Question about Home
Kitchen sink side spray clips/couplings don't match any replacement parts
We're renting a house and don't know the make/model of our kitchen faucet (any tips on how to id it?)
The side spray has been leaking for a couple of months so my husband decided to replace it. Only he's tried 3 different replacement kits from Home Depot, Walmart, etc., and nothing fits.
The faucet is a brushed chrome or stainless finish, wiht a lever handle that sits next to the spigot. The side sprayer sits on the opposite side of the lever. The existing side spray has a non-threaded connector that is covered by two halves of black plastic which are in turn held together by a wire clip. It connects to a coupler under the spigot that seems extremely long, and the bottom part of it is unthreaded. The hose won't fit onto the unthreaded part for a long enough distance to screw onto the threads at the top of the coupler, if that makes any sense
The 2 pieces of the black plastic connector cover popped apart and now the wire clip won't secure them back on.
Any ideas? Why won't a standard replacement kit work? We're going crazy!
ALSO, we seem to have developed a mysterious leak/seepage on the laminate flooring directly in front of the sink & dishwasher. Could this be related, or is it more likely the result of a problem with the dishwasher?
Thanks.
  • 10,865 Answers
First off I would put this issue at the top of my to do list because the laminate flooring will not hold up at all with a constant water bath. That being said, turn off the water to this faucet and remove the entire faucet. Take it to a hardware store or hardware department of a box store and see if the broken part can be replaced. If yes, good. If no, replace the faucet as this is a lot cheaper than replacing the laminate floor. Good luck
Posted on Jan 18, 2009
How do I replace the sprayhead?
replace the sprayhead Dragon, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kitchen Sink Faucets How to Remove the Spray Head From Sink
How to Repair Single Handle Kitchen Faucet With Spray Hose Kitchen Plumbing
Pull Out Kitchen Faucet Sprayhead Replacement
Replacing the Kitchen Sink Spray Nozzle
May 25, 2016 | Plumbing
Kohler single handle sink faucet 10 years old leaking
William, you or a plumber will have to replace the cartridge and seals to stop the leaks. The parts may have life time warranty, check your manual if you still have it. Check the attached links,instruction and guides, Good luck
KOHLER Canada Warranty Information Planning
Maintenance Replacement Parts KOHLER
Fort single control pullout kitchen sink faucet with color matched...
Kohler kitchen faucet repair
May 12, 2016 | Kohler Model 10433: Fort® Single-control...
How do I replace the flange on the side sprayer? The sprayer and hose are intact but the part of the flange that screws broke and has to be replaced. Quesiton is where do I disconnect the hose so I can...
The hose that goes to the Sprayer has to be disconnected under the sink at the main connection there, then it can be pulled up and out of the top of sink. the you can unscrew the nut under the sink on the flange and remove and replace.
Aug 28, 2011 | Price Pfister Marielle Kitchen Faucet with...
Re Delta faucet 172-WHWF The spray assembly has a long delay in getting water to it. Would a new diverter valve fix that problem? If so, what is the part number for the diverter valve for this...
Before you start replacing parts look under the sink and make sure the hose leading to the remote spray is not kinked or starting to kink when pulled out.
Mar 07, 2011 | Delta Faucet Delta 172-WHWF Waterfall...
I have a Price Pfister Marielle Kitchen Faucet that looks exactly like Model No. F-026-3NCC. I need to replace the ceramic valve so I ordered part #Price Pfister 974-035. It looks similar to the valve in...
That faucet was discontinued some time back for the one you ordered parts for and the only way to get the part if it is still available is to know the part number. Now if you have a plumbing parts house in your area that specializes in faucet parts they may be able to match up the old part if you still have it.
If you can find the part number for the faucet you have then the part may still be available from Price Pfister.
Mar 03, 2011 | Price Pfister Marielle Kitchen Faucet with...
Water is very slow coming out on hot side but okay on cold side. Teh rest of house taps work great.
Remove the cartridge and rinse it in another sink. If you have hard water, soak the cartridge in vinegar for a couple of hours.
Apr 05, 2010 | Price Pfister Marielle Kitchen Faucet with...
Dripping faucet
Moen is a cartridge style unit. They make two different cartridges that you can buy at Home Depot. Turn the water off under the sink and then remove the handle. You will see the the cartridge. It has a U shaped retaining clip that pulls out. Once you remove it, then take a pair of pliers and pull the cartridge out. Take it up to HD and match the one you have. The new one will slide right back in and you will reverse the process.
Mar 15, 2009 | Moen 7065 Vestige Single-Handle Kitchen...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Home Logo
1,063 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
