Can't log in my - given to me - advent notebook
I have 'inherited' the little machine, but can log in`
  • 32,281 Answers
You can remove or change the Window's User or administrator's password. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Posted on Nov 07, 2012
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
Advent 4211 will not read linux on usb
Ubuntu has a very user friendly setup. You have the option to download onto USB and either setup (install) or run from USB (good for testing). Same thing for CD's. I like Dual Boot for maximum flexibility. Just install within Windows. Spend a little time on their site to determine what is best for you. Lastly Backtrack 5 also has same options with interfaces to choose from.
Aug 29, 2012 | Computers & Internet
It has a bobbin case underneath the sewing machine, the little lever on the bobbin case comes off and you can't lock in like other machines when I was young, that says it all!!!
go to these 2 sites & email them about the machine, ask them
about the part you want & the manual
sewvacdoctor.com
a1sewingmachines.com
Aug 06, 2012 | Sewing Machines
Advent 7111 narrow screen
If the display isn't going full screen, on that 15.4 inch TFT LCD screen, the problem is the screen Inverter, or LCD screen itself.
90 PERCENT OF THE TIME the fault is the screen Inverter.
It isn't a simple screen resolution setting that needs to be changed.
http://www.laptoppowerjacks.co.uk/advent-inverter/advent-7111-7107-8315-lcd-screen-inverter-as023217127-iv09140t-lf.html
Primer:
An LCD screen does not produce light by itself,
http://solutions.3m.com/wps/portal/3M/en_US/Vikuiti1/BrandProducts/secondary/optics101/
It needs an additional light source.
The additional light source is a Backlight.
A Backlight can be a CCFL, or a series of LED's.
The Advent 7111 Notebook PC uses One CCFL,
http://www.screencountry.com/index.php?section=products&model=7111&brand=Advent&size=
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
(Average size is 2mm Thick. Length is almost as long, as the LCD screen is in height. 2mm is close to 1/16th of an Inch )
A screen Inverter is used to convert the power from the laptop, for the Backlight, and LCD screen.
Primer over.
I don't have access to a Service Manual, for the Advent 7111 Notebook PC. I haven't had one come to my shop for repair.
I DO have years of experience at repairing laptops, and I see the Advent 7111 is just a basic laptop, as I HAVE repaired over the years.
If you wish, I can guide you step by step, in replacing the screen Inverter.
(MANY people go out, and buy an LCD screen, when the problem is a much less expensive screen Inverter. Afterwards they buy the screen Inverter. Too bad they didn't come here first)
Post back in a Comment.
Regards,
joecoolvette
[ The Advent 7111 Notebook PC is just a re-badged Quanta TW3M.
According to the source, you should see TW3M on the bottom of the laptop.
http://www.uktsupport.co.uk/advent/laptop/7111.htm
May 20, 2012 | Advent Computers & Internet
Hi. i'm trying to get my girlfriends notebook(advent 4213) connected to the net. i am using my own wireless net but when i click on the net it comes up saying this page cannot be displayed. do i h
If the Advent notebook normally connects to the internet without problem on her network, then you need to check the following:
1. That she does not have any proxy connection setting in her web browser that you do not use on your own network.
2. Check that her wireless adapter is configured to Obtain an IP address automatically and also Obtain DNS server address automatically.
3. Check the status of the wireless adapter connection and ensure that the Advent notebook has been given a valid IP address, i.e. if your are connecting to a wireless router on your network, you should see an address something like 192.168.x.x where the x.x depend on how your router is setup. If you see a 168.x.x.x address then the notebook is not getting a valid, routable IP address and you should try to do a Repair of the network adapter connection. Repair may also be shown as Diagnose and repair depending on which version of Windows is used.
Jan 07, 2012 | Computers & Internet
When I plug my machine in, it starts sewing very rapidly. I inherited it and am unfamilar with it.
The capacitor in the foot control has blown, undo the foot control and take out the little silver square thing and throw it away, you don't need it
Aug 05, 2011 | Sewing Machines
I have been given a Advent 4213 and I can't turn it on?
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Sep 09, 2010 | Advent 4211c Notebook
Anybody got the driver link to download for an advent laptop as my function keys dont show on screen but work fine
The Advent support site is rubbish. All drivers/utils they list are easily available else where. The ones that can't be found elsewhere aren't given. Useful. However...
For OLDER Advent Laptops/Notebooks and most Advent PCs are made by 'Medion' a German firm. Their website supplies ALL drivers, utils etc for your laptop by the Medion (MD) model number. This you will find on the back of your laptop and will usually begin with a MD- reference (ignore the Advent model number ****).
Stick this model number, or your serial number if you're using a PC, in here: http://www1.medion.de/downloads/?lang=uk and it will list all the applicable drivers for your notebook.
For NEWER Advent Laptops/Notebooks a Tawainese company called ECS manufacturer the Notebooks. You will find the 'ECS' number on the back of your laptop, similar to ECS-G610 for example (thats the model number for the Advent 7091). This can then be used to search for relevent drivers/BIOS' etc here:
http://www.ecs.com.tw/ECSWeb/Downloads/Category_Download.aspx?Categoryid=3&MenuID=37&LanID=9
For MUCH OLDER Advent Laptops/Notebooks a company named as Gericom manufactured the notebooks (also known as Gericon in Germany it seems) and also sold under the name's of 'Mecer', 'Acer' and 'Uniwill', among others. These have model numbers similar to N340S8 etc.
Tracking drivers for these is pretty hard, but these guys seem to still have them on an old section of their site:
http://ftp.mustek.co.za/drivers/list.php?dir=Repository%2F
and by product name (which wasn't used by Advent)
http://www.acomp.hu/pub/gericom/Notebook/
also from the actual source (Gericom) but by product name again
http://download.gericom.com/NOTEBOOK/
Aug 03, 2009 | IBM ThinkPad T30 2366 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
