Question about Epson Perfection 1260 Photo Flatbed Scanner
My computer says to download the associated twain software for my epson 1260 series scanner. Where do I get it? I tried driver detective and my computer will not bring it up.
  • 28 Answers
Go to epson . com and support drivers enter the model number and download the software
or if you have the cd for it just put it in
Posted on Jan 05, 2009
    Brigadier General:
  • 5,158 Answers
Start here... pick the printer you have and download the software you need
How do install scanner in my pc
To Install a scanner
1) Connect it to your Desktop or PC
2) Check whether its able to detect the new device, Right Click on "My computer" icon and click the manage option
3) Select "Device Manager" & you can see your PC name on the top of the right column, just right click on it and select scan for hardware changes, then you can find an option "others" or "Unknown device" where your device will be listed in yellow color as unknown device, just right click on it and select update software.
4) please have your driver software for your scanner ready else you can download it from their website
5) just accept the terms "I Agree" and download it & unzip it & double click on setup.exe & follow the steps.
6) After installing restart your machine. your ready to go.
7) you can find the printer & scanner icon in the control panel, then your ready to go.
May 31, 2011 | Epson Perfection 1260 Flatbed Scanner
Can I get a driver for the epson perfection 1200 scanner that is compatible with windows vista. at present it will not work with vista and I am told no driver is available, otherwise I have to buy new...
this is pretty ancient model, but... you can try to use winxp twain driver and it should work, your registry most probably will need bit of tweaking... version which will most probably work is TWAIN Driver v5.53A,
follow this procedure, disconnect your scanner from computer, run ccleaner to clean all rubbish, including registry clean.
download twain driver and then run it, force vista to accept it, reboot your computer. connect scanner and you will have then warning from vista about digital signature, disregard it and force install software. scanner should work.
i still would suggest newer version...
Jul 20, 2010 | Epson Perfection 1200 Photo Flatbed...
Using adobe photoshop 8 the editor will import from my Epson Perfection 1260, but the organiser will not get from it displaying "Epson perfection 1260 software for this device could not be launched the...
I don't think it's any of those things. I think it's a Twain Data Source problem. When you install the software for your scanner, make sure you also install the twain data source files. This is the scanning protocol used by all scanners and if not present, the scanner won't import images into Photoshop under the command "File" -> "Acquire."
Mar 25, 2010 | Epson Perfection 1250 Flatbed Scanner
Scanner is not recognizing the TWAIN driver I downloaded
Can you run a test through the scanner and camera wizard?
If so you are using a WIA driver and a registry entry is being blocked.
Look for an error log file in the Epson driver folder.
It may show the entry that has been marked read only.
If so just uncheck the read only mode and re-install software.
Jul 20, 2009 | Epson Perfection 1250 Flatbed Scanner
I had epson 4180 installed for a few months and last week it stopped recognising the scanner. i tried it on another computer and it worked fine.
Sounds like the driver is corrupted. Go to this page courtesy of Epson: Download the twain driver for your operating system, then go ahead and download Epson Easyprint for your computer as well. Install the twain driver and then the Epson Easyprint software and the scanner should work then.
Jun 08, 2009 | Dell Inspiron 530 Desktop Computer
Stopped at start-up after months of no problems
Please trash the twain driver completely.
- Trash epson scan and epson scanner monitor from applications.
- Go to hd. Go to library, then application support. Trash epson scanner module.
- Go back to library. Click on image capture. Trash twain data sources.
- Go to the hd. Click on users. Click on your computer name. Click on Library. Click on preferences. Click on the epson folder. Trash epson scan.
- Empty the trash and restart your mac.
Log on to Install the epson11926.dmg.
Apr 28, 2009 | Epson Expression 1640XL Flatbed Scanner
You need to download a "Twain Driver and Epson Scan Utility" from
the Epson Website.
But before you start downloading the Twain Driver we need to delete
the previously installed driver in your computer.
1.) Click and open the MAC or Apple Hard drive / Application and trash Epson Scan and Epson Scanner Monitor ( drag it to your trash )
2.) MAC hard drive / Library / Image Capture / Twain Data Source., we need to trash ( *.ds file )
3.) MAC hard drive / Library / Application Support., trash the Epson Scanner Module
4.) Disconnect the connection ( USB ) between the printer and your MAC.
5. ) Empty your Trash bin and restart your MAC
After the restart we can now download and install the Twain driver to your MAC.
After the installation try to launch Epson Scan under Application
Feb 10, 2009 | Epson Stylus CX4800 All-In-One InkJet...
On Epson Perfection 1250/165o series ,Twain error,component ICM-2, File Group EW-Profilew ,File <sxICCPath>,Error the filename,directoryname or volume label systax is incorrect.
Power off the Epson. Your twain software did not install correctly.
Uninstall the software you installed for the perfection 1250.
Go to Epson's link listed below & download the twain driver.
Pick your operating system & choose the twain driver.
Re-start your system & try again.
Good luck & Thanks for using FixYa.
please vote..
Mar 08, 2008 | Computers & Internet
Epson scanner perfection 1200u photo
The driver listed on the web for 2K is compatible with XP.
1) Go to the website
2) Under the SCANNERS heading select Epson Perfection Series and then your scanner model.
3) Under the Drivers & Downloads section select Windows. Download the most current driver for your Windows operating system.
4) Follow prompts through survey and license agreement. Choose to SAVE this file to your DESKTOP.
5) When the download is complete, double-click on the Epson icon on the desktop. This will automatically extract the files and begin the SETUP.
6) Follow the prompts to install the scanner, and click on FINISH when prompted.
7) At this point reconnect the scanner to the computer.
8) You will see an ADD NEW HARDWARE WIZARD. Make sure INSTALL THE SOFTWARE AUTOMATICALLY (Recommended) is checked and click NEXT.
9) If a message appears indicating THE SCANNER HAS NOT PASSED WINDOWS LOGO TESTING, click CONTINUE ANYWAY. Then click FINISH.
10) Your scanner is now installed. Restart your computer before testing.
Dec 03, 2007 | Epson Perfection 1200 Photo Flatbed...
I advise deleting any Epson scanner or TWAIN software and installing this driver - TWAIN Driver and EPSON Scan Utility v3.04A - from Epson's download page -
Sep 08, 2007 | Epson Stylus Photo RX600 All-In-One InkJet...
Epson Perfection 1260 Photo Flatbed Scanner Logo
142 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
