Question about Dryers
I have a Kenmore electric dryer with the code F-1. I replaced the thermistor, is there anything else I can check becasue the dryer will not start. It does power up but still has the F-1 code..
    Top Expert:
  • Dryers Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 07, 2012
  • theresehursh Nov 07, 2012
    The model number for the kenmore dryer is 110.67042600
SOURCE: Kenmore Elite Oasis Dryer 6705 not start
I take the timed approach with appliance problems. If they occur 10 years after purchase, I buy a new one. If five years, I call a repair service and measure the cost of repair against the purchase of a replacement. If one year or less after purchase, I pile the expensive, offending, useless lump of an example of the decline of American workmanship into the back of my pickup and push it out on the doorstep of the store where I purchased it.
I find this method to be the most cost-effective and least troubling. And costs me about the same as calling the repair service.
In fact, right now I'm loading up my Kenmore Elite Oasis 6705, purchased March 13, 2007, (note that the problem began one month AFTER the warranty ran out) in the back of my pickup and I will make at quick stop at Sears to push it off the back of my truck (I find if I don't stop, but keep the truck rolling it makes for a much louder and attention grabbing drop off) then find the nearest hardware store so I can purchase some strong nylon line to string across my backyard so I can dry my clothes. I also purchase a bit of extra line so that I have enough to string up any Sears or Kenmore representatives who might stop by to inquire about the appliance they found on their doorstep.
Posted on Apr 12, 2008
  • 3 Answers
SOURCE: Kenmore electric dryer series 90
Check the automatic door shut off switch and wiring. When the door closes it actuates a switch (completes and electrical circuit) which allows the dryer to operate.
Posted on Dec 15, 2008
Greg20
  • 149 Answers
SOURCE: kenmore he2 electric dryer error code f-01
always unplug for 10 minutes and retry first.
Posted on Jun 12, 2009
gamefixer
  • 6 Answers
SOURCE: Kenmore 80 series electric dryer will not start even though the door switch switch appears functional and power is getting to the timer.
Easy fix. I had the same problem on mine. You need access to the back. Remove back cover. Look at bottom left, you will see two blue wires going to a white plastic item next to one of the thermal sensors. This white plastic piece is a fuse, or fusible link if you like. I'm not sure what the rating is, but you can take the old one to a parts store. They can match it. Now, why did it blow? Well, if the dryer is old, it could be just worn out. But more than likely, one of your 230 volt lines has degraded due to a bad connection, thus drawing more amps, thus blowing the fuse. Look at where the power cord comes in at. Is there any discoloration or oxidation at the terminals? If so, replace the power cord at this time, and try to clean up the terminals as best you can. Also, at this time, you probably better take a look at the lint collector duct running along the left side down the back. It's probably so clogged with lint that your dryer does't dry as fast anymore, and air flow from the exhaust is restricted. Take the duct off and clean it out, or blow it out with compressed air. You should be up and running now. Have fun...
Posted on Jun 16, 2009
SOURCE: GE profile harmony dryer electric won't heat after first load
Did you end up replacing this thermistor? If so did that solve the problem? We are having the same issue and I don't want to waste time and $$.
Posted on Mar 23, 2010
The dryer shuts off, keep getting an E1 code, what needs to be done
It sounds like this is a Whirlpool Duet or a Kenmore Elite Dryer due to the error code E1 being available only on this models. The problem here is an open thermistor as what error code E1 means. It's either the thermistor is exhibits an extremely high resistance or the wire harness connecting it to the control board is broken or cut open. Click on the link below for the detailed procedure in accessing the thermistor.
Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Measure the resistance of the thermistor and refer the table below. Normal thermistor resistance is around 10000 ohms (10K) at room temperature.
Replace the thermistor if the resistance is significantly higher (or lower) than what it is supposed to be based on the resistance table above. Check the wire harness connecting it to the control board, if the resistance turns out good, and make sure the connectors are good and the wires are intact. Replace the wire harness if necessary. Consider replacing the control board if both the thermistor and the wire harness turn out good. The link below might enlighten you further on the troubleshooting of the thermistor.
Thermistor Troubleshooting on Whirlpool Duet and Kenmore Elite Dryers
Aug 21, 2011 | Dryers
How do I take the front panel off my kenmore elite electric dryer to see if their are tech notes about my E1error code? My dryer turns off after only a few minutes displaying and E1 error code. The...
The E1 displayed indicates the thermistor is open and needs to be replaced.
The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
The thermistor is available from the following: www.searspartsdirect.com
Enter your model # in the appropriate box to get a full parts break-down and diagrams.
To access the thermistor see the image below.
Remember to unplug the dryer from power first.
The thermistor will have a black and red/white wire on it.
You can check continuity across it with the meter and if the circuit is open then the thermistor needs to be replaced.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
The thermistor -may- check ok when cool and freak out when warm!
http://media.fotki.com/1_p,wkrsfrgsskrbttbxgtqsskgwtqkq,vi/wbsdwtgwgxwrgbbgsgs/1/1303472/5961857/image6767img-or.gif
HE3 Dryer: http://media.fotki.com/1_p,wbfbgrrwtrrkfttxgtqsskgwtqkq,vi/kgwgwwwdkxkfkkgwgqs/1/1303472/5961857/image7127img-or.gif
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Kenmore Elite HE4 Electric Dryer
E 1 error code comes on after a minute or so and dryer stops
"E1" error code indicates an open thermistor. The thermistor is located on top of the blower housing. Get to it by removing the bottom quarter panel. The thermistor has gone faulty and you should for a immediate replacement to fix this problem.
Thank you !!
Jul 07, 2010 | Kenmore 62602 Electric Dryer
Kenmore HE3 Gas Dryer F23 error
Well the F23 error code is an exhaust thermistor error. It indicates the thermistor is shorting out. This occurs after the thermistor heats up and that is why it happens after 2 minutes. Remember to unplug the power cord so there is no voltage present while servicing.
All you need to do is to pull the dryer out from the wall and be able to get to the back. If you can do this then you can replace the thermistor.
you can check out the below link for more information -
http://media.fotki.com/1_p,wksdqrtgsdbddsdxgtqsskgwtqkq,vi/wbrfdqtbtxwkrtsktgt/1/1303472/5961857/image59719img-or.gif
The thermistor part number is 8577274.
Good Luck!!
Thanks for using FixYa!!
Jul 07, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore dryer is blinking e1 can you tell me what the prolbem is.
I have a Kenmore Electric HE3 dryer that displays the E1 error code. My husband is good at fixing just about anything so he wants to fix this himself. Is this the Thermistor? Where is it located?
Sep 09, 2009 | Kenmore Elite HE4 Electric Dryer
On a kenmore dryer Elite modle #11071062000 i am getting an error code "E2" can you tell me what this means? Can you tell me how to fix it? The dry runs but will not ignite.
Jun 30, 2009 | Kenmore Elite HE4 Electric Dryer
Error codes
Jul 25, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer starts runs for 4min flashes e1 turns off
The E-1 error code is a thermistor error, some problem with the variable resistance.....this can be caused by over use of fabric softener sheets, which can cause lint to become tacky and coat the thermistor, or it just simply failed. Try replacing the thermistor.
Jan 17, 2008 | Whirlpool GEW9200L Electric Dryer
Code F 1
F1 relates to the thermistor. you need to check that both wires are on. if the wiring is good replace the part.
Sep 21, 2007 | Kenmore Elite HE4 Electric Dryer
Electric kenmore he 3 dryer what is code E-1 mean
This code is for a part called a "Thermistor". Its like a thermostat for an electronic machine.
Sep 06, 2007 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
