Question about Car Audio & Video
Bridging eclipse 36401 4 ch amplifier to two 12 inch dual coil speakers . Need step by step instructions
    Master:
  • 689 Answers
My advice is to get some one that noe,s what there doing, That you don,t fry the amp, End this advice is from a person ,That installed car audio equipment for over 40 (Years)
Posted on Nov 09, 2012
4 Suggested Answers
  • 91 Answers
SOURCE: need owners manual for an eclipse car amplifier
google it most will give it for free
Posted on Apr 28, 2009
JOHN RESTY
  • 38 Answers
SOURCE: Car Ampli Problem
Use x21000w speaker size 10 that is good for your ampli..........theres no over heat because your ampli using a battery of your car thats is 12amp supply your ampli
Posted on Sep 29, 2009
  • 83 Answers
SOURCE: i have a 12 inch
Get a 1200 watt 4 channel amp that's 2 ohm stable. Bridge 2 channels into the single 550W rms audiobahn. Use the other channels for each side of the dual box. Turn the LPF or Low Pass Filter on and vibrate down the road.
Posted on Sep 25, 2010
Testimonial: "great answers and very helpful "
Have 2 -12" inch eclipse sw6200 with two positive and negative hook up idk how to hook up from amp
It will depend on the capability of your amp. Each sub has dual voice coils (DVC). Each voice coil is (probably) 4 ohms. If your amp is a single channel, 1 ohm stable amp, you can connect all of the voice coils from both subs in parallel on the amp output. Other configurations will depend on the amp's number of channels and minimum resistance your amp can withstand.
May 01, 2015 | Eclipse Car Audio & Video
Can my eclipse 4 channel amp 36401 be bridged on bchannel. and what would the ems be?
You can bridge the speaker outputs; positive from channel two(2) , and negative from channel one (1) : Positive from channel four (4) and negative from channel three (3).
I believe this will provide 140 watts from each bridged channel.
Jun 09, 2014 | Car Audio & Video
I have two 12 inch 1200 watt kenwood excelons and i want to bridge them to the amp but i can barely turn it up with out blowing fuses
Please check the impedance of those subs. Are they 4 or 8 ohm speakers? Do they have dual voice coils? this app may not be capable of handling dual voice coil four ohms and you're trying to bring it down to a 2 ohm mono.
Dec 19, 2013 | Kenwood KAC-7201 Car Audio Amplifier
How to wire for 3 ch mode
this is the manual and you will find all you need in it.
http://www.fixya.com/support/p78783-eclipse_ea3422_car_audio_amplifier/manual-18248#
Jan 29, 2010 | Eclipse EA3422 Car Audio Amplifier
Kicker 8 inch 4 ohm subwoofer 200 watts rms?
Max 200 W. You could bridge 2 channels of a 4 channel amp (or get a 2 ch amp and bridge it) and connect the sub. Bridging = connect + of sub to + of one channel, and connect - of sub to - of *other* channel. Check amp manual for instructions.
Don't get a mono - most are 300W or more - might burn the coil during loud passages.
Jun 22, 2009 | Car Audio & Video
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Bridging 800a4
That all depends upon whether or not the sub you are running has dual voice coils or just a single voice coil. The 800a4 is a four channel amp; thus the only way you can bridge it will be 3 channel or 2 channel. If you are running a dual voice coil sub then you can wire the amp two channel and get 400 watts x 2 @ 4 ohms. Make sure that you sub can handle this kind of power though.
Here are the specs:
4 x 100 @ 4 ohms (13.8V - <0.05% THD)
4 x 200 @ 2 ohms (13.8V - <0.10% THD)
2 x 400 @ 4 ohms bridged (13.8V - <0.10% THD)
Fuse: External 60A
Manufactured in 1999 - 2001
Jun 18, 2008 | Rockford Fosgate Punch 800a4 Car Audio...
Amp getting hot and shutting off
no mine do that and its pretty much normal
Jun 06, 2008 | Insignia 600W Bridgeable Amplifier with...
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Car Audio & Video Logo
73 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
