Question about HP LaserJet Pro 100 color MFP M175nw - multifunction printer / copier / scanner color
HP laserjet 100 mfp blue line
I replaced all the toner catriges and now there is a thick blue line down one side of a page about 3/4-1 Inch in Diameter. Its not a thick line but faded like its leaking toner in one particular place. Ive set the printer to clean twice already. What can I do?
    New Friend:
  • 4 Answers
I had the same kind of problem with the same printer.
The problem started with yellow toner powder 'leaking' inside the printer and contaminating the printed documents.
After inspection, the yellow cartridge showed what seamed to be like caked/cluttered powder between the magnetic roller and the doctor blade.
I dismantled the cartridge to realise the 'caked/cluttered powder' was in fact a sponge material. The internal 'spongy' toner feeder roller was damaged and little pieces of the material was coming out of the cartridge.
After further inspection inside the printer (all cartridges and drum removed), I found two little pieces of the same material stuck between the kevlar roll and the metallic housing underneath it. (going up, from bottom to top, you have the pile of paper in the feeder -> horizontal metallic plate -> kevlar roll -> toner carousel.)
I used a strip of heavy paper (200g) to gently remove the two sponges, set two clean jobs and the problem was solved.
The kevlar roll is also accessible from the printer's back door, some material may also be stuck in this location.
Posted on Mar 06, 2014
2 Suggested Answers
beachin
  • 6 Answers
SOURCE: have setup hp laserjet M1319
I have a different HP MFP, but had a similar problem. HP helpdesk wasn't able to help (had me update the bios, restart, etc.). I stumbled upon a similar problem on FixYa and found out that some of the MFP's aren't compatible with an office on a multi-line telephone system (something to do with analog).
I contacted my telephone service provider (which happened to be cable) and they made some changes to that line while I was on the phone with them. Worked perfectly ever since. I hope this helps you. Good luck!
Posted on Jun 25, 2008
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
HP m410n laserjet pro banding gray vertical lines
the two places to look is transfer roller and the fuser unnit.
i think there is a problem with the transfer roller it is under the toner and it needs to be spring loaded. The paper passes between the toner an the transfer roller to charge the paper en let the toner stick to the paper and if it doesn't make correct contact then it wont work
Dec 26, 2013 | HP LaserJet Office Equipment & Supplies
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Hi there, my hp laserjet M1120n MFP is printing with thick black lines? Please assist.
Hello
Unfortunately Thick black lines usually indicate a Fuser-Drum issue. These parts can become worn over extended use and should be replaced. You can try pulling the toner and drum unit out and re-installing them, but if the problem continues then a replacement drum is advised.
Regards GM
Apr 27, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Bran new HP m3035 MFP.
Try replacing the toner if you have another one, even old one should be ok to test, if not the look at the toner drum and see if there is any marks on it.
Jul 09, 2010 | HP LaserJet M3035 MFP Printer
My HP 2840 is printing blue lines on the side of the page
3 Causes for printing Blue Lines on the side of the pages.
01. If it happens with test pages from the machine itself as well as docs;then most likely it is a bad cyan cartridge.if you open the drum shutter on the cyan cartridge,can you see a line on the drum?
02. If the Drum is opened and you can see a continuous line of blue toner is at both sides of the drum. Chance of getting blue lines printed on the side of the pages.
03. If the cartridge is leaking then and will need to be changed.thats why it's ending up on the belt also and it prints blue line on the side of the pages.
Aug 06, 2009 | HP LaserJet 2840 Printer
Tiny dots about 1 inch apart down the side of page
Again, this was actually HP Laserjet 3800. Problem solved by chatting with HP, and them having me go into a diagnosis mode that disabled cartridge check. Then, I removed the cyan cartridge, the dots went away. They then had me put the black into the cyan slot, and not dots appeared. I had backup toner on hand, swapped in a new cyan and magenta, and all was good. HP agreed to replace the cartridges.
Jun 19, 2009 | Brother HL 2140 Laser Printer
Blue streak printing on page
Chances are you have a bad toner. The lines a spaced about the same width as the diameter of the drum on your blue toner. Shack the toner and try again. The toner may also be spilling toner into your printer.
Mar 03, 2009 | HP LaserJet 3600n Printer
Printer prints a line across the paper around three inch from the left hand side of the page.
Check your Toner Carts.
Is the line a certain color?
Black perhaps?
Lift the door of the toner cart.
If you see a streak on your toner drum, you will see a streak on your paperwork.
Look at your fuser as well.
Is there a problem with the big orange roller?
BEWARE! Don't touch the fuser roller its EXTREMELY HOT!
Let the printer cool down before inspecting.
Apr 24, 2008 | HP LaserJet 5500dtn Color Printer
HP LaserJet Pro 100 color MFP M175nw - multifunction  printer / copier / scanner   color Logo
260 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
