My Hotpoint wf000 1000 spin model won't spin. It goes through a full wash cycle, agitates fine, but just won't spin at the end of the wash. Any help appreciated.
  • 4 Answers
Need to replace the back of the dial which is the assembly switch
but you maybe able to see any burn connections as you turn the dial and are not making contact, filling the burn contact may solved I did on my and work for a little time til got a the dial switch
Posted on Nov 06, 2012
Sorry if it may be too obvious, but have you checked the philtre? generally they stop spinning when it's stuffed... when you open it, make sure you have a mop and bucket handy, some water will come out!
aborcass
  • 2651 Answers
SOURCE: Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Posted on Apr 29, 2008
SOURCE: hotpoint 800 wm 11 goes through cycle but won't spill or drain
hi there maybe your waste pipe might be blocked from washing machine or mqaybe there is a blockage somewhere else in your plumbing which does happen queit alot? hope this helps
Posted on Jan 17, 2009
localwonder
  • 6784 Answers
SOURCE: no agitate/no spin/yes spin in rinse
this is a drive shaft issue. this shaft is connected to the gear case and the gears may be stripped or the clutch may be damaged. there are many plastic parts here in this area that can break due to heavy load or just old age. replacing the internal parts and clutch will fix these issue you are having.
Posted on Mar 13, 2009
beltronic205
  • 1467 Answers
SOURCE: Hotpoint Aquarius WF560, goes through cycle wash
Could need new motor brush kit>
Posted on Oct 06, 2009
  • 1218 Answers
SOURCE: Washer will not spin, on rinse or spin cycle.
Good day,
Almost always the lid switch.
Here is a good tutorial on replacing it. It should be noted there are 3 different lid switches depending on your model, and as well, the screws that hold the top console may be in 3 different locations.
Bottom left and right, bottom left and right but under plastic end caps that have to be unclipped and finally on the bottom but at the rear.
Kenmore's are built by Whirlpool.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Posted on May 12, 2010
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Washer won't spin or agitate
You need to check the fuse link in the console. These are known to burn out quite often. Here is a link to the part.
Oct 19, 2012 | Hotpoint VWSR4160GWW Top Load Washer
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Aug 21, 2012 | Kenmore Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
GE Profile WPRE6100G tub spins while washing
My parent's Hotpoint did the same thing!! The brake on the bottom of the tub is not engaging! It needs replaced!!
May 15, 2012 | GE Profile WPRE6100G Top Load Washer
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
Washing Machines Logo
129 people viewed this question
Top Washing Machines Experts
