Question about Organic Fiji Certified Virgin Coconut Oil, Fragrance Free 3 oz 3 oz
How to remove ransedity smell of virgin coconut oil
Few days after virgin coconut oil was extracted the oil become ransed smell. Hor to eliminate it.
Car never burned,or leaked oil till few days back.Drove about fifty mi hwy.Smelled oil burning on engine.Oil coming out oil pan gasket,And from every gasket from engine +under timing belt cover. Can it be...
It can be fixed without removing the engine. What car is it? cause it depends if its fwd or rwd, the fwd usually need the exhaust removed before removing the oil pan
Oct 05, 2014 | Cars & Trucks
Tip
How is palm kernel oil extracted? Facts of palm kernel oil As we...
As we all know, the palm fruit can be used to make healthy red palm oil, but do you know the palm kernel can also be extracted to obtain palm kernel oil? After the palm fruit oil gained and fiber and palm nuts left as by-products, in most time, the fiber is used to make a fire, the nuts left behind, however, can be further processed to obtain palm kernel oil.
Made from the seeds of palm plant, palm kernel oil is more saturated than palm oil and comparable to coconut oil, it is semi-solid at room temperature and is mainly used for cooking since its cheap price as well as its stable properties when cooking with high temperature and can be stored for a longer time than other oils. Palm kernel oil is also able to be used for many other purposes, e.g. pomade (body cream), medicine, frying fish, making stew, making soap, etc.
How many ways to extract palm kernel oil?
There are two common methods of extracting palm kernel oil, one is full press extraction where mechanical screw oil press machines are used to extract oil out by squeezing under high pressure, this oil extracting method is mainly used by small and big capacity oil mill plants. The other method is solvent extraction with hexane, where a solvent is mixed with the material to separate the oil, this extracting method, however, is generally used by larger capacity oil processing mills. You can choose the one that suits you best according to your daily capacity.
Solvent extraction method is recommended for much bigger capacity oil mils, for small capacity oil extraction mills, the former method will be better. Solvent extraction processes can be divided into three main unit operations: kernel pre-treatment, oil extraction, and solvent recovery from the oil and meal.
palm oil extraction process
palm oil press machine and palm oil refining machine
Palm Oil Processing Plant Palm Oil Mill Process Machinerymanufacturerssalep... Cooking oil machine Manufacturer of cooking oil machine and biodiesel...
on Dec 27, 2016 | Miscellaneous
Tip
Homemade remedies for dandruff
If you do not clean your hair regularly then there is a possibility of dandruff. If you clean your hair too much then also the scull skin gets dry and may cause dandruff.
Incase you get dandruff then there is a wonderful remedy that you can prepare it at home. At it is economic also. Here is the recipe.
Take a small onion and extract juice of it. Take some hibiscus flower petals and extract juice. You can crush them and squeeze to extract the juice. Add freshly cut lemon juice, Neem oil, camphor to it. Apply the resulting solution to your sculp. You will get relief from dandruff.
OR
Mix Tender coconut water, lemon juice, ginger juice, mint leaves paste, brahmi (see picture) leaves paste, vinegar and little amount of camphor together. Apply this to your sculp. you will get relief from dandruff.
OR
Take 25 grams of fenugreek seeds and bake it well. Then crash it. Add 10 grams of camphor and crash the mixture to make powder. Add this mixture to 100 grams of coconut oil. Apply this oil to your scalp and massage well. Continue to apply this oil in alternate days. Your dandruff will go away in a week.
In addition to the above follow some rules. Always use herbal shampoo. Often put ginger paste and vinegar mixture to your scalp. Put 4 spoons of apple juice to your scalp 1 hour before taking bath. Eat food which has plenty of vitamin A and D. This will solve dandruff problem.
Brahmi Leaf
on Jan 16, 2011 | Health & Beauty
Why is the pulp warm/hot? the screen is clean...
It is caused by friction as the cutter assembly squeezes the pulp out. The tighter the squeeze the more juice that is extracted. Be sure to oil the shaft with only olive or coconut oil as these oils will withstand the high temperature without getting gummy and making the cutter stick to the shaft..
Sep 04, 2014 | Champion Juicers
What is coconut rum?
Coconut rum is simply white rum flavored with coconut extract. It is often used in cocktails, most commonly mixed with pineapple juice. One of the most popular brands of coconut rum is Malibu.
Feb 03, 2013 | Wine & Spirits
Organic Fiji Certified Virgin Coconut Oil, Fragrance Free 3 oz 3 oz Logo
54 people viewed this question
Top Organic Fiji Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Organic Fiji Health and Beauty Expert? Answer questions, earn points and help others
