multiple Color...
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid dishwasher
i would check your drain for restrictions under sink. fill with water, and then cancel cycle, did you hear water draining freely??? sounds like a clog
Feb 14, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
229 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
