Cannon irc1021i error codes E719/E355
Receiving 2 error codes in maintenance mode e719 and e355. I have tried clearing them but no luck.
5 Suggested Answers
  • 82 Answers
SOURCE: E355 0001
You should really be more detailed than that.
E020 is a drum code, magenta if i am correct. Replace that and that should take care of that one.
E604 i believe is the finisher (going from memory). Haven't seen a E355.
If you are having this many error codes, call a canon technician. it could be something that connects the 3.
Posted on Nov 29, 2009
  • 170 Answers
SOURCE: aftter my photocopy is bootting .its fail with
try to reset the error code enter the simulation press * then press simultaneous2,8,then press again * then press copier then function,clear,err, OK then off/on
Posted on Feb 03, 2010
Elbastardo
  • 21 Answers
SOURCE: i have problem canon ir
How to clear the error code:
1. Enter Service Mode: Press * Additional Functions, 2&8 simultaneously, then * Additional Functions again.
2. Then select the [COPIER] option. Under [COPIER], select the Function tab.
3. Under the [FUNCTION] tab, select the [CLEAR] option.
4. In [CLEAR] there is a selection E355-CLR. Select it and hit OK.
5. Reboot the machine.
If the error occurs again:
1. Make sure the connection is secure and tight to the Main-Controller board from the connector cable to the Serial Number board below.
2. Reseat the Main-Controller board into its slot.
3. Go into service mode and clear the error code as explained above.
* If the error still continues, you probably have a bad Serial Number board and it needs to be replaced.
Posted on Sep 14, 2010
  • 358 Answers
SOURCE: Help me resolve error E000001 to the main screen,
E719 The communication between the card reader and the image processor PCB is disrupted.
Possible cause: The wiring is faulty (short circuit, open circuit). The card reader is faulty. The image processor PCB is faulty
Posted on Dec 11, 2010
Cannon 2002n E355-0005 error
Hi
Please follow the below procedure to enter Service Mode
1. In standby mode, press the "Settings/Registration" key.
2. Press the "Reset" key.
3. Press the "Back" key.
4. Press the "Settings / Registration" key.
5. The service mode screen is displayed.
Use the "Back" key to exit Service Mode
COPIER> FUNCTION> CLEAR> ERR; and then turn OFF and then ON the power.
Still have an error after following that steps, please call at 1800-204-4427. I can solve you out.
Dec 17, 2016 | Cannon Office Equipment & Supplies
How can i fix the errore e355-0004 in canon ir 2202 copier
If you wish to get some details; check the site linked here. Pull up older posts.........
http://electro-medical.blogspot.com/
May 02, 2015 | Canon Office Equipment & Supplies
Bagaimana cara mereset e355 mesin Photo Copy IR 5000??
i has cland this error but can't go to OK but don't move......E355-03 it's error
Feb 28, 2014 | Office Equipment & Supplies
E000719-0031 error code for canon ir c5250
E719 0031 00 Title Error in serial communication at the start of the New Card
Reader
Description Failure in communication with the serial New Card
Reader at start-up.
Remedy - Check if the cable of the serial New Card Reader is
disconnected.
- Take out the serial New Card Reader.
- COPIER > Function > CLEAR > CARD
- COPIER > Function > CLEAR > ERR
Dec 20, 2013 | Canon Office Equipment & Supplies
Help me resolve error E000001 to the main screen, in the service settings # Clear> ERR error appears E719, what to do to resolve the error, the printer is new, is the first time I try to install it
Dec 11, 2010 | Canon Office Equipment & Supplies
I have problem canon ir 5000 e355,,....please help me
Aug 27, 2010 | Canon imageRUNNER 5000 Copier
Aftter my photocopy is bootting .its fail with error code E355=001
Feb 01, 2010 | Canon imageRUNNER 5570 Copier
E355 0001 E604 0000 E020 4b00
Nov 15, 2009 | Canon imageRUNNER C3200 Copier
Toshiba e355. Wireless?
"Certain Pocket PC Models have SD or SDIO slots but are not compatible with the SDIO WLAN Card. These include: Toshiba e350 and e750 – these have SDIO slots but do not have SDIO Now! software from BSQUARE. The e355 is the same as the e350.
Sep 11, 2005 | Toshiba e355 Pocket PC
134 people viewed this question
k24674
jasbo
jasbo
